GPIO Sample XML Config
Working configuration from Viz Mosart Lab in Bergen, October 2014<?xml version="1.0" encoding="ISO-8859-1"?><!--V2.30, Aug 1 2013, 12:55:23--><io-Digital12x12.3> <Config> <Device> <Text> <DeviceName>WEBIO-<wut1></DeviceName> <DeviceText> From the terminal block directly to the network </DeviceText> <Location></Location> <Contact></Contact> </Text> <Time_Date> <TimeZone> <UTCoffset>01:00</UTCoffset> <Enable> <Apply_Time_Zone>ON</Apply_Time_Zone> </Enable> <Summertime> <UTCoffset>02:00</UTCoffset> <Enable> <Apply_Summertime>ON</Apply_Summertime> </Enable> <Start> <Month> <January>OFF</January> <February>OFF</February> <March>ON</March> <April>OFF</April> <May>OFF</May> <June>OFF</June> <July>OFF</July> <August>OFF</August> <September>OFF</September> <October>OFF</October> <November>OFF</November> <December>OFF</December> </Month> <Mode> <first>OFF</first> <second>OFF</second> <third>OFF</third> <fourth>OFF</fourth> <last>ON</last> </Mode> <Weekday> <Sunday>ON</Sunday> <Monday>OFF</Monday> <Tuesday>OFF</Tuesday> <Wednesday>OFF</Wednesday> <Thursday>OFF</Thursday> <Friday>OFF</Friday> <Saturday>OFF</Saturday> </Weekday> <Time>02:00</Time> </Start> <Stop> <Month> <January>OFF</January> <February>OFF</February> <March>OFF</March> <April>OFF</April> <May>OFF</May> <June>OFF</June> <July>OFF</July> <August>OFF</August> <September>OFF</September> <October>ON</October> <November>OFF</November> <December>OFF</December> </Month> <Mode> <first>OFF</first> <second>OFF</second> <third>OFF</third> <fourth>OFF</fourth> <last>ON</last> </Mode> <Weekday> <Sunday>ON</Sunday> <Monday>OFF</Monday> <Tuesday>OFF</Tuesday> <Wednesday>OFF</Wednesday> <Thursday>OFF</Thursday> <Friday>OFF</Friday> <Saturday>OFF</Saturday> </Weekday> <Time>03:00</Time> </Stop> </Summertime> </TimeZone> <TimeServer> <UTCServer1>de.pool.ntp.org</UTCServer1> <UTCServer2>europe.pool.ntp.org</UTCServer2> <SyncTime>0</SyncTime> <Enable> <Apply_TimeServer>OFF</Apply_TimeServer> </Enable> </TimeServer> <DeviceClock> <Time>15:56</Time> <Day>01</Day> <Month>01</Month> <Year>2004</Year> </DeviceClock> </Time_Date> <BasicSettings> <Network> <IP_Addr>10.211.114.124</IP_Addr> <Subnet_Mask>255.255.255.00</Subnet_Mask> <Gateway>10.211.114.01</Gateway> <BOOTPClient> <STATIC>ON</STATIC> <BOOTP_enable>OFF</BOOTP_enable> <DHCP_enable>OFF</DHCP_enable> </BOOTPClient> <DnsServer1></DnsServer1> <DnsServer2></DnsServer2> <KeepAliveTime>00</KeepAliveTime> </Network> <HTTP_Set> <Startup> <index.htm>ON</index.htm> <home.htm>OFF</home.htm> <user.htm>OFF</user.htm> </Startup> <Enable> <GET_Header_enable>OFF</GET_Header_enable> <GET_HTTP_enable>OFF</GET_HTTP_enable> </Enable> <_HTTP_Port>80</_HTTP_Port> <InputTrigger> <Input_0>ON</Input_0> <Input_1>ON</Input_1> <Input_2>ON</Input_2> <Input_3>ON</Input_3> <Input_4>ON</Input_4> <Input_5>ON</Input_5> <Input_6>ON</Input_6> <Input_7>ON</Input_7> <Input_8>ON</Input_8> <Input_9>ON</Input_9> <Input_10>ON</Input_10> <Input_11>ON</Input_11> </InputTrigger> </HTTP_Set> <HTTP_Client> <HTTP_Client> <HTTP_Client_enable>OFF</HTTP_Client_enable> </HTTP_Client> <Enable> <GET_Header_enable>OFF</GET_Header_enable> <GET_HTTP_enable>OFF</GET_HTTP_enable> </Enable> <LocalPort>AUTO</LocalPort> <ServerPort></ServerPort> <Server_IP_Addr></Server_IP_Addr> <ServerUrl></ServerUrl> <InactiveTimeout></InactiveTimeout> <InputTrigger> <Input_0>OFF</Input_0> <Input_1>OFF</Input_1> <Input_2>OFF</Input_2> <Input_3>OFF</Input_3> <Input_4>OFF</Input_4> <Input_5>OFF</Input_5> <Input_6>OFF</Input_6> <Input_7>OFF</Input_7> <Input_8>OFF</Input_8> <Input_9>OFF</Input_9> <Input_10>OFF</Input_10> <Input_11>OFF</Input_11> </InputTrigger> <Timer_Cron></Timer_Cron> </HTTP_Client> <Mail> <Name>Web-IO 12xDigital</Name> <ReplyAddr>Web-IO@no.reply</ReplyAddr> <MailServer></MailServer> <Authentication> <_SMTP_authentication_off>ON</_SMTP_authentication_off> <_ESMTP>OFF</_ESMTP> <_SMTP_after_POP3>OFF</_SMTP_after_POP3> </Authentication> <User></User> <Password></Password> <POP3_Server></POP3_Server> <Enable> <Mail_enable>OFF</Mail_enable> </Enable> </Mail> <SNMP> <Community_String_Read></Community_String_Read> <Community_String_Read_Write></Community_String_Read_Write> <Manager_IP></Manager_IP> <SystemTraps> <Cold_Start>OFF</Cold_Start> <Warm_Start>OFF</Warm_Start> <Diag_Messages>OFF</Diag_Messages> </SystemTraps> <Enable> <SNMP_enable>ON</SNMP_enable> </Enable> </SNMP> <UDP> <Port>42279</Port> <RemotePort></RemotePort> <Enable> <UDP_enable>OFF</UDP_enable> </Enable> </UDP> <Syslog> <SyslogServerIP></SyslogServerIP> <SyslogServerPort>514</SyslogServerPort> <SystemMessages> <Cold_Start>OFF</Cold_Start> <Warm_Start>OFF</Warm_Start> <Diag_Messages>OFF</Diag_Messages> </SystemMessages> <Enable> <System_Messages_enable>OFF</System_Messages_enable> </Enable> </Syslog> <FTP> <FtpServerIP></FtpServerIP> <FtpControlPort>21</FtpControlPort> <User></User> <Password></Password> <FtpAccount></FtpAccount> <Options> <PASV>OFF</PASV> </Options> <Enable> <FTP_enable>OFF</FTP_enable> </Enable> </FTP> <Binary1> <OperationMode> <TCP_Server>ON</TCP_Server> <TCP_Client>OFF</TCP_Client> <UDP_Peer>OFF</UDP_Peer> </OperationMode> <Enable> <Enable_BINARY_1>ON</Enable_BINARY_1> </Enable> <TcpServer1> <LocalPort>49153</LocalPort> <Client_HTTP_Port>80</Client_HTTP_Port> <InputTrigger> <Input_0>ON</Input_0> <Input_1>ON</Input_1> <Input_2>ON</Input_2> <Input_3>ON</Input_3> <Input_4>ON</Input_4> <Input_5>ON</Input_5> <Input_6>ON</Input_6> <Input_7>ON</Input_7> <Input_8>ON</Input_8> <Input_9>ON</Input_9> <Input_10>ON</Input_10> <Input_11>ON</Input_11> </InputTrigger> <ApplicationMode1> <Socket_device>ON</Socket_device> <Compatible_50xxx>OFF</Compatible_50xxx> <Box2Box_Slave>OFF</Box2Box_Slave> <OPC_Device>OFF</OPC_Device> </ApplicationMode1> </TcpServer1> <TcpClient1> <LocalPort>AUTO</LocalPort> <ServerPort>49153</ServerPort> <Server_HTTP_Port>80</Server_HTTP_Port> <Server_IP_Addr></Server_IP_Addr> <ServerPassword></ServerPassword> <InactiveTimeout>30</InactiveTimeout> <InputTrigger> <Input_0>ON</Input_0> <Input_1>ON</Input_1> <Input_2>ON</Input_2> <Input_3>ON</Input_3> <Input_4>ON</Input_4> <Input_5>ON</Input_5> <Input_6>ON</Input_6> <Input_7>ON</Input_7> <Input_8>ON</Input_8> <Input_9>ON</Input_9> <Input_10>ON</Input_10> <Input_11>ON</Input_11> </InputTrigger> <Interval></Interval> <ApplicationMode2> <Socket_device>ON</Socket_device> <Compatible_50xxx>OFF</Compatible_50xxx> <Box2Box_Master>OFF</Box2Box_Master> <ILOface>OFF</ILOface> </ApplicationMode2> </TcpClient1> <UdpPeer1> <LocalPort>45889</LocalPort> <RemotePort>45889</RemotePort> <Remote_IP_Addr></Remote_IP_Addr> <InputTrigger> <Input_0>ON</Input_0> <Input_1>ON</Input_1> <Input_2>ON</Input_2> <Input_3>ON</Input_3> <Input_4>ON</Input_4> <Input_5>ON</Input_5> <Input_6>ON</Input_6> <Input_7>ON</Input_7> <Input_8>ON</Input_8> <Input_9>ON</Input_9> <Input_10>ON</Input_10> <Input_11>ON</Input_11> </InputTrigger> <Interval></Interval> <ApplicationMode3> <Socket_device>ON</Socket_device> <Compatible_50xxx>OFF</Compatible_50xxx> </ApplicationMode3> </UdpPeer1> </Binary1> <Binary2> <OperationMode> <TCP_Server>ON</TCP_Server> <TCP_Client>OFF</TCP_Client> <UDP_Peer>OFF</UDP_Peer> </OperationMode> <Enable> <Enable_BINARY_2>ON</Enable_BINARY_2> </Enable> <TcpServer2> <LocalPort>49154</LocalPort> <Client_HTTP_Port>80</Client_HTTP_Port> <InputTrigger> <Input_0>ON</Input_0> <Input_1>ON</Input_1> <Input_2>ON</Input_2> <Input_3>ON</Input_3> <Input_4>ON</Input_4> <Input_5>ON</Input_5> <Input_6>ON</Input_6> <Input_7>ON</Input_7> <Input_8>ON</Input_8> <Input_9>ON</Input_9> <Input_10>ON</Input_10> <Input_11>ON</Input_11> </InputTrigger> <ApplicationMode1> <Socket_device>ON</Socket_device> <Compatible_50xxx>OFF</Compatible_50xxx> <Box2Box_Slave>OFF</Box2Box_Slave> <OPC_Device>OFF</OPC_Device> </ApplicationMode1> </TcpServer2> <TcpClient2> <LocalPort>AUTO</LocalPort> <ServerPort>49154</ServerPort> <Server_HTTP_Port>80</Server_HTTP_Port> <Server_IP_Addr></Server_IP_Addr> <ServerPassword></ServerPassword> <InactiveTimeout>30</InactiveTimeout> <InputTrigger> <Input_0>ON</Input_0> <Input_1>ON</Input_1> <Input_2>ON</Input_2> <Input_3>ON</Input_3> <Input_4>ON</Input_4> <Input_5>ON</Input_5> <Input_6>ON</Input_6> <Input_7>ON</Input_7> <Input_8>ON</Input_8> <Input_9>ON</Input_9> <Input_10>ON</Input_10> <Input_11>ON</Input_11> </InputTrigger> <Interval></Interval> <ApplicationMode2> <Socket_device>ON</Socket_device> <Compatible_50xxx>OFF</Compatible_50xxx> <Box2Box_Master>OFF</Box2Box_Master> <ILOface>OFF</ILOface> </ApplicationMode2> </TcpClient2> <UdpPeer2> <LocalPort>45890</LocalPort> <RemotePort>45890</RemotePort> <Remote_IP_Addr></Remote_IP_Addr> <InputTrigger> <Input_0>ON</Input_0> <Input_1>ON</Input_1> <Input_2>ON</Input_2> <Input_3>ON</Input_3> <Input_4>ON</Input_4> <Input_5>ON</Input_5> <Input_6>ON</Input_6> <Input_7>ON</Input_7> <Input_8>ON</Input_8> <Input_9>ON</Input_9> <Input_10>ON</Input_10> <Input_11>ON</Input_11> </InputTrigger> <Interval></Interval> <ApplicationMode3> <Socket_device>ON</Socket_device> <Compatible_50xxx>OFF</Compatible_50xxx> </ApplicationMode3> </UdpPeer2> </Binary2> </BasicSettings> <OutputMode> <Output0> <_HTTP>ON</_HTTP> <_UDP_ASCII>OFF</_UDP_ASCII> <_SNMP>OFF</_SNMP> <Binary_1>OFF</Binary_1> <Binary_2>OFF</Binary_2> <_Logic>OFF</_Logic> </Output0> <Output1> <_HTTP>ON</_HTTP> <_UDP_ASCII>OFF</_UDP_ASCII> <_SNMP>OFF</_SNMP> <Binary_1>OFF</Binary_1> <Binary_2>OFF</Binary_2> <_Logic>OFF</_Logic> </Output1> <Output2> <_HTTP>ON</_HTTP> <_UDP_ASCII>OFF</_UDP_ASCII> <_SNMP>OFF</_SNMP> <Binary_1>OFF</Binary_1> <Binary_2>OFF</Binary_2> <_Logic>OFF</_Logic> </Output2> <Output3> <_HTTP>ON</_HTTP> <_UDP_ASCII>OFF</_UDP_ASCII> <_SNMP>OFF</_SNMP> <Binary_1>OFF</Binary_1> <Binary_2>OFF</Binary_2> <_Logic>OFF</_Logic> </Output3> <Output4> <_HTTP>ON</_HTTP> <_UDP_ASCII>OFF</_UDP_ASCII> <_SNMP>OFF</_SNMP> <Binary_1>OFF</Binary_1> <Binary_2>OFF</Binary_2> <_Logic>OFF</_Logic> </Output4> <Output5> <_HTTP>ON</_HTTP> <_UDP_ASCII>OFF</_UDP_ASCII> <_SNMP>OFF</_SNMP> <Binary_1>OFF</Binary_1> <Binary_2>OFF</Binary_2> <_Logic>OFF</_Logic> </Output5> <Output6> <_HTTP>OFF</_HTTP> <_UDP_ASCII>OFF</_UDP_ASCII> <_SNMP>OFF</_SNMP> <Binary_1>ON</Binary_1> <Binary_2>OFF</Binary_2> <_Logic>OFF</_Logic> </Output6> <Output7> <_HTTP>OFF</_HTTP> <_UDP_ASCII>OFF</_UDP_ASCII> <_SNMP>OFF</_SNMP> <Binary_1>ON</Binary_1> <Binary_2>OFF</Binary_2> <_Logic>OFF</_Logic> </Output7> <Output8> <_HTTP>OFF</_HTTP> <_UDP_ASCII>OFF</_UDP_ASCII> <_SNMP>OFF</_SNMP> <Binary_1>ON</Binary_1> <Binary_2>OFF</Binary_2> <_Logic>OFF</_Logic> </Output8> <Output9> <_HTTP>OFF</_HTTP> <_UDP_ASCII>OFF</_UDP_ASCII> <_SNMP>OFF</_SNMP> <Binary_1>ON</Binary_1> <Binary_2>OFF</Binary_2> <_Logic>OFF</_Logic> </Output9> <Output10> <_HTTP>OFF</_HTTP> <_UDP_ASCII>OFF</_UDP_ASCII> <_SNMP>OFF</_SNMP> <Binary_1>ON</Binary_1> <Binary_2>OFF</Binary_2> <_Logic>OFF</_Logic> </Output10> <Output11> <_HTTP>OFF</_HTTP> <_UDP_ASCII>OFF</_UDP_ASCII> <_SNMP>OFF</_SNMP> <Binary_1>ON</Binary_1> <Binary_2>OFF</Binary_2> <_Logic>OFF</_Logic> </Output11> <Safety_Timeout></Safety_Timeout> <Enable> <Load_Control_enable>OFF</Load_Control_enable> </Enable> </OutputMode> <Alarm> <Alarm1> <InputTrigger> <Input_0><enable>OFF</enable><state>OFF</state></Input_0> <Input_1><enable>OFF</enable><state>OFF</state></Input_1> <Input_2><enable>OFF</enable><state>OFF</state></Input_2> <Input_3><enable>OFF</enable><state>OFF</state></Input_3> <Input_4><enable>OFF</enable><state>OFF</state></Input_4> <Input_5><enable>OFF</enable><state>OFF</state></Input_5> <Input_6><enable>OFF</enable><state>OFF</state></Input_6> <Input_7><enable>OFF</enable><state>OFF</state></Input_7> <Input_8><enable>OFF</enable><state>OFF</state></Input_8> <Input_9><enable>OFF</enable><state>OFF</state></Input_9> <Input_10><enable>OFF</enable><state>OFF</state></Input_10> <Input_11><enable>OFF</enable><state>OFF</state></Input_11> </InputTrigger> <OutputTrigger> <Output_0><enable>OFF</enable><state>OFF</state></Output_0> <Output_1><enable>OFF</enable><state>OFF</state></Output_1> <Output_2><enable>OFF</enable><state>OFF</state></Output_2> <Output_3><enable>OFF</enable><state>OFF</state></Output_3> <Output_4><enable>OFF</enable><state>OFF</state></Output_4> <Output_5><enable>OFF</enable><state>OFF</state></Output_5> <Output_6><enable>OFF</enable><state>OFF</state></Output_6> <Output_7><enable>OFF</enable><state>OFF</state></Output_7> <Output_8><enable>OFF</enable><state>OFF</state></Output_8> <Output_9><enable>OFF</enable><state>OFF</state></Output_9> <Output_10><enable>OFF</enable><state>OFF</state></Output_10> <Output_11><enable>OFF</enable><state>OFF</state></Output_11> </OutputTrigger> <SystemTrigger> <Load_Control>OFF</Load_Control> <Interval_Timer>OFF</Interval_Timer> <Cold_Start>OFF</Cold_Start> <Warm_Start>OFF</Warm_Start> </SystemTrigger> <MaxCounterValue></MaxCounterValue> <Interval></Interval> <Timer_Cron></Timer_Cron> <AlarmEnable> <Mail_enable>OFF</Mail_enable> <SNMP_Trap_enable>OFF</SNMP_Trap_enable> <UDP_Client_enable>OFF</UDP_Client_enable> <Send_special_alarm_to_pending_TCP_connections>OFF</Send_special_alarm_to_pending_TCP_connections> <TCP_Client_enable>OFF</TCP_Client_enable> <Syslog_Messages_enable>OFF</Syslog_Messages_enable> <FTP_Client_enable>OFF</FTP_Client_enable> </AlarmEnable> <Mail> <E-Mail-Addr></E-Mail-Addr> <Subject></Subject> <Mailtext></Mailtext> <Alarm_clear_subject></Alarm_clear_subject> <Alarm_clear_text></Alarm_clear_text> </Mail> <SNMP> <Manager_IP></Manager_IP> <TrapText></TrapText> <Alarm_clear_text></Alarm_clear_text> </SNMP> <UDP> <IP_Addr></IP_Addr> <Port></Port> <UdpText></UdpText> <Alarm_clear_text></Alarm_clear_text> </UDP> <TCP> <IP_Addr></IP_Addr> <Port></Port> <TcpText></TcpText> <Alarm_clear_text></Alarm_clear_text> </TCP> <Syslog> <IP_Addr></IP_Addr> <Port>514</Port> <SyslogText></SyslogText> <Alarm_clear_text></Alarm_clear_text> </Syslog> <FTP> <FtpLocalDataPort>AUTO</FtpLocalDataPort> <FileName></FileName> <FtpAlarmText></FtpAlarmText> <Alarm_clear_text></Alarm_clear_text> <Options> <STORE>OFF</STORE> <APPEND>ON</APPEND> </Options> </FTP> </Alarm1> <Alarm2> <InputTrigger> <Input_0><enable>OFF</enable><state>OFF</state></Input_0> <Input_1><enable>OFF</enable><state>OFF</state></Input_1> <Input_2><enable>OFF</enable><state>OFF</state></Input_2> <Input_3><enable>OFF</enable><state>OFF</state></Input_3> <Input_4><enable>OFF</enable><state>OFF</state></Input_4> <Input_5><enable>OFF</enable><state>OFF</state></Input_5> <Input_6><enable>OFF</enable><state>OFF</state></Input_6> <Input_7><enable>OFF</enable><state>OFF</state></Input_7> <Input_8><enable>OFF</enable><state>OFF</state></Input_8> <Input_9><enable>OFF</enable><state>OFF</state></Input_9> <Input_10><enable>OFF</enable><state>OFF</state></Input_10> <Input_11><enable>OFF</enable><state>OFF</state></Input_11> </InputTrigger> <OutputTrigger> <Output_0><enable>OFF</enable><state>OFF</state></Output_0> <Output_1><enable>OFF</enable><state>OFF</state></Output_1> <Output_2><enable>OFF</enable><state>OFF</state></Output_2> <Output_3><enable>OFF</enable><state>OFF</state></Output_3> <Output_4><enable>OFF</enable><state>OFF</state></Output_4> <Output_5><enable>OFF</enable><state>OFF</state></Output_5> <Output_6><enable>OFF</enable><state>OFF</state></Output_6> <Output_7><enable>OFF</enable><state>OFF</state></Output_7> <Output_8><enable>OFF</enable><state>OFF</state></Output_8> <Output_9><enable>OFF</enable><state>OFF</state></Output_9> <Output_10><enable>OFF</enable><state>OFF</state></Output_10> <Output_11><enable>OFF</enable><state>OFF</state></Output_11> </OutputTrigger> <SystemTrigger> <Load_Control>OFF</Load_Control> <Interval_Timer>OFF</Interval_Timer> <Cold_Start>OFF</Cold_Start> <Warm_Start>OFF</Warm_Start> </SystemTrigger> <MaxCounterValue></MaxCounterValue> <Interval></Interval> <Timer_Cron></Timer_Cron> <AlarmEnable> <Mail_enable>OFF</Mail_enable> <SNMP_Trap_enable>OFF</SNMP_Trap_enable> <UDP_Client_enable>OFF</UDP_Client_enable> <Send_special_alarm_to_pending_TCP_connections>OFF</Send_special_alarm_to_pending_TCP_connections> <TCP_Client_enable>OFF</TCP_Client_enable> <Syslog_Messages_enable>OFF</Syslog_Messages_enable> <FTP_Client_enable>OFF</FTP_Client_enable> </AlarmEnable> <Mail> <E-Mail-Addr></E-Mail-Addr> <Subject></Subject> <Mailtext></Mailtext> <Alarm_clear_subject></Alarm_clear_subject> <Alarm_clear_text></Alarm_clear_text> </Mail> <SNMP> <Manager_IP></Manager_IP> <TrapText></TrapText> <Alarm_clear_text></Alarm_clear_text> </SNMP> <UDP> <IP_Addr></IP_Addr> <Port></Port> <UdpText></UdpText> <Alarm_clear_text></Alarm_clear_text> </UDP> <TCP> <IP_Addr></IP_Addr> <Port></Port> <TcpText></TcpText> <Alarm_clear_text></Alarm_clear_text> </TCP> <Syslog> <IP_Addr></IP_Addr> <Port>514</Port> <SyslogText