Action Group
Action Group is useful for grouping several actions together, both scene and project, and executing them at the same time.
It’s possible to collapse a group or expand it and insert/edit/remove action children.
Pressing the Edit icon  next to the group name opens the main tool, where you can edit the group name, box color, time delay in milliseconds, keyboard shortcut and GPI channel.
It’s also possible to execute all action boxes included in an action group on initialize group by pressing the Execute All icon  at the top-right of the group box.
Remove all actions from the group by selecting Take All Actions Out in the Context Menu (right-click on group action).
Executing a Group – Left-click vs. Right-click
The Execute All button in the top-right of the group box triggers every action contained in the group.
  • Left-click Execute All takes the whole group in (a normal execute).
  • Right-click Execute All sends a Continue to every action in the group instead of a take-in.
This mirrors the behavior of individual actions, where a left-click executes the action and a right-click continues it (advances the next stop-point / animation). Right-clicking the Execute All button does not open the group's context menu, the right-click is reserved for the Continue command.
This is especially useful for template actions, which can be configured to fire a different command on Continue (right-click) than on Take-in (left-click). Standard (non-template) actions carry out the same command on both left-click and right-click. The cascading delays described below are applied identically for a left-click and a right-click, so a group's timing behaves the same whether you take it in or continue it.
Note: Combined with the accumulating delays described below, right-clicking Execute All lets you drive a whole sequence of Continues through a group with a single click.
Accumulating Delays within a Group
Each action inside a group can be given its own time delay (in milliseconds) via the Edit dialog. Within a group these delays accumulate from top to bottom: the delay set on an action pushes back the execution of every action beneath it, rather than only delaying that single action.
When the group is executed, actions fire in their visual order (top to bottom), starting from the group's own delay, and each action's delay is added to the running total used for the actions that follow it.
Example: A group whose own delay is 0 ms, containing three actions:
Order
Action
Action delay
Fires at
1
Action A
500 ms
0 ms
2
Action B
300 ms
500 ms
3
Action C
0 ms
800 ms
Action A fires immediately; because A carries a 500 ms delay, Action B fires 500 ms later; B's 300 ms delay pushes Action C to 800 ms. If the group itself is given a delay, that value is added on top of every action's fire time. This makes it easy to build a timed, cascading sequence of actions inside a single group without scripting.
Command
The Command action lets you write custom commands to talk with Viz Engines, for example to manage stage animations or start a specific director, as shown in the example above.
Tracking Hub
TH Command lets you write a custom command to interact with Tracking Hub.
Note: Tracking Hub is a console program for Viz Virtual Studio that collects and stores data from tracking systems (cameras and objects). Viz Engine is provided with this tracking data at a configurable time or delay.
MSE
MSE lets you retrieve Viz Trio’s saved pages and import them directly into Viz Arc for execution.
The profile used for the action is in the lower left corner of the MSE action. It contains a list of the profiles configured on your MSE.
To Import Viz Trio Pages
This section shows you how to import Viz Trio Saved Pages into Viz Arc:
Press the MSE icon  to make a window containing a list of Viz Trio shows appear.
Select a show. A list of Viz Trio pages is displayed.
You can sort pages by page number, description and template by double-clicking on the header at the top of the list.
Reload MSE pages by clicking Refresh.
To import, select one or more pages and click Add Selected to add them in the actions area.
To abort an operation, close the window or press the Close  button.
At the bottom of the MSE window, you can select Take, Continue, or Take Out, which creates a single action box for every operation.
To Work with Page Animations
Once the pages are imported as MSE Actions, you can work with Page animations:
TAKE: start animation.
CONTINUE: continue animation from the previous stop point to the next.
TAKE OUT: take out the graphic.
Execute: perform the action selected above.
Pilot Data Server Elements
In addition to Viz Trio Pages, you can also create actions linked to Pilot Data Elements stored in the Pilot Data Server (PDS). To get there you need to either select the PDS ELELEMENT button on an existing action or select the PDS ELEMENTS tab when creating a new MSE Action
Note: The PDS Server needs to be properly configured in the Director section under the Vizrt Systems configuration section.
From there you can navigate all available Concepts and navigate down to all available Data Elements under each Template
Click on the Load XML button to visualize the actual raw Payload. This is just for information and cannot be manipulated. Click the Add Selected button to create the MSE Actions or double click the Data Elements to add it to the action canvas.
