Viz Mosart Web Applications Release Notes
Version 1.4 | Published August 05, 2022 ©
Viz Mosart Web Applications is a growing suite of modern, browser-based utilities, designed to enrich Mosart workflows.
Current Version
The current version of Viz Mosart Web Applications is 1.4.
To download this version, please visit https://download.vizrt.com/ → / products/VizMosart/Latest Version/WebComponents/
Included Applications
The latest installer contains the following applications:
Key features
HTTPS support
The Web Applications suite supports HTTPS authentication for the applications running under it, with a centralized interface to help with certificate configuration. Note that depending on the application, some additional configuration may be needed in connected applications (e.g. Mosart itself) to enable HTTPS communication.
Previous Versions
None.
Supported System Requirements
Microsoft Windows 10 (runs on the same machine as the Viz Mosart server)
Support