></SyslogText> <Alarm_clear_text></Alarm_clear_text> </Syslog> <FTP> <FtpLocalDataPort>AUTO</FtpLocalDataPort> <FileName></FileName> <FtpAlarmText></FtpAlarmText> <Alarm_clear_text></Alarm_clear_text> <Options> <STORE>OFF</STORE> <APPEND>ON</APPEND> </Options> </FTP> </Alarm2> <Alarm3> <InputTrigger> <Input_0><enable>OFF</enable><state>OFF</state></Input_0> <Input_1><enable>OFF</enable><state>OFF</state></Input_1> <Input_2><enable>OFF</enable><state>OFF</state></Input_2> <Input_3><enable>OFF</enable><state>OFF</state></Input_3> <Input_4><enable>OFF</enable><state>OFF</state></Input_4> <Input_5><enable>OFF</enable><state>OFF</state></Input_5> <Input_6><enable>OFF</enable><state>OFF</state></Input_6> <Input_7><enable>OFF</enable><state>OFF</state></Input_7> <Input_8><enable>OFF</enable><state>OFF</state></Input_8> <Input_9><enable>OFF</enable><state>OFF</state></Input_9> <Input_10><enable>OFF</enable><state>OFF</state></Input_10> <Input_11><enable>OFF</enable><state>OFF</state></Input_11> </InputTrigger> <OutputTrigger> <Output_0><enable>OFF</enable><state>OFF</state></Output_0> <Output_1><enable>OFF</enable><state>OFF</state></Output_1> <Output_2><enable>OFF</enable><state>OFF</state></Output_2> <Output_3><enable>OFF</enable><state>OFF</state></Output_3> <Output_4><enable>OFF</enable><state>OFF</state></Output_4> <Output_5><enable>OFF</enable><state>OFF</state></Output_5> <Output_6><enable>OFF</enable><state>OFF</state></Output_6> <Output_7><enable>OFF</enable><state>OFF</state></Output_7> <Output_8><enable>OFF</enable><state>OFF</state></Output_8> <Output_9><enable>OFF</enable><state>OFF</state></Output_9> <Output_10><enable>OFF</enable><state>OFF</state></Output_10> <Output_11><enable>OFF</enable><state>OFF</state></Output_11> </OutputTrigger> <SystemTrigger> <Load_Control>OFF</Load_Control> <Interval_Timer>OFF</Interval_Timer> <Cold_Start>OFF</Cold_Start> <Warm_Start>OFF</Warm_Start> </SystemTrigger> <MaxCounterValue></MaxCounterValue> <Interval></Interval> <Timer_Cron></Timer_Cron> <AlarmEnable> <Mail_enable>OFF</Mail_enable> <SNMP_Trap_enable>OFF</SNMP_Trap_enable> <UDP_Client_enable>OFF</UDP_Client_enable> <Send_special_alarm_to_pending_TCP_connections>OFF</Send_special_alarm_to_pending_TCP_connections> <TCP_Client_enable>OFF</TCP_Client_enable> <Syslog_Messages_enable>OFF</Syslog_Messages_enable> <FTP_Client_enable>OFF</FTP_Client_enable> </AlarmEnable> <Mail> <E-Mail-Addr></E-Mail-Addr> <Subject></Subject> <Mailtext></Mailtext> <Alarm_clear_subject></Alarm_clear_subject> <Alarm_clear_text></Alarm_clear_text> </Mail> <SNMP> <Manager_IP></Manager_IP> <TrapText></TrapText> <Alarm_clear_text></Alarm_clear_text> </SNMP> <UDP> <IP_Addr></IP_Addr> <Port></Port> <UdpText></UdpText> <Alarm_clear_text></Alarm_clear_text> </UDP> <TCP> <IP_Addr></IP_Addr> <Port></Port> <TcpText></TcpText> <Alarm_clear_text></Alarm_clear_text> </TCP> <Syslog> <IP_Addr></IP_Addr> <Port>514</Port> <SyslogText></SyslogText> <Alarm_clear_text></Alarm_clear_text> </Syslog> <FTP> <FtpLocalDataPort>AUTO</FtpLocalDataPort> <FileName></FileName> <FtpAlarmText></FtpAlarmText> <Alarm_clear_text></Alarm_clear_text> <Options> <STORE>OFF</STORE> <APPEND>ON</APPEND> </Options> </FTP> </Alarm3> <Alarm4> <InputTrigger> <Input_0><enable>OFF</enable><state>OFF</state></Input_0> <Input_1><enable>OFF</enable><state>OFF</state></Input_1> <Input_2><enable>OFF</enable><state>OFF</state></Input_2> <Input_3><enable>OFF</enable><state>OFF</state></Input_3> <Input_4><enable>OFF</enable><state>OFF</state></Input_4> <Input_5><enable>OFF</enable><state>OFF</state></Input_5> <Input_6><enable>OFF</enable><state>OFF</state></Input_6> <Input_7><enable>OFF</enable><state>OFF</state></Input_7> <Input_8><enable>OFF</enable><state>OFF</state></Input_8> <Input_9><enable>OFF</enable><state>OFF</state></Input_9> <Input_10><enable>OFF</enable><state>OFF</state></Input_10> <Input_11><enable>OFF</enable><state>OFF</state></Input_11> </InputTrigger> <OutputTrigger> <Output_0><enable>OFF</enable><state>OFF</state></Output_0> <Output_1><enable>OFF</enable><state>OFF</state></Output_1> <Output_2><enable>OFF</enable><state>OFF</state></Output_2> <Output_3><enable>OFF</enable><state>OFF</state></Output_3> <Output_4><enable>OFF</enable><state>OFF</state></Output_4> <Output_5><enable>OFF</enable><state>OFF</state></Output_5> <Output_6><enable>OFF</enable><state>OFF</state></Output_6> <Output_7><enable>OFF</enable><state>OFF</state></Output_7> <Output_8><enable>OFF</enable><state>OFF</state></Output_8> <Output_9><enable>OFF</enable><state>OFF</state></Output_9> <Output_10><enable>OFF</enable><state>OFF</state></Output_10> <Output_11><enable>OFF</enable><state>OFF</state></Output_11> </OutputTrigger> <SystemTrigger> <Load_Control>OFF</Load_Control> <Interval_Timer>OFF</Interval_Timer> <Cold_Start>OFF</Cold_Start> <Warm_Start>OFF</Warm_Start> </SystemTrigger> <MaxCounterValue></MaxCounterValue> <Interval></Interval> <Timer_Cron></Timer_Cron> <AlarmEnable> <Mail_enable>OFF</Mail_enable> <SNMP_Trap_enable>OFF</SNMP_Trap_enable> <UDP_Client_enable>OFF</UDP_Client_enable> <Send_special_alarm_to_pending_TCP_connections>OFF</Send_special_alarm_to_pending_TCP_connections> <TCP_Client_enable>OFF</TCP_Client_enable> <Syslog_Messages_enable>OFF</Syslog_Messages_enable> <FTP_Client_enable>OFF</FTP_Client_enable> </AlarmEnable> <Mail> <E-Mail-Addr></E-Mail-Addr> <Subject></Subject> <Mailtext></Mailtext> <Alarm_clear_subject></Alarm_clear_subject> <Alarm_clear_text></Alarm_clear_text> </Mail> <SNMP> <Manager_IP></Manager_IP> <TrapText></TrapText> <Alarm_clear_text></Alarm_clear_text> </SNMP> <UDP> <IP_Addr></IP_Addr> <Port></Port> <UdpText></UdpText> <Alarm_clear_text></Alarm_clear_text> </UDP> <TCP> <IP_Addr></IP_Addr> <Port></Port> <TcpText></TcpText> <Alarm_clear_text></Alarm_clear_text> </TCP> <Syslog> <IP_Addr></IP_Addr> <Port>514</Port> <SyslogText></SyslogText> <Alarm_clear_text></Alarm_clear_text> </Syslog> <FTP> <FtpLocalDataPort>AUTO</FtpLocalDataPort> <FileName></FileName> <FtpAlarmText></FtpAlarmText> <Alarm_clear_text></Alarm_clear_text> <Options> <STORE>OFF</STORE> <APPEND>ON</APPEND> </Options> </FTP> </Alarm4> <Alarm5> <InputTrigger> <Input_0><enable>OFF</enable><state>OFF</state></Input_0> <Input_1><enable>OFF</enable><state>OFF</state></Input_1> <Input_2><enable>OFF</enable><state>OFF</state></Input_2> <Input_3><enable>OFF</enable><state>OFF</state></Input_3> <Input_4><enable>OFF</enable><state>OFF</state></Input_4> <Input_5><enable>OFF</enable><state>OFF</state></Input_5> <Input_6><enable>OFF</enable><state>OFF</state></Input_6> <Input_7><enable>OFF</enable><state>OFF</state></Input_7> <Input_8><enable>OFF</enable><state>OFF</state></Input_8> <Input_9><enable>OFF</enable><state>OFF</state></Input_9> <Input_10><enable>OFF</enable><state>OFF</state></Input_10> <Input_11><enable>OFF</enable><state>OFF</state></Input_11> </InputTrigger> <OutputTrigger> <Output_0><enable>OFF</enable><state>OFF</state></Output_0> <Output_1><enable>OFF</enable><state>OFF</state></Output_1> <Output_2><enable>OFF</enable><state>OFF</state></Output_2> <Output_3><enable>OFF</enable><state>OFF</state></Output_3> <Output_4><enable>OFF</enable><state>OFF</state></Output_4> <Output_5><enable>OFF</enable><state>OFF</state></Output_5> <Output_6><enable>OFF</enable><state>OFF</state></Output_6> <Output_7><enable>OFF</enable><state>OFF</state></Output_7> <Output_8><enable>OFF</enable><state>OFF</state></Output_8> <Output_9><enable>OFF</enable><state>OFF</state></Output_9> <Output_10><enable>OFF</enable><state>OFF</state></Output_10> <Output_11><enable>OFF</enable><state>OFF</state></Output_11> </OutputTrigger> <SystemTrigger> <Load_Control>OFF</Load_Control> <Interval_Timer>OFF</Interval_Timer> <Cold_Start>OFF</Cold_Start> <Warm_Start>OFF</Warm_Start> </SystemTrigger> <MaxCounterValue></MaxCounterValue> <Interval></Interval> <Timer_Cron></Timer_Cron> <AlarmEnable> <Mail_enable>OFF</Mail_enable> <SNMP_Trap_enable>OFF</SNMP_Trap_enable> <UDP_Client_enable>OFF</UDP_Client_enable> <Send_special_alarm_to_pending_TCP_connections>OFF</Send_special_alarm_to_pending_TCP_connections> <TCP_Client_enable>OFF</TCP_Client_enable> <Syslog_Messages_enable>OFF</Syslog_Messages_enable> <FTP_Client_enable>OFF</FTP_Client_enable> </AlarmEnable> <Mail> <E-Mail-Addr></E-Mail-Addr> <Subject></Subject> <Mailtext></Mailtext> <Alarm_clear_subject></Alarm