Shared Memory Integration of Channel Volume Levels
The volume level of Live Input Channels like SDI, IP or NDI as well as clip channels can be exposed to a Shared Memory Variable. This could be used, for example, to visualize a level meter of an input source.
Any change to the input level is written into a shared memory variable in the System.Map. The naming convention is the following:
AudioLevel.LiveIn0_0 for the first Live Input and the first channel.
AudioLevel.LiveIn0_1 for the first Live Input and the second channel.
AudioLevel.LiveIn1_0 for the second Live Input and the first channel.
AudioLevel.LiveIn1_1 for the second Live Input and the second channel.
AudioLevel.LiveIn5_63 for the sixth Live Input and the sixty fourth channel.
AudioLevel.ClipIn0_0 for the first Clip and the first channel.
etc....
To specify how often these values are updated, you can either specify a fixed value in the Viz configuration file:
SECTION AUDIO_CONFIG
0
: No calculation of VU meter values at all (
default
0
: frequency of frames when calculation happens (every X frame(s)).
AudioLevelMeterUpdateInterval =
2
or you can send a command to change it during runtime:
MAIN*CONFIGURATION*AUDIO*LEVEL_METER_UPDATE_INTERVAL GET / SET
Information: A setting of 0 means to not send values anymore.
Note: That the value you receive is in decibel, which is a logarithmic value between -0 and -120.
A sample script to generate a volume meter:
dim mySrc as string
Sub OnSharedMemoryVariableChanged(map As SharedMemory, mapKey As String)
dim tmp as array[string]
dim normal_val as
double
If mapKey.StartsWith(
"AudioLevel"
) Then
dim val = Cdbl(map[mapKey])
normal_val = calculate(val)
mapKey.Split(
"_"
,tmp)
dim idx = cInt(tmp[-
1
if
ChildContainerCount >= idx then
GetChildContainerByIndex(idx).scaling.y = normal_val
end If
End If
End Sub
function calculate(db as
double
) as
double
dim myval as
double
calculate =
10
^(db/
20.00
end function
sub OnInitParameters()
RegisterParameterString(
"source"
"Source"
"LIVE1"
20
20
end sub
Sub OnParameterChanged(parameterName As String)
if
parameterName =
"source"
Then
if
mySrc<>
Then
system.map.UnregisterChangedCallback(
"AudioLevel."
&mySrc&
"_0"
"AudioLevel."
&mySrc&
"_1"
end If
mySrc = GetParameterString(
"source"
system.map.RegisterChangedCallback(
"AudioLevel."
&mySrc&
"_0"
"AudioLevel."
&mySrc&
"_1"
end If
end Sub
This script generates an input field, that specifies the source (for example, ClipIn0). Any change in the shared memory map for AudioLevel.Clip0_0 or AudioLevel.Clip0_1 (Stereo) is applied to y-scaling of two subcontainers:
