Gateway Administrator Guide
Version 5.0 | Published January 08, 2018 ©
Install Database Client
This section describes how to install and test the Oracle Database 11g Client. For further documentation, please see the Oracle Documentation website:
http://www.oracle.com/technology/software/products/database/
http://www.oracle.com/technetwork/indexes/documentation/index.html
Note:
Installing the Oracle Database Client is not necessary if you connecting to Oracle or Graphic Hub via the Pilot Data Server.
IMPORTANT!
A 64-bit Oracle Client is required because the Media Sequencer is a 64-bit application.
Before installing Gateway, check the language settings for the Oracle client. The National Language Support (NLS_LANG) parameter must be the same as on the Vizrt database.
This section has more information about these topics:
To install the extra stored procedure (only for Viz Pilot 5.1 - 5.6)
Also, refer to Oracle software and documentation:
Pre-installation
If there is an existing Oracle Client installed, create a backup of the tnsnames.ora file
Remove any previous or older versions of the client
Download the client from Oracle’s web site
Click Downloads, and follow the instructions to make sure that the correct Oracle Database Client installation executable is selected.
To install the Oracle client
Note:
The installation procedure below is according to Oracle Client version 10.2.0.1.0. For a reference on another version, see the Oracle web site.
Log on as a member of the Administrators group to the computer on which to install Oracle components. For installations on a Primary Domain Controller (PDC) or a Backup Domain Controller (BDC), log on as a member of the Domain Administrators group.
Double-click the installer (setup.exe).
In the Welcome screen, click Next.
In the Select Installation Type screen, select type Runtime.
In the Specify Home Details screen, click Next
In the Product-Specific Prerequisite Checks screen, click Next.
In the Summary screen, click Next to start the actual installation and configuration.
Note:
Do not use the Oracle Net Configuration Assistant (NetCA) unless there are specific client connection configuration needs. Using the NetCA is beyond the scope of this guide.
Click Next.
In the End of Installation screen, click Exit, then click Yes to exit from Oracle Universal Installer.
Optionally, delete the \temp\OraInstalldate_time directory to remove the temporary files that were created during the installation process. The OraInstalldate_time directory holds about 45 MB of files.
Restarting the computer also removes the OraInstalldate_time directory.
See also section Installation, and how To test the installation.
To set the language setting for the Oracle client
Start the Registry Editor (regedit) on the Start menu
Click the Run menu option, enter regedit, and click OK
Open the path \HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\ORACLE\KEY...<version>
Double-click the registry setting for NLS_LANG.
Edit the string and change it to AMERICAN_AMERICA.AL32UTF8, and click OK
Note:
To help give Vizrt’s customers the best possible support, American English is chosen as the default language for log messages.
Start a command-line tool, and type the following:
sqlplus userid/password
@tnsname
It is also possible, if a TNS name alias is not configured, to use an easyconnect string:
@hostname
/SID
Check that the output is something like the example output below:
C:>sqlplus pilot/pilot
@VIZRTDB
SQL*Plus: Release
10.2
0.1
0
- Production on Thu Mar
24
12
17
19
2014
Copyright (c)
1982
2010
, Oracle. All rights reserved. Connected to: Oracle Database 10g Release
10.2
0.1
0
- Production SQL>
See also section Installation.