_clear_subject> <Alarm_clear_text></Alarm_clear_text> </Mail> <SNMP> <Manager_IP></Manager_IP> <TrapText></TrapText> <Alarm_clear_text></Alarm_clear_text> </SNMP> <UDP> <IP_Addr></IP_Addr> <Port></Port> <UdpText></UdpText> <Alarm_clear_text></Alarm_clear_text> </UDP> <TCP> <IP_Addr></IP_Addr> <Port></Port> <TcpText></TcpText> <Alarm_clear_text></Alarm_clear_text> </TCP> <Syslog> <IP_Addr></IP_Addr> <Port>514</Port> <SyslogText></SyslogText> <Alarm_clear_text></Alarm_clear_text> </Syslog> <FTP> <FtpLocalDataPort>AUTO</FtpLocalDataPort> <FileName></FileName> <FtpAlarmText></FtpAlarmText> <Alarm_clear_text></Alarm_clear_text> <Options> <STORE>OFF</STORE> <APPEND>ON</APPEND> </Options> </FTP> </Alarm5> <Alarm6> <InputTrigger> <Input_0><enable>OFF</enable><state>OFF</state></Input_0> <Input_1><enable>OFF</enable><state>OFF</state></Input_1> <Input_2><enable>OFF</enable><state>OFF</state></Input_2> <Input_3><enable>OFF</enable><state>OFF</state></Input_3> <Input_4><enable>OFF</enable><state>OFF</state></Input_4> <Input_5><enable>OFF</enable><state>OFF</state></Input_5> <Input_6><enable>OFF</enable><state>OFF</state></Input_6> <Input_7><enable>OFF</enable><state>OFF</state></Input_7> <Input_8><enable>OFF</enable><state>OFF</state></Input_8> <Input_9><enable>OFF</enable><state>OFF</state></Input_9> <Input_10><enable>OFF</enable><state>OFF</state></Input_10> <Input_11><enable>OFF</enable><state>OFF</state></Input_11> </InputTrigger> <OutputTrigger> <Output_0><enable>OFF</enable><state>OFF</state></Output_0> <Output_1><enable>OFF</enable><state>OFF</state></Output_1> <Output_2><enable>OFF</enable><state>OFF</state></Output_2> <Output_3><enable>OFF</enable><state>OFF</state></Output_3> <Output_4><enable>OFF</enable><state>OFF</state></Output_4> <Output_5><enable>OFF</enable><state>OFF</state></Output_5> <Output_6><enable>OFF</enable><state>OFF</state></Output_6> <Output_7><enable>OFF</enable><state>OFF</state></Output_7> <Output_8><enable>OFF</enable><state>OFF</state></Output_8> <Output_9><enable>OFF</enable><state>OFF</state></Output_9> <Output_10><enable>OFF</enable><state>OFF</state></Output_10> <Output_11><enable>OFF</enable><state>OFF</state></Output_11> </OutputTrigger> <SystemTrigger> <Load_Control>OFF</Load_Control> <Interval_Timer>OFF</Interval_Timer> <Cold_Start>OFF</Cold_Start> <Warm_Start>OFF</Warm_Start> </SystemTrigger> <MaxCounterValue></MaxCounterValue> <Interval></Interval> <Timer_Cron></Timer_Cron> <AlarmEnable> <Mail_enable>OFF</Mail_enable> <SNMP_Trap_enable>OFF</SNMP_Trap_enable> <UDP_Client_enable>OFF</UDP_Client_enable> <Send_special_alarm_to_pending_TCP_connections>OFF</Send_special_alarm_to_pending_TCP_connections> <TCP_Client_enable>OFF</TCP_Client_enable> <Syslog_Messages_enable>OFF</Syslog_Messages_enable> <FTP_Client_enable>OFF</FTP_Client_enable> </AlarmEnable> <Mail> <E-Mail-Addr></E-Mail-Addr> <Subject></Subject> <Mailtext></Mailtext> <Alarm_clear_subject></Alarm_clear_subject> <Alarm_clear_text></Alarm_clear_text> </Mail> <SNMP> <Manager_IP></Manager_IP> <TrapText></TrapText> <Alarm_clear_text></Alarm_clear_text> </SNMP> <UDP> <IP_Addr></IP_Addr> <Port></Port> <UdpText></UdpText> <Alarm_clear_text></Alarm_clear_text> </UDP> <TCP> <IP_Addr></IP_Addr> <Port></Port> <TcpText></TcpText> <Alarm_clear_text></Alarm_clear_text> </TCP> <Syslog> <IP_Addr></IP_Addr> <Port>514</Port> <SyslogText></SyslogText> <Alarm_clear_text></Alarm_clear_text> </Syslog> <FTP> <FtpLocalDataPort>AUTO</FtpLocalDataPort> <FileName></FileName> <FtpAlarmText></FtpAlarmText> <Alarm_clear_text></Alarm_clear_text> <Options> <STORE>OFF</STORE> <APPEND>ON</APPEND> </Options> </FTP> </Alarm6> <Alarm7> <InputTrigger> <Input_0><enable>OFF</enable><state>OFF</state></Input_0> <Input_1><enable>OFF</enable><state>OFF</state></Input_1> <Input_2><enable>OFF</enable><state>OFF</state></Input_2> <Input_3><enable>OFF</enable><state>OFF</state></Input_3> <Input_4><enable>OFF</enable><state>OFF</state></Input_4> <Input_5><enable>OFF</enable><state>OFF</state></Input_5> <Input_6><enable>OFF</enable><state>OFF</state></Input_6> <Input_7><enable>OFF</enable><state>OFF</state></Input_7> <Input_8><enable>OFF</enable><state>OFF</state></Input_8> <Input_9><enable>OFF</enable><state>OFF</state></Input_9> <Input_10><enable>OFF</enable><state>OFF</state></Input_10> <Input_11><enable>OFF</enable><state>OFF</state></Input_11> </InputTrigger> <OutputTrigger> <Output_0><enable>OFF</enable><state>OFF</state></Output_0> <Output_1><enable>OFF</enable><state>OFF</state></Output_1> <Output_2><enable>OFF</enable><state>OFF</state></Output_2> <Output_3><enable>OFF</enable><state>OFF</state></Output_3> <Output_4><enable>OFF</enable><state>OFF</state></Output_4> <Output_5><enable>OFF</enable><state>OFF</state></Output_5> <Output_6><enable>OFF</enable><state>OFF</state></Output_6> <Output_7><enable>OFF</enable><state>OFF</state></Output_7> <Output_8><enable>OFF</enable><state>OFF</state></Output_8> <Output_9><enable>OFF</enable><state>OFF</state></Output_9> <Output_10><enable>OFF</enable><state>OFF</state></Output_10> <Output_11><enable>OFF</enable><state>OFF</state></Output_11> </OutputTrigger> <SystemTrigger> <Load_Control>OFF</Load_Control> <Interval_Timer>OFF</Interval_Timer> <Cold_Start>OFF</Cold_Start> <Warm_Start>OFF</Warm_Start> </SystemTrigger> <MaxCounterValue></MaxCounterValue> <Interval></Interval> <Timer_Cron></Timer_Cron> <AlarmEnable> <Mail_enable>OFF</Mail_enable> <SNMP_Trap_enable>OFF</SNMP_Trap_enable> <UDP_Client_enable>OFF</UDP_Client_enable> <Send_special_alarm_to_pending_TCP_connections>OFF</Send_special_alarm_to_pending_TCP_connections> <TCP_Client_enable>OFF</TCP_Client_enable> <Syslog_Messages_enable>OFF</Syslog_Messages_enable> <FTP_Client_enable>OFF</FTP_Client_enable> </AlarmEnable> <Mail> <E-Mail-Addr></E-Mail-Addr> <Subject></Subject> <Mailtext></Mailtext> <Alarm_clear_subject></Alarm_clear_subject> <Alarm_clear_text></Alarm_clear_text> </Mail> <SNMP> <Manager_IP></Manager_IP> <TrapText></TrapText> <Alarm_clear_text></Alarm_clear_text> </SNMP> <UDP> <IP_Addr></IP_Addr> <Port></Port> <UdpText></UdpText> <Alarm_clear_text></Alarm_clear_text> </UDP> <TCP> <IP_Addr></IP_Addr> <Port></Port> <TcpText></TcpText> <Alarm_clear_text></Alarm_clear_text> </TCP> <Syslog> <IP_Addr></IP_Addr> <Port>514</Port> <SyslogText></SyslogText> <Alarm_clear_text></Alarm_clear_text> </Syslog> <FTP> <FtpLocalDataPort>AUTO</FtpLocalDataPort> <FileName></FileName> <FtpAlarmText></FtpAlarmText> <Alarm_clear_text></Alarm_clear_text> <Options> <STORE>OFF</STORE> <APPEND>ON</APPEND> </Options> </FTP> </Alarm7> <Alarm8> <InputTrigger> <Input_0><enable>OFF</enable><state>OFF</state></Input_0> <Input_1><enable>OFF</enable><state>OFF</state></Input_1> <Input_2><enable>OFF</enable><state>OFF</state></Input_2> <Input_3><enable>OFF</enable><state>OFF</state></Input_3> <Input_4><enable>OFF</enable><state>OFF</state></Input_4> <Input_5><enable>OFF</enable><state>OFF</state></Input_5> <Input_6><enable>OFF</enable><state>OFF</state></Input_6> <Input_7><enable>OFF</enable><state>OFF</state></Input_7> <Input_8><enable>OFF</enable><state>OFF</state></Input_8> <Input_9><enable>OFF</enable><state>OFF</state></Input_9> <Input_10><enable>OFF</enable><state>OFF</state></Input_10> <Input_11><enable>OFF</enable><state>OFF</state></Input_11> </InputTrigger> <OutputTrigger> <Output_0><enable>OFF</enable><state>OFF</state></Output_0> <Output_1><enable>OFF</enable><state>OFF</state></Output_1> <Output_2><enable>OFF</enable><state>OFF</state></Output_2> <Output_3><enable>OFF</enable><state>OFF</state></Output_3> <Output_4><enable>OFF</enable><state>OFF</state></Output_4> <Output_5><enable>OFF</enable><state>OFF</state></Output_5> <Output_6><enable>OFF</enable><state>OFF</state></Output_6> <Output_7><enable>OFF</enable><state>OFF</state></Output_7> <Output_8><enable>OFF</enable><state>OFF</state></Output_8> <Output_9><enable>OFF</enable><state>OFF</state></Output_9> <Output_10><enable>OFF</enable><state>OFF</state></Output_10> <Output_11><enable>OFF</enable><state>OFF</state></Output_11> </OutputTrigger> <SystemTrigger> <Load_Control>OFF</Load_Control> <Interval_Timer>OFF</Interval_Timer> <Cold_Start>OFF</Cold_Start> <Warm_Start>OFF</Warm_Start> </SystemTrigger> <MaxCounterValue></MaxCounterValue> <Interval></Interval> <Timer_Cron></Timer_Cron> <AlarmEnable> <Mail_enable>OFF</Mail_enable> <SNMP_Trap_enable>OFF</SNMP_Trap_enable> <UDP_Client_enable>OFF</UDP_Client_enable> <Send_special_alarm_to_pending_TCP_connections>OFF</Send_special_alarm_to_pending_TCP_connections> <TCP_Client_enable>OFF</TCP_Client_enable> <Syslog_Messages_enable>OFF</Syslog_Messages_enable> <FTP_Client_enable>OFF</FTP_Client_enable> </AlarmEnable> <Mail> <E-Mail-Addr></E-Mail-Addr> <Subject></Subject> <Mailtext></Mailtext> <Alarm_clear_subject></Alarm_clear_subject> <Alarm_clear_text></Alarm_clear_text> </Mail> <SNMP> <Manager_IP></Manager_IP> <TrapText></TrapText> <Alarm_clear_text></Alarm_clear_text> </SNMP> <UDP> <IP_Addr></IP_Addr> <Port></Port> <UdpText></UdpText> <Alarm_clear_text></Alarm_clear_text> </UDP> <TCP> <IP_Addr></IP_Addr> <Port></Port> <TcpText></TcpText> <Alarm_clear_text></Alarm_clear_text> </TCP> <Syslog> <IP_Addr></IP_Addr> <Port>514</Port> <SyslogText></SyslogText> <Alarm_clear_text></Alarm_clear_text> </Syslog> <FTP> <FtpLocalDataPort>AUTO</FtpLocalDataPort> <FileName></FileName> <FtpAlarmText></FtpAlarmText> <Alarm_clear_text></Alarm_clear_text> <Options> <STORE>OFF</STORE> <APPEND>ON</APPEND> </Options> </FTP> </Alarm8> <Alarm9> <InputTrigger> <Input_0><enable>OFF</enable><state>OFF</state></Input_0> <Input_1><enable>OFF</enable><state>OFF</state></Input_1> <Input_2><enable>OFF</enable><state>OFF</state></Input_2> <Input_3><enable>OFF</enable><state>OFF</state></Input_3> <Input_4><enable>OFF</enable><state>OFF</state></Input_4> <Input_5><enable>OFF</enable><state>OFF</state></Input_5> <Input_6><enable>OFF</enable><state>OFF</state></Input_6> <Input_7><enable>OFF</enable><state>OFF</state></Input_7> <Input_8><enable>OFF</enable><state>OFF</state></Input_8> <Input_9><enable>OFF</enable><state>OFF</state></Input_9> <Input_10><enable>OFF</enable><state>OFF</state></Input_10> <Input_11><enable>OFF</enable><state>OFF</state></Input_11> </InputTrigger> <OutputTrigger> <Output_0><enable>OFF</enable><state>OFF</state></Output_0> <Output_1><enable>OFF</enable><state>OFF</state></Output_1> <Output_2><enable>OFF</enable><state>OFF</state></Output_2> <Output_3><enable>OFF</enable><state>OFF</state></Output_3> <Output_4><enable>OFF</enable><state>OFF</state></Output_4> <Output_5><enable>OFF</enable><state>OFF</state></Output_5> <Output_6><enable>OFF</enable><state>OFF</state></Output_6> <Output_7><enable>OFF</enable><state>OFF</state></Output_7> <Output_8><enable>OFF</enable><state>OFF</state></Output_8> <Output_9><enable>OFF</enable><state>OFF</state></Output_9> <Output_10><enable>OFF</enable><state>OFF</state></Output_10> <Output_11><enable>OFF</enable><state>OFF</state></Output_11> </OutputTrigger> <SystemTrigger> <Load_Control>OFF</Load_Control> <Interval_Timer>OFF</Interval_Timer> <Cold_Start>OFF</Cold_Start> <Warm_Start>OFF</Warm_Start> </SystemTrigger> <MaxCounterValue></MaxCounterValue> <Interval></Interval> <Timer_Cron></Timer_Cron> <AlarmEnable> <Mail_enable>OFF</Mail_enable> <SNMP_Trap_enable>OFF</SNMP_Trap_enable> <UDP_Client_enable>OFF</UDP_Client_enable> <Send_special_alarm_to_pending_TCP_connections>OFF</Send_special_alarm_to_pending_TCP_connections> <TCP_Client_enable>OFF</TCP_Client_enable> <Syslog_Messages_enable>OFF</Syslog_Messages_enable> <FTP_Client_enable>OFF</FTP_Client_enable> </AlarmEnable> <Mail> <E-Mail-Addr></E-Mail-Addr> <Subject></Subject> <Mailtext></Mailtext> <Alarm_clear_subject></Alarm_clear_subject> <Alarm_clear_text></Alarm_clear_text> </Mail> <SNMP> <Manager_IP></Manager_IP> <TrapText></TrapText> <Alarm_clear_text></Alarm_clear_text> </SNMP> <UDP> <IP_Addr></IP_Addr> <Port></Port> <UdpText></UdpText> <Alarm_clear_text></Alarm_clear_text> </UDP> <TCP> <IP_Addr></IP_Addr> <Port></Port> <TcpText></TcpText> <Alarm_clear_text></Alarm_clear_text> </TCP> <Syslog> <IP_Addr></IP_Addr> <Port>514</Port> <SyslogText></SyslogText> <Alarm_clear_text></Alarm_clear_text> </Syslog> <FTP> <FtpLocalDataPort>AUTO</FtpLocalDataPort> <FileName></FileName> <FtpAlarmText></FtpAlarmText> <Alarm_clear_text></Alarm_clear_text> <Options> <STORE>OFF</STORE> <APPEND>ON</APPEND> </Options> </FTP> </Alarm9> <Alarm10> <InputTrigger> <Input_0><enable>OFF</enable><state>OFF</state></Input_0> <Input_1><enable>OFF</enable><state>OFF</state></Input_1> <Input_2><enable>OFF</enable><state>OFF</state></Input_2> <Input_3><enable>OFF</enable><state>OFF</state></Input_3> <Input_4><enable>OFF</enable><state>OFF</state></Input_4> <Input_5><enable>OFF</enable><state>OFF</state></Input_5> <Input_6><enable>OFF</enable><state>OFF</state></Input_6> <Input_7><enable>OFF</enable><state>OFF</state></Input_7> <Input_8><enable>OFF</enable><state>OFF</state></Input_8> <Input_9><enable>OFF</enable><state>OFF</state></Input_9> <Input_10><enable>OFF</enable><state>OFF</state></Input_10> <Input_11><enable>OFF</enable><state>OFF</state></Input_11> </InputTrigger> <OutputTrigger> <Output_0><enable>OFF</enable><state>OFF</state></Output_0> <Output_1><enable>OFF</enable><state>OFF</state></Output_1> <Output_2><enable>OFF</enable><state>OFF</state></Output_2> <Output_3><enable>OFF</enable><state>OFF</state></Output_3> <Output_4><enable>OFF</enable><state>OFF</state></Output_4> <Output_5><enable>OFF</enable><state>OFF</state></Output_5> <Output_6><enable>OFF</enable><state>OFF</state></Output_6> <Output_7><enable>OFF</enable><state>OFF</state></Output_7> <Output_8><enable>OFF</enable><state>OFF</state></Output_8> <Output_9><enable>OFF</enable><state>OFF</state></Output_9> <Output_10><enable>OFF</enable><state>OFF</state></Output_10> <Output_11><enable>OFF</enable><state>OFF</state></Output_11> </OutputTrigger> <SystemTrigger> <Load_Control>OFF</Load_Control> <Interval_Timer>OFF</Interval_Timer> <Cold_Start>OFF</Cold_Start> <Warm_Start>OFF</Warm_Start> </SystemTrigger> <MaxCounterValue></MaxCounterValue> <Interval></Interval> <Timer_Cron></Timer_Cron> <AlarmEnable> <Mail_enable>OFF</Mail_enable> <SNMP_Trap_enable>OFF</SNMP_Trap_enable> <UDP_Client_enable>OFF</UDP_Client_enable> <Send_special_alarm_to_pending_TCP_connections>OFF</Send_special_alarm_to_pending_TCP_connections> <TCP_Client_enable>OFF</TCP_Client_enable> <Syslog_Messages_enable>OFF</Syslog_Messages_enable> <FTP_Client_enable>OFF</FTP_Client_enable> </AlarmEnable> <Mail> <E-Mail-Addr></E-Mail-Addr> <Subject></Subject> <Mailtext></Mailtext> <Alarm_clear_subject></Alarm_clear_subject> <Alarm_clear_text></Alarm_clear_text> </Mail> <SNMP> <Manager_IP></Manager_IP> <TrapText></TrapText> <Alarm_clear_text></Alarm_clear_text> </SNMP> <UDP> <IP_Addr></IP_Addr> <Port></Port> <UdpText></UdpText> <Alarm_clear_text></Alarm_clear_text> </UDP> <TCP> <IP_Addr></IP_Addr> <Port></Port> <TcpText></TcpText> <Alarm_clear_text></Alarm_clear_text> </TCP> <Syslog> <IP_Addr></IP_Addr> <Port>514</Port> <SyslogText></SyslogText> <Alarm_clear_text></Alarm_clear_text> </Syslog> <FTP> <FtpLocalDataPort>AUTO</FtpLocalDataPort> <FileName></FileName> <FtpAlarmText></FtpAlarmText> <Alarm_clear_text></Alarm_clear_text> <Options> <STORE>OFF</STORE> <APPEND>ON</APPEND> </Options> </FTP> </Alarm10> <Alarm11> <InputTrigger> <Input_0><enable>OFF</enable><state>OFF</state></Input_0> <Input_1><enable>OFF</enable><state>OFF</state></Input_1> <Input_2><enable>OFF</enable><state>OFF</state></Input_2> <Input_3><enable>OFF</enable><state>OFF</state></Input_3> <Input_4><enable>OFF</enable><state>OFF</state></Input_4> <Input_5><enable>OFF</enable><state>OFF</state></Input_5> <Input_6><enable>OFF</enable><state>OFF</state></Input_6> <Input_7><enable>OFF</enable><state>OFF</state></Input_7> <Input_8><enable>OFF</enable><state>OFF</state></Input_8> <Input_9><enable>OFF</enable><state>OFF</state></Input_9> <Input_10><enable>OFF</enable><state>OFF</state></Input_10> <Input_11><enable>OFF</enable><state>OFF</state></Input_11> </InputTrigger> <OutputTrigger> <Output_0><enable>OFF</enable><state>OFF</state></Output_0> <Output_1><enable>OFF</enable><state>OFF</state></Output_1> <Output_2><enable>OFF</enable><state>OFF</state></Output_2> <Output_3><enable>OFF</enable><state>OFF</state></Output_3> <Output_4><enable>OFF</enable><state>OFF</state></Output_4> <Output_5><enable>OFF</enable><state>OFF</state></Output_5> <Output_6><enable>OFF</enable><state>OFF</state></Output_6> <Output_7><enable>OFF</enable><state>OFF</state></Output_7> <Output_8><enable>OFF</enable><state>OFF</state></Output_8> <Output_9><enable>OFF</enable><state>OFF</state></Output_9> <Output_