Matrox M264 S1/S2/S3/S4
Matrox M264 cards feature hardware-based H.264 encoding and decoding capabilities. Depending on the card used, up to four UHD XAVC streams can be encoded/decoded simultaneously. Viz Engine and Channel Recorder are both capable of using the M264 cards for playback and capture of XAVC material, without affecting CPU performance.
Key Features
PCI Express Cards
H.264 video encoding and decoding
UHD resolution support
4:2:2 10-bit
Sony XAVC compliant encoding including 4K XAVC Long and 4K Intra Class 480
Panasonic AVC-Ultra compliant
Performance for 4:2:2 10-bit Streams for M264 (S1)
Resolutions |
Structure |
Format |
Number of streams |
2160p |
I-frame |
XAVC Class 300 & Class 480 / AVC-Intra 4K |
1 |
1080p |
I-frame |
XAVC Class 200 / AVC-Intra 200 |
3 |
1080i |
I-frame |
XAVC Class 100 / AVC-Intra 100 |
10 |
2160p |
Long GOP |
Generic / XAVC 4K Long |
1 |
1080p |
Long GOP |
Generic / XAVC Long50 / AVC-LongG50 |
5 |
1080i |
Long GOP |
Generic / XAVC Long25 / AVC-LongG25 |
10 |
720p |
Long GOP |
10 |
Note: Since the S2, S3 or S4 models host more encoder/decoder chips respectively, the number of possible streams is doubled, tripled or quadrupled.
M264 Configuration
Viz Engine
To enable Viz Engine to use M264 cards, the serial number of the M264 must be added to the configuration file after the serial number of the installed X.mio3 or DSX LE 4 card.
Matrox.Devices = A123456,A654321
Channel Recorder
When the XAVC UHD codec is used, Channel Recorder automatically detects any installed M264 card and uses it for encoding. No further configuration is necessary.
