Viz Engine supports a wide range of Matrox products. This chapter provides an overview of the different Matrox video cards supported by Viz Engine, as well as providing their common installation procedures.
The Matrox X.mio series boards are used as Vizrt’s HD, SD and UHD multi-channel video- and audio I/O solution.
  • X.mio5/DSX LE 5 series: Integrates Viz Engine into an IP based workflow (2110) (optional SDI).
  • DSX Core: Allows to playback Matrox encoded clips without the need of a physical hardware.
  • X.mio3/DSX LE 4 series: Introduced in 2015 and is supported by Viz Engine 3.8 and higher.
See Also:
  • Driver History for Matrox X.mio and DSX Series