10><enable>OFF</enable><state>OFF</state></Output_10> <Output_11><enable>OFF</enable><state>OFF</state></Output_11> </OutputTrigger> <SystemTrigger> <Load_Control>OFF</Load_Control> <Interval_Timer>OFF</Interval_Timer> <Cold_Start>OFF</Cold_Start> <Warm_Start>OFF</Warm_Start> </SystemTrigger> <MaxCounterValue></MaxCounterValue> <Interval></Interval> <Timer_Cron></Timer_Cron> <AlarmEnable> <Mail_enable>OFF</Mail_enable> <SNMP_Trap_enable>OFF</SNMP_Trap_enable> <UDP_Client_enable>OFF</UDP_Client_enable> <Send_special_alarm_to_pending_TCP_connections>OFF</Send_special_alarm_to_pending_TCP_connections> <TCP_Client_enable>OFF</TCP_Client_enable> <Syslog_Messages_enable>OFF</Syslog_Messages_enable> <FTP_Client_enable>OFF</FTP_Client_enable> </AlarmEnable> <Mail> <E-Mail-Addr></E-Mail-Addr> <Subject></Subject> <Mailtext></Mailtext> <Alarm_clear_subject></Alarm_clear_subject> <Alarm_clear_text></Alarm_clear_text> </Mail> <SNMP> <Manager_IP></Manager_IP> <TrapText></TrapText> <Alarm_clear_text></Alarm_clear_text> </SNMP> <UDP> <IP_Addr></IP_Addr> <Port></Port> <UdpText></UdpText> <Alarm_clear_text></Alarm_clear_text> </UDP> <TCP> <IP_Addr></IP_Addr> <Port></Port> <TcpText></TcpText> <Alarm_clear_text></Alarm_clear_text> </TCP> <Syslog> <IP_Addr></IP_Addr> <Port>514</Port> <SyslogText></SyslogText> <Alarm_clear_text></Alarm_clear_text> </Syslog> <FTP> <FtpLocalDataPort>AUTO</FtpLocalDataPort> <FileName></FileName> <FtpAlarmText></FtpAlarmText> <Alarm_clear_text></Alarm_clear_text> <Options> <STORE>OFF</STORE> <APPEND>ON</APPEND> </Options> </FTP> </Alarm11> <Alarm12> <InputTrigger> <Input_0><enable>OFF</enable><state>OFF</state></Input_0> <Input_1><enable>OFF</enable><state>OFF</state></Input_1> <Input_2><enable>OFF</enable><state>OFF</state></Input_2> <Input_3><enable>OFF</enable><state>OFF</state></Input_3> <Input_4><enable>OFF</enable><state>OFF</state></Input_4> <Input_5><enable>OFF</enable><state>OFF</state></Input_5> <Input_6><enable>OFF</enable><state>OFF</state></Input_6> <Input_7><enable>OFF</enable><state>OFF</state></Input_7> <Input_8><enable>OFF</enable><state>OFF</state></Input_8> <Input_9><enable>OFF</enable><state>OFF</state></Input_9> <Input_10><enable>OFF</enable><state>OFF</state></Input_10> <Input_11><enable>OFF</enable><state>OFF</state></Input_11> </InputTrigger> <OutputTrigger> <Output_0><enable>OFF</enable><state>OFF</state></Output_0> <Output_1><enable>OFF</enable><state>OFF</state></Output_1> <Output_2><enable>OFF</enable><state>OFF</state></Output_2> <Output_3><enable>OFF</enable><state>OFF</state></Output_3> <Output_4><enable>OFF</enable><state>OFF</state></Output_4> <Output_5><enable>OFF</enable><state>OFF</state></Output_5> <Output_6><enable>OFF</enable><state>OFF</state></Output_6> <Output_7><enable>OFF</enable><state>OFF</state></Output_7> <Output_8><enable>OFF</enable><state>OFF</state></Output_8> <Output_9><enable>OFF</enable><state>OFF</state></Output_9> <Output_10><enable>OFF</enable><state>OFF</state></Output_10> <Output_11><enable>OFF</enable><state>OFF</state></Output_11> </OutputTrigger> <SystemTrigger> <Load_Control>OFF</Load_Control> <Interval_Timer>OFF</Interval_Timer> <Cold_Start>OFF</Cold_Start> <Warm_Start>OFF</Warm_Start> </SystemTrigger> <MaxCounterValue></MaxCounterValue> <Interval></Interval> <Timer_Cron></Timer_Cron> <AlarmEnable> <Mail_enable>OFF</Mail_enable> <SNMP_Trap_enable>OFF</SNMP_Trap_enable> <UDP_Client_enable>OFF</UDP_Client_enable> <Send_special_alarm_to_pending_TCP_connections>OFF</Send_special_alarm_to_pending_TCP_connections> <TCP_Client_enable>OFF</TCP_Client_enable> <Syslog_Messages_enable>OFF</Syslog_Messages_enable> <FTP_Client_enable>OFF</FTP_Client_enable> </AlarmEnable> <Mail> <E-Mail-Addr></E-Mail-Addr> <Subject></Subject> <Mailtext></Mailtext> <Alarm_clear_subject></Alarm_clear_subject> <Alarm_clear_text></Alarm_clear_text> </Mail> <SNMP> <Manager_IP></Manager_IP> <TrapText></TrapText> <Alarm_clear_text></Alarm_clear_text> </SNMP> <UDP> <IP_Addr></IP_Addr> <Port></Port> <UdpText></UdpText> <Alarm_clear_text></Alarm_clear_text> </UDP> <TCP> <IP_Addr></IP_Addr> <Port></Port> <TcpText></TcpText> <Alarm_clear_text></Alarm_clear_text> </TCP> <Syslog> <IP_Addr></IP_Addr> <Port>514</Port> <SyslogText></SyslogText> <Alarm_clear_text></Alarm_clear_text> </Syslog> <FTP> <FtpLocalDataPort>AUTO</FtpLocalDataPort> <FileName></FileName> <FtpAlarmText></FtpAlarmText> <Alarm_clear_text></Alarm_clear_text> <Options> <STORE>OFF</STORE> <APPEND>ON</APPEND> </Options> </FTP> </Alarm12> </Alarm> </Device> <Ports> <Inputs> <Input0> <Name>Input 0</Name> <Text>Description Input 0</Text> <Filter></Filter> <InputMode> <Short_Pulse_detection_enable>OFF</Short_Pulse_detection_enable> <Change_detection_enable>OFF</Change_detection_enable> <Clear_counter_on_read>OFF</Clear_counter_on_read> <Bidirectional_counter_enable>OFF</Bidirectional_counter_enable> </InputMode> <Counter_Mode> <PulsPolarity> <negative>OFF</negative> <positive>ON</positive> </PulsPolarity> <InactiveTimeout>1</InactiveTimeout> </Counter_Mode> </Input0> <Input1> <Name>Input 1</Name> <Text>Description Input 1</Text> <Filter></Filter> <InputMode> <Short_Pulse_detection_enable>OFF</Short_Pulse_detection_enable> <Change_detection_enable>OFF</Change_detection_enable> <Clear_counter_on_read>OFF</Clear_counter_on_read> <Bidirectional_counter_enable>OFF</Bidirectional_counter_enable> </InputMode> <Counter_Mode> <PulsPolarity> <negative>OFF</negative> <positive>ON</positive> </PulsPolarity> <InactiveTimeout>1</InactiveTimeout> </Counter_Mode> </Input1> <Input2> <Name>Input 2</Name> <Text>Description Input 2</Text> <Filter></Filter> <InputMode> <Short_Pulse_detection_enable>OFF</Short_Pulse_detection_enable> <Change_detection_enable>OFF</Change_detection_enable> <Clear_counter_on_read>OFF</Clear_counter_on_read> <Bidirectional_counter_enable>OFF</Bidirectional_counter_enable> </InputMode> <Counter_Mode> <PulsPolarity> <negative>OFF</negative> <positive>OFF</positive> </PulsPolarity> <InactiveTimeout></InactiveTimeout> </Counter_Mode> </Input2> <Input3> <Name>Input 3</Name> <Text>Description Input 3</Text> <Filter></Filter> <InputMode> <Short_Pulse_detection_enable>OFF</Short_Pulse_detection_enable> <Change_detection_enable>OFF</Change_detection_enable> <Clear_counter_on_read>OFF</Clear_counter_on_read> <Bidirectional_counter_enable>OFF</Bidirectional_counter_enable> </InputMode> <Counter_Mode> <PulsPolarity> <negative>OFF</negative> <positive>OFF</positive> </PulsPolarity> <InactiveTimeout></InactiveTimeout> </Counter_Mode> </Input3> <Input4> <Name>Input 4</Name> <Text>Description Input 4</Text> <Filter></Filter> <InputMode> <Change_detection_enable>OFF</Change_detection_enable> <Clear_counter_on_read>OFF</Clear_counter_on_read> <Bidirectional_counter_enable>OFF</Bidirectional_counter_enable> </InputMode> <Counter_Mode> <PulsPolarity> <negative>OFF</negative> <positive>OFF</positive> </PulsPolarity> <InactiveTimeout></InactiveTimeout> </Counter_Mode> </Input4> <Input5> <Name>Input 5</Name> <Text>Description Input 5</Text> <Filter></Filter> <InputMode> <Change_detection_enable>OFF</Change_detection_enable> <Clear_counter_on_read>OFF</Clear_counter_on_read> <Bidirectional_counter_enable>OFF</Bidirectional_counter_enable> </InputMode> <Counter_Mode> <PulsPolarity> <negative>OFF</negative> <positive>OFF</positive> </PulsPolarity> <InactiveTimeout></InactiveTimeout> </Counter_Mode> </Input5> <Input6> <Name>Input 6</Name> <Text>Description Input 6</Text> <Filter></Filter> <InputMode> <Change_detection_enable>OFF</Change_detection_enable> <Clear_counter_on_read>OFF</Clear_counter_on_read> <Bidirectional_counter_enable>OFF</Bidirectional_counter_enable> </InputMode> <Counter_Mode> <PulsPolarity> <negative>OFF</negative> <positive>OFF</positive> </PulsPolarity> <InactiveTimeout></InactiveTimeout> </Counter_Mode> </Input6> <Input7> <Name>Input 7</Name> <Text>Description Input 7</Text> <Filter></Filter> <InputMode> <Change_detection_enable>OFF</Change_detection_enable> <Clear_counter_on_read>OFF</Clear_counter_on_read> <Bidirectional_counter_enable>OFF</Bidirectional_counter_enable> </InputMode> <Counter_Mode> <PulsPolarity> <negative>OFF</negative> <positive>OFF</positive> </PulsPolarity> <InactiveTimeout></InactiveTimeout> </Counter_Mode> </Input7> <Input8> <Name>Input 8</Name> <Text>Description Input 