Introduction
The Mosart Remote Control Service (RCS) provides a REST API for controlling Viz Mosart rundowns using REST. This interface in effect duplicates some GPI/O calls (0-4) for rundown operations.
Working with the REST API
Prerequisites/Conditions
  • The descriptions below of the command assume that RCS and the user work on the same machine and its name is localhost.
  • The API hosted by RCS and configured to run on port 55167. This port can not be configured.
  • Employs API key-based authentication where the key needs to be passed in a HTTP header called "X-API-key". See Authentication below.
  • All routes under "/api/v1/command" are protected.
  • All commands of this API are accessible only when RCS is running.
Swagger Documentation
Command Descriptions
Reload rundown
The reload endpoint allows you to reload the current rundown. It will trigger a rundown reload event. I.e. the timeline will be stopped and the current rundown will be reloaded from the NRCS cache. No additional parameters.
GET api/v1/command/reload
Start/Continue Rundown
Start or continue the rundown. You can use some optional parameters - see the swagger documentation.
GET api/v1/command/start-continue
Skip Next
Skip the next item in the rundown.
GET api/v1/command/skip-next
Unskip Next
Unskip a previously skipped item in the rundown.
GET api/v1/command/un-skip-next
Skip Next Sub Item
Skip the next sub item in the rundown.
GET api/v1/command/skip-next-sub-item
Unskip Next Sub Item
Unskip a previously skipped sub item in the rundown.
GET api/v1/command/un-skip-next-sub-item
Start Rundown from Top
Restart the rundown from the first story. No additional parameters.
GET api/v1/command/start-from-top
Enable/disable Rehearsal Mode
Enable/disable/toggle rehearsal mode:
GET api/v1/command/rehearsal-mode?state=true
GET api/v1/command/rehearsal-mode?state=false
Take a Template
Takes the template by its type and variant (name) and which bus (optional).
GET api/v1/command/template?type={template-type}&variant={variant}&bus={preview|program}
For example,
GET api/v1/command/template?type=Camera&variant=CAM1
Here Camera and CAM1 are the current type and name of the desired template cut to program.
GET api/v1/command/template?type=Camera&variant=CAM1&bus=PREVIEW
Here Camera and CAM1 are the actual type and name of the desired template put into preview.
Trigger a DirectTake Template
Trigger a given DirectTake template. You must provide the number of desired template.
GET api/v1/command/directtake?number={number}
Trigger Control Command
Trigger a control command in Mosart.
Here is a list of the Control Commands supported by the API along with the parameters the command takes.
Control Command
Parameters (case sensitive)
start_from_top
switch_rehearsal_mode
Action: TOGGLE | ACTIVATE | DEACTIVATE
If no Action parameter is passed, it will DEACTIVATE.
autotake
Action: TRUE | ACTIVATE | FALSE | DEACTIVATE | TOGGLE
If no Action parameter is passed, it will TOGGLE
play_story
Story+Name: String
videowallmode
MicEffect: string
release_background
CueOnly: bool
overlay_graphics
Render: string
Action: CONTINUE | TAKE_MANUAL_OUT | TAKE_ALL_OUT | TAKE_LAST_OUT | PRETAKE_NEXT | CLEAR | MACRO | TAKE_NAMED_OVERLAY
Parameter: string
Value: string
marked
Description: string
directtake
Template: number
accessories
ncs
Action: START_STATUS | STOP_STATUS
Parameter: string
rundown_ncs_resync
user_message
Message: string
overlay_to_manual
Target: SELECTED | ONAIR | PREVIEW
Handlers: string
TakeOutMethod: AUTOMATIC | MANUAL
storyid: string
gui
asrunlog_event
Action: RemotePanelFunctions
Parameter: string
switch_graphics_mirroring
Action: TOGGLE | ACTIVATE | DE-ACTIVATE
enable_graphics_mirroring
Target: NONE | OVERLAY
Action: bool
switch_genlock_mode
engine_switcher
Action: INIT | PRESET_STYLE | GOTO_PREV_PRESET
PresetName: string
Transition: CUT | TAKE
autotrans
MixEffect: PP | PROGRAM | ME1 | ME2 | ME3
Transitionrate: string
video_server_goto
ServerChannel: CURRENT | ONAIR | PREVIEW
frame: number
dve
Direction: FORWARD | FWD | REVERSE | REV | BACKWARD
fullscreen_graphics
Engine: string
Action: CONTINUE | MACRO
Parameter: string
audio
Action: FADE_MANUAL | FADE_OUT_KEEPS | FREEZE_AUDIO | SET_LEVEL_2_PREVIEW | SET_LEVEL_2_ONAIR | FADE_DOWN_ALL_MAINS | FADE_DOWN_SECONDARY_AUDIO | FADE_UP_LAST_MAINS | FADE_UP_SECONDARY_AUDIO
Faderate: number
light
Scene: number
sequence
Action: START | STOP | LOOP | STOPLOOP
take_server_to_program
Transitionrate: number
video_port
Action: PLAY_PAUSE | PLAY | PAUSE | PLAY_CONTINUE | STOP | CUE | RECUE | SET_LOOP | SET_LOOP_OFF | PLAY_TAIL | CUE_TAIL
VideoPort: string
Parameter: string
get_player_status
VideoPort: string
weather
Action: PLAY | CONTINUE | GOTO_FIRST
graphicsprofile
studiosetup
set_aux_crosspoint
Bus: string
CrossPoint: string
set_crosspoint
Bus: A | B | C | D | KEY1 | KEY2 | KEY3 | KEY4
CrossPoint: string
transition_type
TransitionType: MIX | WIPE | EFFECT | Default | Toggle | Cut | None
Value: number
record
Command: PREPARE | START | STOP | STOP_AND_DETACH | DELETE | GETSOM
ClipName: string
PortName: string
Group: string
Recorder: string
Duration: number
IgnoreClipNamePattern: bool
device_properties
For audio mixer device properties:
Parameter1: AUDIO
Parameter2: string
The key of the property you want to set.
Parameter3: string
The value of the property you want to set.
set_videoserver_salvo
Salvo: string
switch_videoserver_mirroring
GET api/v1/command/controlcommand/{command}?params…
Load Rundown
Load/Open a specific rundown in Mosart. This only works with MOS-based rundowns, and you have to provide the ID of the rundown that you want to open. In Vizrt’s Showmaker, you can get this ID by opening a rundown, then copying the ID from the URL.
GET api/v1/command/open-rundown?id={rundown-id}
Authentication
All commands require the special API key as a sign that the action has been authorized. This key should be passed in HTTP header called X-API-key.
Remote Control Dispatcher Service (RCS) configuration file
The RCS configuration file contains a new setting RestApi. It's value can be randomly generated to be robust and sustainable against brute-force attack. Each REST call will compare the passed in header key  X-API-key  with the value from the RestApi setting first.
%ProgramData%\Mosart Medialab\ConfigurationFiles\RemoteDispatcherServiceConfig.xml
<?xml version="1.0" encoding="UTF-8"?>
<RemoteServiceConfig>
<Properties>
<item name="RestApiKey" value="test-api-key" />
curl -X GET "http://localhost:55167/api/v1/command/reload" -H "accept: */*" -H "X-API-Key: test-api-key"
Warning: All the above commands will impact the live show on your Mosart server.
