Mosart Web Applications Release Notes
Version 1.7 | Published March 14, 2024 ©
Mosart Web Applications 1.7.0
Release Date: 2024-03
Welcome to the release notes for Mosart Web Applications version 1.7.0, marking a significant step forward from version 1.6.1.
We invite your feedback, feature requests, and any comments on the application and its documentation, as your insights are invaluable to us.
images/download/attachments/125451001/image-2024-3-14_9-45-43.png
What's New?
  • Seamless Integration of NRCS Plugin with Pilot Edge!
    Enhance your planning efficiency by embedding the Mosart NRCS Plugin directly into Pilot Edge. This integration significantly reduces the need to toggle between applications during show planning, simplifying your workflow.
    images/download/attachments/125451001/2024-3-14_9-27-23.png
  • Audio Countdown in Timing Display
    Introducing the ability to schedule audio cues directly in the web Timing Display, mirroring desktop application functionalities with an entirely refreshed setup experience
    images/download/attachments/125451001/image-2024-3-13_14-46-54.png
  • Template Type Color Timer
    Introducing a novel timer in the Timing Display that indicates the color associated with the current on-air template, adding a visual cue to your workflow.
    images/download/attachments/125451001/image-2024-3-13_14-48-47.png
  • Integrated Rundown Viewer Timeline
    We've incorporated the Rundown Viewer's timeline directly into the Timing Display, offering another timer variant that enriches your control and visualization options.
    images/download/attachments/125451001/image-2024-3-13_14-51-45.png
  • Story Script in Rundown Viewer
    We added the story script component in the Rundown Viewer. For now, you have to use the URL parameter "?show-story-script" to show it.
    images/download/attachments/125451001/image-2024-3-14_9-12-58.png
  • Clip mirror statuses
    Support for the new clip status pattern for mirrored servers introduced in Mosart 5.5.
    images/download/thumbnails/125451001/2024-3-14_9-8-2.png
  • .NET 8 Upgrade
    Our backend now utilizes .NET 8, introducing improvements in security and performance to provide a more reliable and efficient application experience.
  • In Viz Mosart 5.4.0, there is an improvement to the Mosart Remote Control Service which should resolve the known issue where if the Remote Control Service had to be restarted it could happen that the Mosart Web Applications could not communicate with the Viz Mosart Server and you would get a warning message starting with "Mosart Web Applications require Viz Mosart version 5.1.0 or higher."
Bug Fixes
  • Resolved an issue where the Timing Display and Rundown Viewer failed to operate correctly with FQDN (MOSART-11698).
  • Fixed a bug causing errors in the Plugin when the Directtakes template set was hidden from user (MOSART-11973).
Installation and Upgrade Process
  • Installation: To download this version, please visit the Vizrt FTP site at https://download.vizrt.com/ and navigate to / products/VizMosart/Latest Version/WebApplications/.
  • Upgrade: The installer manages the upgrade, automatically removing older versions of Vizrt Mosart Web Applications and Vizrt Mosart Web Applications Configuration Tool before installing the new package.
System Requirements & Documentation
  • Ensure compatibility with Windows 10, Windows Server 2022, and Chrome for a seamless experience across all web applications.
  • The NRCS Plugin should work with any version of Mosart, while the Timing Display needs a least 5.0.3 and Rundown Viewer needs at least 5.1.0.
  • Detailed user guides are accessible within each application and via the Vizrt Documentation Center for the latest insights and instructions.
Support
