Use the Video Output section to configure special settings for video output, such as SPG settings and so on.
Video Output Properties
- Show Video Output Config. Editor: Opens the Video Output Editor. You can also open the Video Output Editor by pressing ALT + V.
- Video wall/Multi-display: Sets the main output to the Digital Visual Interface (DVI).
Important: For videowall setups, this setting must be active and the output format must be set to FULLSCREEN.
- Render preview default setting: Sets the default value for the Preview button (see Control Buttons) when Viz Engine is in On Air mode. - Inactive: Renders only video out signals. This increases performance, as the renderer does not have to render into an editor on-screen and into pixel buffer.
- Active: Renders both video out signals and on-screen (this decreases performance).
- Fullscreen: Sets the On Air window to screen size.
Video Output Editor
The Video Output Editor defines the synchronization standard and the output signal phases.
- Freerun: Locks Viz Engine to a clock signal on the video board.
- Blackburst: Locks Viz Engine to a Blackburst GenLock signal.
- Tri-level: Locks Viz Engine to a Tri-Level GenLock signal.
- Auto: Auto detects the genlock signal and locks to it.
- Digital Input 1 and 2: Locks Viz Engine to the signal on Input 1 or 2.
- PTP: Uses a Precision Time Protocol source for synchronizing. Mainly used in IP networks.
- H-Phase and V-Phase: Shifts the output signal with respect to the sync signal.
Note: The Auto option is only available on Matrox boards. On Matrox boards the h- and v-phase settings are updated automatically with default values based on the output resolution (Except IP based cards). It is still needed to measure the exact h- and v-phase for each setup.
To Make the V- and H-Phase Values Coincide
- Set the V-phase value. - The V-granularity is taken from the genlock.
- The V-delay is calculated from V-phase * V-granularity.
- The genlock is set with this V-delay.
- Set the H-phase value. Note that there is a distinction whether the H-phase is a positive or a negative value. - If the H-phase > 0
- The genlock H-delay is set to - 0.
- The H-granularity is taken from the video out channel.
- The H-delay is calculated from H-phase * H-granularity.
- The fill and key channels are set with this H-delay.
- If the H-phase <=0
- The fill and key channel H-delay is set to - 0.
- The H-granularity is taken from the genlock.
- The H-delay is calculated from - H-phase * H-granularity.
- The genlock is set with this H-delay.
Note: The granularity and possible min/max values are printed to the Viz Artist/Engine console during startup.
It should be taken into account that when the genlock video format is different from the fill/key video format the value of the V-delay matches the genlock lines and not the video output lines. The same applies to negative H-phase values.
