You can select how exports are created.
LST Settings
Export schedule after Import/Update: When checked, the schedule export process will be performed after a schedule import and/or schedule update.
Merge elements added by Rules with source Schedule: When checked, schedule export will be a merge export, based on the source Schedule and include elements added by rules. If unchecked, it will be an export, all elements will be included in the schedule file.
Schedule Export Folder: The path where a schedule file is exported to during the schedule export process.
See also:
