Viz Channel Branding Release Notes
Version 5.0 | Published July 03, 2023 ©
Viz Channel Branding 5.0.0
Release Date: 2023-06-30
These are the release notes for Viz Channel Branding 5.0.0.
Functionality Added
  • Integrations Hub REST API v2
  • 64 bit Playlist Importer
  • 64 bit Channel Branding Client
  • New Component: Channel Deck
  • New Component: (Promo Server) Failover Helper
  • Introduction of Message Element for playlist
Functionality Improved
  • New improved Page Editor with an all new powerful Playlist Query and Database Query sections
  • Database Query can now be set per Page Field, including against different databases
  • Memory footprint of Promo Server reduced by 97%
  • Time zone and DST handling for Schedule and Channel settings uses latest available data from every system update
  • Rules section reworked for easier administration of powerful capabilities
System Requirements
  • Windows 7 64-bit (only), or higher
  • Microsoft .NET Framework 4.8.
  • Media Sequencer 5.0 or higher
  • Viz Engine 3.6 or higher
  • Graphic Hub REST 2.4.2 or higher
  • Media Codecs (K-lite Codec Pack full)
    Note: Codecs are required to preview proxy videos from Viz One. For installation, see the Viz One Integration section in the Viz Channel Branding User Guide.
Migration
Migrating from Viz Multichannel 4.2.x to Channel Branding 5.0+
  1. Uninstall previous version.
  2. Install Viz Channel Branding 5.0 component 'Upgrade Tool'
  3. Run 'Upgrade Tool' and 'Migrate' and then 'Upgrade' appropriate channels - it is a two-step process, one data migration-step step and one final data-upgrade pass
Documentation
Documentation for Viz Channel Branding is available at the Vizrt Documentation Center:
Support