The resulting action looks like this:
The Viz Pilot action has an additional dropdown menu containing the available MSE Channels. The channels can be configured in Director:
Note: You can only trigger Viz Trio or Viz Pilot elements from Viz Arc. You cannot modify its content payload.
Superchannels
A Superchannel is a A/B switcher built into the Viz Engine that can be used as texture or DVE asset. Each Superchannel owns two sub-channels: One is PLAYING (On Air) and the other is PENDING (where the next content is prepared). A toggle swaps them with a frame-accurate, optionally animated transition, giving a seamless cut/mix between arbitrary content (video clips, live or stream inputs, graphics scenes, still images or web pages).
Viz Arc exposes Superchannels in two places: As layers on a profile channel (the destination), and as a dedicated Superchannel action (the content and the operation). A Superchannel action is created and edited on the action canvas.
Step 1 – Add a Superchannel Layer to a Channel
Superchannels are configured as layers on a profile channel, alongside the usual Front / Main / Back / GFX layers. In the channel’s layer configuration:
  1. Click ADD LAYER and pick a Superchannel from the list – they are labelled SC 1 through SC 16.
  2. Each Superchannel layer shows two extra dropdowns that control how takes behave on that layer.
  3. Make sure to uncheck the MAIN layer which is toggled on by default when creating a new channel.
Take Mode
“When the pending sub-channel is toggled On Air…”
Option
Behavior
Use for
Toggle on loaded (default)
The engine toggles by itself once the pending content has finished loading.
Scenes and clips: anything that reliably reports “loaded”.
Toggle immediately
Viz Arc sends the toggle on execute without waiting for a loaded signal.
Content that never latches “loaded” (for example, an inactive live input).
Prepare only
Only prepares the pending sub-channel; nothing goes on air until you toggle manually.
Pre-cueing content to be taken later (for example, by a separate Control action).
Content Start (Scene Animation)
“When the loaded scene’s stage starts animating…”
Animate after transition (default) / Animate during transition / Animate manually.
Note: This second dropdown governs when a scene’s animation starts, and applies mainly to template actions that target a Superchannel layer. The media Superchannel action (below) plays media rather than scenes and does not use it.
Step 2 – The Superchannel Action
The Superchannel action carries the content and the operation only – the destination and take timing come from the Superchannel layer(s) enabled on the action’s channel (the same model templates use). The editor header states this: “Plays to the SuperChannel layers enabled on this action’s channel.”
A top-level MEDIA / CONTROL switch selects what the action does.
MEDIA Mode (Play Content)
Choose a Source, then configure it:
Source
What you set
Options
Pick an image. Click the thumbnail to browse Graphic Hub, or the folder icon to browse the file system.
Background Loading: Load the image in the background (SETBGL).
Built-In
Pick an Input.
LIVE 1–8 and STREAM 1–16.
Web
Enter a URL.
Clip
Pick a video clip (Graphic Hub or file system).
Play on load (off = cue only, prepared but not auto-started at the transition) and Loop.
CONTROL Mode (Manual Operations)
  • TOGGLE: Swaps the On Air and pending sub-channels (with transition).
  • CLEAR: Clears both sub-channels and reset the active side to A.
(A raw SWAP operation exists but is intentionally not offered in the UI, because the Engine refuses to swap content that is On Air; it is available from scripting only.)
Executing a Superchannel Action
Like other actions, a Superchannel media action responds to the four execution commands:
Command
Effect
Execute
Prepares the content on the pending sub-channel and takes it On Air according to the layer’s take mode (self-toggle when loaded, toggle immediately, or prepare only).
Continue
No effect for static media.
Out
Clears the pending sub-channel and toggles it on, taking the content Off Air.
Update
Replaces the asset directly on the On Air side, without a transition (a hot swap).
In CONTROL mode, Execute performs the chosen operation (Toggle or Clear).
How Superchannels Relate to Channels and Templates
  • Superchannels are addressable destinations inside an Engine, modelled in Viz Arc as layers on a profile channel (peers of Front / Main / Back / GFX), rather than as separate channels or Engines.
  • The Superchannel action is destination-agnostic: It fires to whichever SC layer(s) are enabled on the channel it runs on, and inherits the take mode (and, for scenes, content-start mode) from that layer.
  • Template actions can also target a Superchannel layer: A template played to an SC layer prepares on the pending side and transitions on, using the same take-mode / content-start settings.
  • Other actions (camera, control object, etc.) that hit a Superchannel layer are automatically routed to drive the scene currently on the PLAYING side, so they affect what is On Air.
Shared Memory
Set Shared Memory names and assign a value using Shared Memory. You can add multiple Shared Memory key/value pairs.
The value pairs can be sent to different shared memory destinations:
  • COMMUNICATION: The VizCommunication map of the destination Engines is updated. Only the Engine's selected profile is updated.
  • SYSTEM: The System map of the destination Engines is updated. Only the Engine's selected profile is updated.
  • DISTRIBUTED: The VizCommunication map of the destination Engines is updated and all Engines connected with the same user to the Graphic Hub are updated as well.
The action works only when the destination Engine(s) have either UDP or TCP ports configured for shared memory updates. It uses the UDP port if configured other than 0, else it uses the TCP if configured other than 0.
The Viz Engine configuration, configured to receive shared memory updates via UDP on port 3004 or via TCP on port 3003.
Precision Keyer
Setting up the Precision Keyer is a sequential process where each step creates an interim result. The suggested layout follows the sequence and places the show buttons next to the items which need to be inspected. The buttons shown are check boxes and can be overwritten if another checkbox is selected. If no checkbox is active, the final composition is shown.
No checkbox
Shows the final and composed output of the Keyer.
Trash Matte
Shows the color coded trash matte on the output.
Matte
Shows the key output, white representing foreground and black the background.
Matte Inverse
Shows the inverse of the Matte output, foreground white, background black.
Advanced
(Primary Matte)
Inks threshold values to ease setup when it is hard to distinguish between 0.9 and 1.0 (both appear "white" on monitors).
Value 0.0 is mapped to green and 1.0 to red.
Denoise
Shows the output of the de-noising step.
Processed
Shows the processed output.
Advanced
(Processed Foreground)
Value 0.0 (fully processed) is mapped to red.
Spill
Shows the spill matte.
Edges
Shows the detected edges between foreground and background.
Highlights
Shows the highlights in the foreground.
Primary Matte
  • Hue: Rotate the color space to move the color of the Cyclorama to the purest color chosen, green or blue. You can adjust this by looking at the matte and checking that the matte calculated on the Cyclorama approaches black.
  • Saturation: If the video is not highly saturated you may want to adjust this to ease setting of the opacity and transparency point.
  • Opacity: This is the point at which the primary matte value becomes 100% opaque. Equivalent to the black point on gray scale images.
  • Transparency: This is the point at the which the primary matte becomes 100% transparent. Equivalent to the white point in gray scale images.
Matte Denoise
  • Radius: The radius of the bi-linear filter used to blur the noisy parts of the image.
  • Sharpen: Pixels whose color differ more than this threshold from the main pixel are not included in the blurring process. This maintains detail, even if a large blur radius is applied.
  • Process Foreground: Enables or disables the foreground processing. When disabled, it falls back to a classic alpha blending.
  • Gain: Sets gain for the processed foreground color.
  • RGB: Uses this backing plate color to process the foreground. This value gets subtracted from the foreground color, and the result should be black.
  • Black Point: Scales the key value used when processing the foreground. Only affects areas where matte is > 0.0 and < 1.0. Can be used to enlarge the talent in semi-transparent regions, increases lightness around edges.
  • White Point: Scales the key used when processing the foreground. Only affects areas where matte is > 0.0 and < 1.0. Can be used to shrink the talent in semi-transparent regions, decreases lightness around edges.
The Black Point can be used to enlarge talent, the White Point to shrink it. It only affects foreground processing and transition regions. Shrunken talent introduces darkened edges, enlarged talent enlightens edges.
How to setup RGB values manually:
  • Enabled Advanced mode, it highlights areas which are fully processed in RED (when processed - color is less than 0).
  • Turn all values to 1.0, background should be fully red now, increase gain if it's not.
  • Tune in B: Reduce value until the red areas start to vanish. Go back a little bit.
