Viz Pilot Edge Release Notes
Version 2.1 | Published April 14, 2021 ©
Viz Pilot Edge 2.1.0
Release Date: 2021-04-14
These are the release notes for Viz Pilot Edge version 2.1.0. This document describes the user-visible changes that have been made to the software since release 2.0.0.
Changes and New Features
  • In a custom layout, you can now browse for assets by clicking anywhere in their container (VPE-3921).
Fixed Issues
  • Hidden fields won't receive focus (VPE-3825).
  • Improved fields focus when using keyboard navigation (VPE-3824).
  • Tempered visual artifacts when closing a template containing a custom layout (VPE-3781).
  • No more blank space and scrollbar after resizing the browser window (VPE-3831 & VPE-3934).
  • Context menus, number sliders, and date pickers respond better when used in multiple tabs (VPE-3748).
  • Improved custom layout responsiveness (VPE-3797 & VPE-3935).
  • Read-only map thumbnails now display correctly (VPE-3891).
Known Issues
  • 4K resolution images are not supported in Octopus 8 and Octopus X due to memory constraints (VPE-2412).
System Requirements
Hardware
There are no known hardware limitations for Viz Pilot Edge, other than requirements stipulated by newsroom systems hosting the client.
Software
Vizrt components
  • Pilot Data Server 8.6
  • Preview Server 4.4.1
  • Viz Engine 4.2.0
  • Viz Engine 3.14.5
Note: Viz Engine 4.2.0 is required to enable support for transition logic and combo templates.
Note: TGA image support requires a codec program like https://www.fastpictureviewer.com/codecs/ to be installed on the same machine as crop service.
Browser
If running Viz Pilot Edge inside a browser, the following minimum requirements apply:
  • Microsoft Internet Explorer 11 +
  • Chrome 64 +
  • Safari 11.0 +
Newsroom Systems Used for Testing
  • iNEWS 7.7.0.14
  • Octopus 8.3 (see also Known Issues above)
  • ENPS 9.0.177 (Browser type Internet Explorer)
  • Open Media 4.4.4359
  • Octopus X (see also Known Issues above)
Upgrading
When upgrading from a previous version of Pilot Edge, the previous version may still be presented by the host browser for a short time due to client side caching. To prevent this, clear the host browser cache. If you are using the default Internet Explorer host, open Internet Explorer, press CTRL + SHIFT + DEL, select Temporary Internet files and website files and click DELETE.
Important Notes
  • If there are any issues with map fields when running in Microsoft Internet Explorer 11 +, remove include all local sites not listed in other zones and turn off detection of intranet zones in the IE11 policy settings. (VPE-2329)
Documentation
Documentation for Viz Pilot Edge is available at the Vizrt Documentation Center:
Support
