This page walks you through opening Smart Panel, recognizing the main views, the core terminology, and building and running your first panel.
For an overview of Smart Panel and where it fits, see the Smart Panel introduction.
Open Smart Panel
Smart Panel runs in a web browser. Open it at http(s)://<server>:55142/smartpanel (port 55143 for HTTPS), where <server> is the hostname or IP of the Mosart Web Apps host. Your administrator may have changed those ports.
You can also open Smart Panel from the App Launcher in the Configuration Tool.
Smart Panel is one of the Mosart Web Apps, so the same host serves the other apps in the suite, and switching between them does not require signing in again.
Signing in and what you are allowed to do
Whether you sign in depends on how your administrator configured Mosart Web Apps:
  • Authentication off (the default install): you reach Smart Panel without signing in, and everyone has full control. Command buttons may still fail to reach the Viz Mosart server if it requires an API key.
  • Authentication on: the first time you open the page you are redirected to your organization's identity provider and signed in there. What you can do then depends on your role.
Role
What you can do
smartpanel-admin
Full control: create, edit, duplicate and delete panels, as well as run them.
smartpanel-viewer
Open and use panels, but not edit them. Opening a panel takes you straight to display mode.
Roles are granted in your identity provider, not in Smart Panel. If you sign in and are told you do not have access, you are authenticated but have not been given either role: ask your administrator. For the administrator's side of this, see Setup and Administration of Smart Panel.
Note: If Smart Panel opens but an Offline chip stays in the app bar, the connection to Viz Mosart could not be established. You can still design panels, but live values are replaced by placeholders. See the troubleshooting notes in Setup and Administration of Smart Panel.
Tour of the Interface
Smart Panel has three main views.
Landing page
At /smartpanel, this lists the saved panels. From here you create a new panel or open an existing one.
  • Click a panel to open it. If you can edit, it opens in the editor; if you can only view, it opens in display mode.
  • Each card has a Copy link button, for handing the panel to whoever needs to run it.
  • The card's options menu offers Display mode, Duplicate Panel and Delete Panel.
  • New panel opens the picker, where you start from a blank canvas or from one of the ready-made preset panels.
Panel editor
At /smartpanel/<panel>/edit, this is where you design a panel. It has four areas:
  1. App bar (top): a back arrow, the panel name (click to rename), an Edit and Preview switch so you can try the panel without leaving the editor, Save, an NDI Stream control for publishing the panel as an NDI source, a more-options menu holding Audio Countdowns, Duplicate Panel, Copy Link and Delete Panel, and the ? help icon. An Offline chip appears here when Viz Mosart is unreachable.
  2. Components palette (left): the nine item types you can place on the canvas, namely Timer, Label, Text, Image, Widget, Fader, Button, Toggle and Live.
  3. Canvas (center): the panel grid. Click a palette item, then click an empty cell to drop it. Click an existing item to select it.
  4. Properties pane (right): split into Panel Items, a searchable list of everything placed on the panel, and the property editor below it. The editor shows Panel Properties when nothing is selected, and Item Properties for the selected item.
Tip: Both side panes can be resized by dragging their inner edge, and pressing K shows the keyboard shortcuts.
Display mode
At /smartpanel/<panel>, without /edit, the panel runs touch-friendly and full-width, ready for the operator's screen. This is what you use on air, and it cannot be edited. Reach it from the Display mode action on the panel card, or from a copied link. For a completely bare screen, use the browser's own full-screen mode.
Help menu
The ? icon at the top right of every page opens the help menu:
Option
Opens
Keyboard shortcuts
The shortcut reference. Also available by pressing K.
Documentation
This Smart Panel user documentation.
What's new
The release notes for the current version.
Give feedback
An email to the Smart Panel team ([email protected]).
About
Smart Panel version and build information.
User avatar. When you are signed in, your avatar appears at the top right next to the help icon. Click it for your account and to sign out. Smart Panel shares its identity provider with the other Mosart Web Apps, so signing in or out applies to them all in the same browser session.
Key Terms
Term
Meaning
Panel
A single panel design: a grid of items plus its own name, aspect ratio, background, padding and font size presets. Stored on the server, so everyone who can reach it sees the same panel.
Item
One thing on a panel: a button, timer, label, image, fader, and so on.
Edit mode
The panel open at /smartpanel/<panel>/edit, with the app bar, the palette and the properties pane.
Display mode
The panel open at /smartpanel/<panel>, with no /edit. This is what you run on air, and it cannot be edited.
Grid
The rows and columns the canvas is divided into. Items snap to cells. Set in Panel Properties.
Aspect ratio
The shape of the canvas. Choose a preset, set a custom ratio, or pick None to stretch to fit the window. Set per panel in Panel Properties, so each panel suits its target screen.
Panel Properties
The pane shown when no item is selected. Controls background color, default padding, grid size, aspect ratio and the font size presets that items refer to as S, M and L.
Item Properties
The pane shown when an item is selected. Controls its text, color, font, padding, command binding and any type-specific options.
Panel Items
The searchable list of every item on the panel. Useful when items overlap or the panel is busy.
Offline
A chip in the app bar meaning the connection to Viz Mosart is not established. Live data is replaced with placeholder values so you can keep designing.
Preset panel
A read-only starting point offered in the New panel picker. What you create from one is a normal, editable panel.
Your First Panel
A short walk-through that uses every core concept once. It assumes Smart Panel is connected to a working Viz Mosart system. If the Offline chip is showing you can still complete the design steps, and only the last step needs a live server.
  1. Create a panel. On the landing page, click New panel, choose a blank panel, name it My first panel and create it. Smart Panel opens it in the editor.
  2. Set the canvas shape. With nothing selected, the right pane shows Panel Properties. Pick an Aspect ratio that matches your target screen, for example a landscape ratio for a wall-mounted touch monitor. Leave the grid as it is for now.
  3. Add a take button. Click Button in the palette. The cursor picks up a preview. Click an empty cell near the bottom of the canvas to drop it, and its Item Properties open on the right. Set the Label to Take, leave the target as Mosart, set the command type to Template, choose Program as the output, then pick any template from the picker, for example a camera template.
  4. Add a story countdown. Click Timer in the palette, then click a cell at the top of the canvas. In Item Properties, choose Current Item Countdown as the timer type. The item shows a placeholder countdown, or a live one if Viz Mosart is connected.
  5. Add a label. Click Label, click a cell next to the timer, and choose Current Item Slug so it shows the name of the on-air item. Set Font size to M.
  6. Try it without leaving the editor. Switch the app bar from Edit to Preview. The palette and handles step out of the way so you can see the panel as an operator would.
  7. Save. Click Save in the app bar. The panel is stored on the server, and anyone who can reach it can now open it.
  8. Run it. Go back to the landing page and choose Display mode on your panel's card, or use Copy Link and open that link on the operator's screen. Tap the take button and, with Viz Mosart connected, it sends the template you bound in step 3.
You have now built and operated your first panel. To go deeper into any step, see Working with Smart Panel.