8</Text> <Filter></Filter> <InputMode> <Change_detection_enable>OFF</Change_detection_enable> <Clear_counter_on_read>OFF</Clear_counter_on_read> <Bidirectional_counter_enable>OFF</Bidirectional_counter_enable> </InputMode> <Counter_Mode> <PulsPolarity> <negative>OFF</negative> <positive>OFF</positive> </PulsPolarity> <InactiveTimeout></InactiveTimeout> </Counter_Mode> </Input8> <Input9> <Name>Input 9</Name> <Text>Description Input 9</Text> <Filter></Filter> <InputMode> <Change_detection_enable>OFF</Change_detection_enable> <Clear_counter_on_read>OFF</Clear_counter_on_read> <Bidirectional_counter_enable>OFF</Bidirectional_counter_enable> </InputMode> <Counter_Mode> <PulsPolarity> <negative>OFF</negative> <positive>OFF</positive> </PulsPolarity> <InactiveTimeout></InactiveTimeout> </Counter_Mode> </Input9> <Input10> <Name>Input 10</Name> <Text>Description Input 10</Text> <Filter></Filter> <InputMode> <Change_detection_enable>OFF</Change_detection_enable> <Clear_counter_on_read>OFF</Clear_counter_on_read> <Bidirectional_counter_enable>OFF</Bidirectional_counter_enable> </InputMode> <Counter_Mode> <PulsPolarity> <negative>OFF</negative> <positive>OFF</positive> </PulsPolarity> <InactiveTimeout></InactiveTimeout> </Counter_Mode> </Input10> <Input11> <Name>Input 11</Name> <Text>Description Input 11</Text> <Filter></Filter> <InputMode> <Change_detection_enable>OFF</Change_detection_enable> <Clear_counter_on_read>OFF</Clear_counter_on_read> <Bidirectional_counter_enable>OFF</Bidirectional_counter_enable> </InputMode> <Counter_Mode> <PulsPolarity> <negative>OFF</negative> <positive>OFF</positive> </PulsPolarity> <InactiveTimeout></InactiveTimeout> </Counter_Mode> </Input11> </Inputs> <Outputs> <Output0> <Name>Output 0</Name> <Text>Description Output 0</Text> <GroupMode> <_0_1_2_3_separated>ON</_0_1_2_3_separated> <_0--1_2--3_parallel>OFF</_0--1_2--3_parallel> <_0--1--2--3_parallel>OFF</_0--1--2--3_parallel> </GroupMode> <SafetyState> <Safety_enable><enable>OFF</enable><state>OFF</state></Safety_enable> </SafetyState> <Logic> <InputMask> <Input_0>OFF</Input_0> <Input_1>OFF</Input_1> <Input_2>OFF</Input_2> <Input_3>OFF</Input_3> <Input_4>OFF</Input_4> <Input_5>OFF</Input_5> <Input_6>OFF</Input_6> <Input_7>OFF</Input_7> <Input_8>OFF</Input_8> <Input_9>OFF</Input_9> <Input_10>OFF</Input_10> <Input_11>OFF</Input_11> </InputMask> <InputInverter> <Input_0>OFF</Input_0> <Input_1>OFF</Input_1> <Input_2>OFF</Input_2> <Input_3>OFF</Input_3> <Input_4>OFF</Input_4> <Input_5>OFF</Input_5> <Input_6>OFF</Input_6> <Input_7>OFF</Input_7> <Input_8>OFF</Input_8> <Input_9>OFF</Input_9> <Input_10>OFF</Input_10> <Input_11>OFF</Input_11> </InputInverter> <LogicFunc> <AND>ON</AND> <OR>OFF</OR> </LogicFunc> <OutputInverter> <Output_Inverter>OFF</Output_Inverter> </OutputInverter> </Logic> <Puls> <Duration>5000</Duration> <PulsPolarity> <negative>OFF</negative> <positive>ON</positive> </PulsPolarity> </Puls> </Output0> <Output1> <Name>Output 1</Name> <Text>Description Output 1</Text> <GroupMode> <_0_1_2_3_separated>ON</_0_1_2_3_separated> <_0--1_2--3_parallel>OFF</_0--1_2--3_parallel> <_0--1--2--3_parallel>OFF</_0--1--2--3_parallel> </GroupMode> <SafetyState> <Safety_enable><enable>OFF</enable><state>OFF</state></Safety_enable> </SafetyState> <Logic> <InputMask> <Input_0>OFF</Input_0> <Input_1>OFF</Input_1> <Input_2>OFF</Input_2> <Input_3>OFF</Input_3> <Input_4>OFF</Input_4> <Input_5>OFF</Input_5> <Input_6>OFF</Input_6> <Input_7>OFF</Input_7> <Input_8>OFF</Input_8> <Input_9>OFF</Input_9> <Input_10>OFF</Input_10> <Input_11>OFF</Input_11> </InputMask> <InputInverter> <Input_0>OFF</Input_0> <Input_1>OFF</Input_1> <Input_2>OFF</Input_2> <Input_3>OFF</Input_3> <Input_4>OFF</Input_4> <Input_5>OFF</Input_5> <Input_6>OFF</Input_6> <Input_7>OFF</Input_7> <Input_8>OFF</Input_8> <Input_9>OFF</Input_9> <Input_10>OFF</Input_10> <Input_11>OFF</Input_11> </InputInverter> <LogicFunc> <AND>ON</AND> <OR>OFF</OR> </LogicFunc> <OutputInverter> <Output_Inverter>OFF</Output_Inverter> </OutputInverter> </Logic> <Puls> <Duration>2000</Duration> <PulsPolarity> <negative>OFF</negative> <positive>ON</positive> </PulsPolarity> </Puls> </Output1> <Output2> <Name>Output 2</Name> <Text>Description Output 2</Text> <GroupMode> <_0_1_2_3_separated>ON</_0_1_2_3_separated> <_0--1_2--3_parallel>OFF</_0--1_2--3_parallel> <_0--1--2--3_parallel>OFF</_0--1--2--3_parallel> </GroupMode> <SafetyState> <Safety_enable><enable>OFF</enable><state>OFF</state></Safety_enable> </SafetyState> <Logic> <InputMask> <Input_0>OFF</Input_0> <Input_1>OFF</Input_1> <Input_2>OFF</Input_2> <Input_3>OFF</Input_3> <Input_4>OFF</Input_4> <Input_5>OFF</Input_5> <Input_6>OFF</Input_6> <Input_7>OFF</Input_7> <Input_8>OFF</Input_8> <Input_9>OFF</Input_9> <Input_10>OFF</Input_10> <Input_11>OFF</Input_11> </InputMask> <InputInverter> <Input_0>OFF</Input_0> <Input_1>OFF</Input_1> <Input_2>OFF</Input_2> <Input_3>OFF</Input_3> <Input_4>OFF</Input_4> <Input_5>OFF</Input_5> <Input_6>OFF</Input_6> <Input_7>OFF</Input_7> <Input_8>OFF</Input_8> <Input_9>OFF</Input_9> <Input_10>OFF</Input_10> <Input_11>OFF</Input_11> </InputInverter> <LogicFunc> <AND>ON</AND> <OR>OFF</OR> </LogicFunc> <OutputInverter> <Output_Inverter>OFF</Output_Inverter> </OutputInverter> </Logic> <Puls> <Duration>1000</Duration> <PulsPolarity> <negative>OFF</negative> <positive>ON</positive> </PulsPolarity> </Puls> </Output2> <Output3> <Name>Output 3</Name> <Text>Description Output 3</Text> <GroupMode> <_0_1_2_3_separated>ON</_0_1_2_3_separated> <_0--1_2--3_parallel>OFF</_0--1_2--3_parallel> <_0--1--2--3_parallel>OFF</_0--1--2--3_parallel> </GroupMode> <SafetyState> <Safety_enable><enable>OFF</enable><state>OFF</state></Safety_enable> </SafetyState> <Logic> <InputMask> <Input_0>OFF</Input_0> <Input_1>OFF</Input_1> <Input_2>OFF</Input_2> <Input_3>OFF</Input_3> <Input_4>OFF</Input_4> <Input_5>OFF</Input_5> <Input_6>OFF</Input_6> <Input_7>OFF</Input_7> <Input_8>OFF</Input_8> <Input_9>OFF</Input_9> <Input_10>OFF</Input_10> <Input_11>OFF</Input_11> </InputMask> <InputInverter> <Input_0>OFF</Input_0> <Input_1>OFF</Input_1> <Input_2>OFF</Input_2> <Input_3>OFF</Input_3> <Input_4>OFF</Input_4> <Input_5>OFF</Input_5> <Input_6>OFF</Input_6> <Input_7>OFF</Input_7> <Input_8>OFF</Input_8> <Input_9>OFF</Input_9> <Input_10>OFF</Input_10> <Input_11>OFF</Input_11> </InputInverter> <LogicFunc> <AND>ON</AND> <OR>OFF</OR> </LogicFunc> <OutputInverter> <Output_Inverter>OFF</Output_Inverter> </OutputInverter> </Logic> <Puls> <Duration>1000</Duration> <PulsPolarity> <negative>OFF</negative> <positive>ON</positive> </PulsPolarity> </Puls> </Output3> <Output4> <Name>Output 4</Name> <Text>Description Output 4</Text> <GroupMode> <_4_5_6_7_separated>ON</_4_5_6_7_separated> <_4--5_6--7_parallel>OFF</_4--5_6--7_parallel> <_4--5--6--7_parallel>OFF</_4--5--6--7_parallel> </GroupMode> <SafetyState> <Safety_enable><enable>OFF</enable><state>OFF</state></Safety_enable> </SafetyState> <Logic> <InputMask> <Input_0>OFF</Input_0> <Input_1>OFF</Input_1> <Input_2>OFF</Input_2> <Input_3>OFF</Input_3> <Input_4>OFF</Input_4> <Input_5>OFF</Input_5> <Input_6>OFF</Input_6> <Input_7>OFF</Input_7> <Input_8>OFF</Input_8> <Input_9>OFF</Input_9> <Input_10>OFF</Input_10> <Input_11>OFF</Input_11> </InputMask> <InputInverter> <Input_0>OFF</Input_0> <Input_1>OFF</Input_1> <Input_2>OFF</Input_2> <Input_3>OFF</Input_3> <Input_4>OFF</Input_4> <Input_5>OFF</Input_5> <Input_6>OFF</Input_6> <Input_7>OFF</Input_7> <Input_8>OFF</Input_8> <Input_9>OFF</Input_9> <Input_10>OFF</Input_10> <Input_11>OFF</Input_11> </InputInverter> <LogicFunc> <AND>ON</AND> <OR>OFF</OR> </LogicFunc> <OutputInverter> <Output_Inverter>OFF</Output_Inverter> </OutputInverter> </Logic> <Puls> <Duration></Duration> <PulsPolarity> <negative>OFF</negative> <positive>OFF</positive> </PulsPolarity> </Puls> </Output4> <Output5> <Name>Output 5</Name> <Text>Description Output 