  • Tune in G: Reduce value until the red areas start to vanish. Go back a little bit.
  • Tune in R: Reduce value until the red areas start to vanish. Go back a little bit.
  • Switch back to normal mode.
  • Check result around edges, fine tune as necessary.
Despill
  • CMY: Cyan, Magenta and Yellow despill gain.
  • Restoration Version: Restores more lightness during despilling when LIGHT is selected.
Lightwrap
Light wrapping: Light wrapping is a compositing technique designed to blend keyed out green screen footage with a background plate. Light wrapping is used to simulate ambient light that casts light onto your subject in the scene. Although in some circumstances (like mixed lighting) it can be better to use a different layer than your background layer for the light wrap, this all depends on your scene.
  • Lightwrap: Enables or disables lightwrapping.
  • Edge Blur: If this value is greater than zero, edge detection is performed and edges found are blurred by the amount set in this field. The blurred edges serve as input to brighten up the edges to overcome overshooting when going from a dark color to the Cyclorama. These edges are used for lightwrapping.
  • Edge Blur Factor: Determines how much of the background blur is used for the edge lightwrapping. 1.0 = same blur as for spill lightwrapping, 0.0 = use unblurred background.
  • Kernel: Choose between LAPLACE and SOBEL. LAPLACE is more fine-grained and keeps more details.
  • Blur: The blurred background is used for lightwrapping onto the foreground together with the spill matte or the edge matte. See also Edge Blur Factor.
  • Edge Gain - Background: Defines how strongly the lightwrap is applied to the background when using the edge matte.
  • Spill Gain - Background: Defines how strongly the lightwrap is applied to the background when using the spill matte.
  • Solid Color RGB: A constant color that is applied as a lightwrap on the foreground.
  • Edge Gain - Solid Color RGB: Defines how strongly the lightwrap is applied to the foreground when using the edge matte.
  • Spill Gain - Solid Color RGB: Defines how strongly the lightwrap is applied to the foreground when using the spill matte.
Spill: Carefully use Spill Gain - Background to create an ambient light effect, and increase Edge Gain - Background to improve edge quality. Blur level should be high to prevent transparency effects when using Spill Gain, while Edge Blur Factor can be low to reduce blur used for edge lightwrapping.
Edge Matte: Edge detection is performed on the primary matte, resulting in a grayscale image that in most cases needs to be blurred for a smoother transition.
Shadows
  • Enabled: Toggles background shadows.
  • Inner: Sets threshold under which shadows or dark colors are brought to the background. This feature is disabled if the value is zero.
  • Gain: Strengthens the effect of bringing dark colors back.
Highlights
  • Enabled: Toggles foreground highlights.
  • Inner: Luminescence from which highlights are added to the background.
  • Gain: Highlight gain.
Color Correction
Primary color correction is applied on the already keyed foreground pixels.
  • Saturation: Values for the overall saturation.
  • Contrast: Values for the overall contrast.
  • Exposure: Values for the overall exposure.
  • Lift: RGB values for lift.
  • Gamma: RGB values for gamma.
  • Gain: RGB values for gain.
Presets
Presets can be used to store and recall different presets within the chroma action. Its main purpose is to be able to quickly switch between stored presets and experiment with some settings while being able to quickly undo the changes recalling a stored preset.
Create a new preset by clicking the New Preset button. It can be renamed using the Rename... context menu entry. When a new preset is created the current chroma keying values are stored. After changing some values use the save icon to overwrite the respective preset.
Recall a preset by double clicking the preset entry or by clicking the load icon. Delete a preset using the trash icon or by selecting the Delete... context menu.
Note: The save buttons in the preset stores the preset within the Precision Keyer action. To store them permanently on disk, save the entire project on the local file system or the Graphic Hub.
Video Input
Select the asset source to apply the keying on. Toggle the Unreal button to specify that keying takes place in the Unreal Engine.
Screen Color
Select between GREEN and BLUE screen color, or EXT in order use key and processed foreground from external input, skips internal matte calculation and despiller.
Auto Adjust
For an initial keying setup, point the camera into the green/blue box and hit the Auto Adjust button to get an initial key.
Picking
Picking lets you get a good first estimate of your Chroma/Precision Keyer. Press the Picking button to enter picking mode:
An attempt is automatically made to fetch a still frame from Viz Engine configured in the current channel selected in the chroma action.
