This is a pre-release of Showmaker.
Note: As documentation is updated, it will become available at the Vizrt Documentation Center.
Setting up Showmaker
Prerequisites
  • Viz Mosart 5.1.0 or later
Installation and Configuration
You can create standalone, placeholder rundowns in Showmaker with no additional configuration.
However, to work with Mosart templates, or to test the rundown, you must perform a one-off configuration.
To manage Mosart templates
To work with Mosart template sets in Showmaker, the bundled web application NRCS Plugin shall be correctly configured.
To connect to Viz Mosart
To verify your Showmaker rundown in Viz Mosart, you will need to configure your browser’s connection to the Mosart server.
  1. Ensure that your Viz Mosart system is operating under normal working conditions.
    As a minimum,
    1. Manus Admin must be running.
    2. The Viz Mosart UI is running, displaying a rundown.
  2. From the Mosart Web Apps Configuration Tool, select App Configuration.
Optional Server Setups
Support for Main/Backup Connection
  • If you have a backup server for redundancy, you will need define the environment in the menu section Server Configuration.
Support for HTTPS
Troubleshooting
Please refer to section Troubleshooting.
