The Matrox X.mio5 video board is the next generation IP card supporting SMPTE ST 2110-20/30/40 protocols. It is equipped with quad 25GbE SFPs delivering an effective, fully redundant bandwidth of 50GbE capable of providing four UHD inputs and outputs.
Key Features
  • Native SMPTE ST 2110 support with no CPU usage.
  • Up to four UHDp60/50 inputs and four UHDp60/50 outputs over 25GbE.
  • ST 2110-21 packet pacing in hardware for narrow senders (Type N).
  • Wide asynchronous receivers (Type A).
  • 32x HD inputs and outputs over 25GbE.
  • 256 audio flows from one to 64 tracks.
  • Multi-channel HDR conversion.
  • On-board de-interlacing, scaling and compositing.
  • Integrated hardware PTP for ST 2059-2.
  • Built in NMOS IS-04 and IS-05 support.
General Notes
  • Please be aware that an X.mio5 uses a 16x PCIe slot. It can't use the same slot as an X.mio3.
  • To make sure the PTP is stable, all Power Management options in Windows and BIOS need to be disabled (Runtime power management disabled in BIOS settings).
  • Each SFP of an X.mio5 board requires two IP addresses. This is mandatory.
  • NTSC and PAL resolutions are not supported by the SMPTE ST 2110 standard.
Matrox X.mio5 IP Configuration
Please see section SMPTE ST 2110 Configuration for further details.