You'll now be able to scroll horizontally and vertically within the snapshot and pick an area of green. The picking area can be resized using the mouse wheel.
Once an area is picked, the calculated RGB values are displayed above the snapshot. The HUE value is only relevant if the Precision Keyer is selected. The picked values are directly applied to the Engine if Update On-Edit is enabled.
You can use the Fit and Scroll to view the snapshot either scaled into the view or in it's original size for more accurate picking.
To fetch a new still frame from Viz Engine for picking, press Update Still.
  • The Fetch button retrieves the current keying settings from the Viz Engine. This is useful when creating a new Chroma Action that needs to be initialized with the current settings of Viz Engine.
  • FREEZE freezes the selected video input on the Engine. Don't forget to unfreeze when you are finished adjusting the key.
  • SHOW KEY forces the Viz Engine to output the key channel on the fill output. Deselect this when you are finished adjusting the key.
Adjusting the Keyer
To get to a good keying result, the following steps should be followed in the described order, since the different steps depend on each other.
  • Start by hitting the Auto Adjust key button in the Keyer control. This sets the values of the hue and saturation and ensures that the rest of the keying parameters are set to a value to optimize their influence on previous settings.
  • The obtained result after hitting the Auto Adjust key button is the primary matte which results from the difference between the pixel colors and the primary color. The ideal hue can be found by viewing the matte and rotating the hue until the key strength is at a maximum. The brightness of the key represents the strength of the key. The saturation can be used to increase the key strength in case the signal coming from the camera is not very saturated. To adjust the limits for transparency and opacity the user can switch between the key and inverse key view. Clicking on the same button again disables the view.
  • Denoising can be viewed either on the key signal or on the denoised frame which is used to calculate the key. A large radius has a performance cost. Denoising should eliminate the noise on homogenous areas, while keeping details like hair intact.
  • The processed foreground is the next step. The background should be replaced by solid black. When reducing the gain, the user can check if too much or not enough red or blue is still in the processed foreground. Subtracting the wrong color results in red or blue tint in areas with semi-transparent key.
  • Despilling serves two purposes: It removes the green or blue spill from the people and objects in the studio and generates a matte which can be used for light wrapping with either a solid color or blurred background. The shadows and highlights sections allow to bring back dark and bright colors. This happens after the processed foreground has been applied to the background. This should be done after adjusting the primary key and processed foreground.
  • Lightwrapping helps to blend foreground and background better and should be the last step in the process of keying/compositing.
  • A color correction can be applied to the processed foreground. It has no effect on any of the keying and blending methods.
Precision Keyer Stages
The final composited output after Auto Adjust has been pressed is shown above.
Output of the matte only, black representing foreground and white background, is shown above.
Output of the inverse matte only, black representing background and white the foreground, is shown above; helpful for seeing details such as hair.
Output showing the detected and blurred edge is shown above.
Output of the processed foreground that also shows the light wrap around the talent is shown above.
Unreal Command
The Unreal Command action lets you write custom commands to talk to the Unreal Engine, for example to trigger a sequence. Multiple commands can be sent separating them by ; and a newline.
Native Unreal commands are also allowed such as for example:
  • disableallscreenmessages: Disables all screen messages.
  • enableallscreenmessages: Enables all screen messages.
  • scalability 2: Sets the render quality to High.
  • stat FPS: Shows some FPS information on screen.
  • stat unit: Shows some useful performance information on screen.
  • r.ScreenPercentage 50: Sets the Screen Percentage scaling resolution to 50.
  • sg.ShadowQuality 0: Reduces the Shadow Quality to 0.
Virtual Studio
Virtual Studio lets you set up X/Y/Z positions and Y rotations of every scene listed at the left of the panel. When Send Position is unchecked, it only sends the scene index to be selected on the Engine(s) and uses the position and rotation stored in the current scene.
Viz Camera
In Viz Camera, you can select between every camera in Viz Engine (from 1 – main to 16). The default behavior once a Camera Action is created is to switch the active camera.
If the toggle Editor/Remote is activated you can force a camera to be in Remote or in Editor mode, for example.
When Editor mode is selected, you can enable all aspects of the camera such as Angle, Position and Direction and force the displayed values.