5</Text> <GroupMode> <_4_5_6_7_separated>ON</_4_5_6_7_separated> <_4--5_6--7_parallel>OFF</_4--5_6--7_parallel> <_4--5--6--7_parallel>OFF</_4--5--6--7_parallel> </GroupMode> <SafetyState> <Safety_enable><enable>OFF</enable><state>OFF</state></Safety_enable> </SafetyState> <Logic> <InputMask> <Input_0>OFF</Input_0> <Input_1>OFF</Input_1> <Input_2>OFF</Input_2> <Input_3>OFF</Input_3> <Input_4>OFF</Input_4> <Input_5>OFF</Input_5> <Input_6>OFF</Input_6> <Input_7>OFF</Input_7> <Input_8>OFF</Input_8> <Input_9>OFF</Input_9> <Input_10>OFF</Input_10> <Input_11>OFF</Input_11> </InputMask> <InputInverter> <Input_0>OFF</Input_0> <Input_1>OFF</Input_1> <Input_2>OFF</Input_2> <Input_3>OFF</Input_3> <Input_4>OFF</Input_4> <Input_5>OFF</Input_5> <Input_6>OFF</Input_6> <Input_7>OFF</Input_7> <Input_8>OFF</Input_8> <Input_9>OFF</Input_9> <Input_10>OFF</Input_10> <Input_11>OFF</Input_11> </InputInverter> <LogicFunc> <AND>ON</AND> <OR>OFF</OR> </LogicFunc> <OutputInverter> <Output_Inverter>OFF</Output_Inverter> </OutputInverter> </Logic> <Puls> <Duration></Duration> <PulsPolarity> <negative>OFF</negative> <positive>OFF</positive> </PulsPolarity> </Puls> </Output5> <Output6> <Name>Output 6</Name> <Text>Description Output 6</Text> <GroupMode> <_4_5_6_7_separated>ON</_4_5_6_7_separated> <_4--5_6--7_parallel>OFF</_4--5_6--7_parallel> <_4--5--6--7_parallel>OFF</_4--5--6--7_parallel> </GroupMode> <SafetyState> <Safety_enable><enable>OFF</enable><state>OFF</state></Safety_enable> </SafetyState> <Logic> <InputMask> <Input_0>OFF</Input_0> <Input_1>OFF</Input_1> <Input_2>OFF</Input_2> <Input_3>OFF</Input_3> <Input_4>OFF</Input_4> <Input_5>OFF</Input_5> <Input_6>OFF</Input_6> <Input_7>OFF</Input_7> <Input_8>OFF</Input_8> <Input_9>OFF</Input_9> <Input_10>OFF</Input_10> <Input_11>OFF</Input_11> </InputMask> <InputInverter> <Input_0>OFF</Input_0> <Input_1>OFF</Input_1> <Input_2>OFF</Input_2> <Input_3>OFF</Input_3> <Input_4>OFF</Input_4> <Input_5>OFF</Input_5> <Input_6>OFF</Input_6> <Input_7>OFF</Input_7> <Input_8>OFF</Input_8> <Input_9>OFF</Input_9> <Input_10>OFF</Input_10> <Input_11>OFF</Input_11> </InputInverter> <LogicFunc> <AND>ON</AND> <OR>OFF</OR> </LogicFunc> <OutputInverter> <Output_Inverter>OFF</Output_Inverter> </OutputInverter> </Logic> <Puls> <Duration></Duration> <PulsPolarity> <negative>OFF</negative> <positive>OFF</positive> </PulsPolarity> </Puls> </Output6> <Output7> <Name>Output 7</Name> <Text>Description Output 7</Text> <GroupMode> <_4_5_6_7_separated>ON</_4_5_6_7_separated> <_4--5_6--7_parallel>OFF</_4--5_6--7_parallel> <_4--5--6--7_parallel>OFF</_4--5--6--7_parallel> </GroupMode> <SafetyState> <Safety_enable><enable>OFF</enable><state>OFF</state></Safety_enable> </SafetyState> <Logic> <InputMask> <Input_0>OFF</Input_0> <Input_1>OFF</Input_1> <Input_2>OFF</Input_2> <Input_3>OFF</Input_3> <Input_4>OFF</Input_4> <Input_5>OFF</Input_5> <Input_6>OFF</Input_6> <Input_7>OFF</Input_7> <Input_8>OFF</Input_8> <Input_9>OFF</Input_9> <Input_10>OFF</Input_10> <Input_11>OFF</Input_11> </InputMask> <InputInverter> <Input_0>OFF</Input_0> <Input_1>OFF</Input_1> <Input_2>OFF</Input_2> <Input_3>OFF</Input_3> <Input_4>OFF</Input_4> <Input_5>OFF</Input_5> <Input_6>OFF</Input_6> <Input_7>OFF</Input_7> <Input_8>OFF</Input_8> <Input_9>OFF</Input_9> <Input_10>OFF</Input_10> <Input_11>OFF</Input_11> </InputInverter> <LogicFunc> <AND>ON</AND> <OR>OFF</OR> </LogicFunc> <OutputInverter> <Output_Inverter>OFF</Output_Inverter> </OutputInverter> </Logic> <Puls> <Duration></Duration> <PulsPolarity> <negative>OFF</negative> <positive>OFF</positive> </PulsPolarity> </Puls> </Output7> <Output8> <Name>Output 8</Name> <Text>Description Output 8</Text> <GroupMode> <_8_9_10_11_separated>ON</_8_9_10_11_separated> <_8--9_10--11_parallel>OFF</_8--9_10--11_parallel> <_8--9--10--11_parallel>OFF</_8--9--10--11_parallel> </GroupMode> <SafetyState> <Safety_enable><enable>OFF</enable><state>OFF</state></Safety_enable> </SafetyState> <Logic> <InputMask> <Input_0>OFF</Input_0> <Input_1>OFF</Input_1> <Input_2>OFF</Input_2> <Input_3>OFF</Input_3> <Input_4>OFF</Input_4> <Input_5>OFF</Input_5> <Input_6>OFF</Input_6> <Input_7>OFF</Input_7> <Input_8>OFF</Input_8> <Input_9>OFF</Input_9> <Input_10>OFF</Input_10> <Input_11>OFF</Input_11> </InputMask> <InputInverter> <Input_0>OFF</Input_0> <Input_1>OFF</Input_1> <Input_2>OFF</Input_2> <Input_3>OFF</Input_3> <Input_4>OFF</Input_4> <Input_5>OFF</Input_5> <Input_6>OFF</Input_6> <Input_7>OFF</Input_7> <Input_8>OFF</Input_8> <Input_9>OFF</Input_9> <Input_10>OFF</Input_10> <Input_11>OFF</Input_11> </InputInverter> <LogicFunc> <AND>ON</AND> <OR>OFF</OR> </LogicFunc> <OutputInverter> <Output_Inverter>OFF</Output_Inverter> </OutputInverter> </Logic> <Puls> <Duration></Duration> <PulsPolarity> <negative>OFF</negative> <positive>OFF</positive> </PulsPolarity> </Puls> </Output8> <Output9> <Name>Output 9</Name> <Text>Description Output 9</Text> <GroupMode> <_8_9_10_11_separated>ON</_8_9_10_11_separated> <_8--9_10--11_parallel>OFF</_8--9_10--11_parallel> <_8--9--10--11_parallel>OFF</_8--9--10--11_parallel> </GroupMode> <SafetyState> <Safety_enable><enable>OFF</enable><state>OFF</state></Safety_enable> </SafetyState> <Logic> <InputMask> <Input_0>OFF</Input_0> <Input_1>OFF</Input_1> <Input_2>OFF</Input_2> <Input_3>OFF</Input_3> <Input_4>OFF</Input_4> <Input_5>OFF</Input_5> <Input_6>OFF</Input_6> <Input_7>OFF</Input_7> <Input_8>OFF</Input_8> <Input_9>OFF</Input_9> <Input_10>OFF</Input_10> <Input_11>OFF</Input_11> </InputMask> <InputInverter> <Input_0>OFF</Input_0> <Input_1>OFF</Input_1> <Input_2>OFF</Input_2> <Input_3>OFF</Input_3> <Input_4>OFF</Input_4> <Input_5>OFF</Input_5> <Input_6>OFF</Input_6> <Input_7>OFF</Input_7> <Input_8>OFF</Input_8> <Input_9>OFF</Input_9> <Input_10>OFF</Input_10> <Input_11>OFF</Input_11> </InputInverter> <LogicFunc> <AND>ON</AND> <OR>OFF</OR> </LogicFunc> <OutputInverter> <Output_Inverter>OFF</Output_Inverter> </OutputInverter> </Logic> <Puls> <Duration></Duration> <PulsPolarity> <negative>OFF</negative> <positive>OFF</positive> </PulsPolarity> </Puls> </Output9> <Output10> <Name>Output 10</Name> <Text>Description Output 10</Text> <GroupMode> <_8_9_10_11_separated>ON</_8_9_10_11_separated> <_8--9_10--11_parallel>OFF</_8--9_10--11_parallel> <_8--9--10--11_parallel>OFF</_8--9--10--11_parallel> </GroupMode> <SafetyState> <Safety_enable><enable>OFF</enable><state>OFF</state></Safety_enable> </SafetyState> <Logic> <InputMask> <Input_0>OFF</Input_0> <Input_1>OFF</Input_1> <Input_2>OFF</Input_2> <Input_3>OFF</Input_3> <Input_4>OFF</Input_4> <Input_5>OFF</Input_5> <Input_6>OFF</Input_6> <Input_7>OFF</Input_7> <Input_8>OFF</Input_8> <Input_9>OFF</Input_9> <Input_10>OFF</Input_10> <Input_11>OFF</Input_11> </InputMask> <InputInverter> <Input_0>OFF</Input_0> <Input_1>OFF</Input_1> <Input_2>OFF</Input_2> <Input_3>OFF</Input_3> <Input_4>OFF</Input_4> <Input_5>OFF</Input_5> <Input_6>OFF</Input_6> <Input_7>OFF</Input_7> <Input_8>OFF</Input_8> <Input_9>OFF</Input_9> <Input_10>OFF</Input_10> <Input_11>OFF</Input_11> </InputInverter> <LogicFunc> <AND>ON</AND> <OR>OFF</OR> </LogicFunc> <OutputInverter> <Output_Inverter>OFF</Output_Inverter> </OutputInverter> </Logic> <Puls> <Duration></Duration> <PulsPolarity> <negative>OFF</negative> <positive>OFF</positive> </PulsPolarity> </Puls> </Output10> <Output11> <Name>Output 11</Name> <Text>Description Output 11</Text> <GroupMode> <_8_9_10_11_separated>ON</_8_9_10_11_separated> <_8--9_10--11_parallel>OFF</_8--9_10--11_parallel> <_8--9--10--11_parallel>OFF</_8--9--10--11_parallel> </GroupMode> <SafetyState> <Safety_enable><enable>OFF</enable><state>OFF</state></Safety_enable> </SafetyState> <Logic> <InputMask> <Input_0>OFF</Input_0> <Input_1>OFF</Input_1> <Input_2>OFF</Input_2> <Input_3>OFF</Input_3> <Input_4>OFF</Input_4> <Input_5>OFF</Input_5> <Input_6>OFF</Input_6> <Input_7>OFF</Input_7> <Input_8>OFF</Input_8> <Input_9>OFF</Input_9> <Input_10>OFF</Input_10> <Input_11>OFF</Input_11> </InputMask> <InputInverter> <Input_0>OFF</Input_0> <Input_1>OFF</Input_1> <Input_2>OFF</Input_2> <Input_3>OFF</Input_3> <Input_4>OFF</Input_4> <Input_5>OFF</Input_5> <Input_6>OFF</Input_6> <Input_7>OFF</Input_7> <Input_8>OFF</Input_8> <Input_9>OFF</Input_9> <Input_10>OFF</Input_10> <Input_11>OFF</Input_11> </InputInverter> <LogicFunc> <AND>ON</AND> <OR>OFF</OR> </LogicFunc> <OutputInverter> <Output_Inverter>OFF</Output_Inverter> </OutputInverter> </Logic> <Puls> <Duration></Duration> <PulsPolarity> <negative>OFF</negative> <positive>OFF</positive> </PulsPolarity> </Puls> </Output11> </Outputs> </Ports> <Manufacturer> <Name>Wiesemann & Theis GmbH</Name> <Address>Porschstr. 12<br>42279 Wuppertal<br>Germany</Address> <Support_Hotline>+49-(0)202-2680-0</Support_Hotline> <Internet>www.wut.de</Internet> <DeviceTyp>Web-IO Digital 12xIn, 12xOut</DeviceTyp> <DeviceNo>#57630 TB 900571</DeviceNo> <Logo>logo.gif</Logo> </Manufacturer> </Config></io-Digital12x12.3>
