Viz Mosart Media Router Guide
Version 5.3 | Published September 14, 2023 ©
Media Router Console Commands
It is possible to activate predefined salvos, to set individual crosspoints and to get router information by entering appropriate console commands. The following commands are available:
autofailover: Toggles auto failover mode. See the MosartMediaRouterService configuration.
autotake: Toggle autotake mode. See the MosartMediaRouterService configuration.
clear: Clears the console window
command: Syntax: command cmd [arg1] [arg2]. Executes a Media Router command with two optional arguments. The following commands are available:
backup: Enforces a backup of the Media Router database
get <filename> : Retrieves the current Media Router database and stores the database using the given filename.
reset: Resets the Media Router to the latest Media Router database stored on the file system.
restore <filename> : Restores the Media Router database to the content of the database stored in the given filename
flush: Flushes the current content of the Media Router to file storage. This command may be used to set the initial state of the Media Router
deletesalvo: Syntax: deletesalvo salvo. Deletes the specified salvo
exit: Exits the Media Router
getconfig: Syntax: getconfig client. Returns the current configuration for the given client. Used mainly for testing Mosart Server clients
getstatus: Returns an xml string containing current Media Router status.
help: Lists all commands
idle: Toggles active / idle mode of the Media Router service. Used for testing
list: Syntax: list [salvos|clients|sources|inputs|outputs|all]. List various router information
restore: Syntax: restore <filename>. Restores the Media Router database to the content of the database stored in the given filename.
save: Syntax: save <filename>. Retrieves the current Media Router database and stores the database using the given filename.
setactive: Activates the Media Router service
setcrosspoint: Syntax: setcrosspoint inport outport [salvo]. Sets a crosspoint in the given salvo:
If no salvo is given then the pending salvo is used. I.e. a set crosspoint request is sent to corresponding clients.
If the given salvo is not present, a new salvo will be created.
setsalvo: Syntax: setsalvo salvo. Fires the specified salvo
verbose: Turns on/off verbose diagnostics
Note when specifying crosspoints in console commands the inport/outport name shall be used to identify the corresponding port.
Media Router console command examples
List all current salvos: list salvos
List active connections: list salvos current
List pending connections: list salvos pending
List a specified salvo: list salvos M1.A
Connects video port M1.A.A to Quantel 2 / Port 1: setcrosspoint VS.Q2.1 M1.A.VA
Sets a crosspoint in a salvo: setcrosspoint VS.Q2.1 M1.A.VA M1.Backup
Fires a salvo: setsalvo M1.Backup
Deletes a salvo: deletesalvo M1.Backup
