Log Files
Viz Log Files
Viz Pilot System Log Files
The default location is:
%PROGRAMDATA%\Vizrt\Logs\Viz Pilot x.y\pilot.log
Note: If this path is empty, check the ContentPilot.ini, as the default path may be overridden by the logdir setting in the Pilot section of the ini file.
You can also access the logs from Main Menu > File > View Log.
The logging level can be set using environment variable PILOT_LOG_LEVEL. This accepts the values 0-4 where a higher number means a more verbose log. The default level is 3.
Database Log Files
See Database Error Logs.
Other Log Files
Other useful log files include the Media Sequencer logs and the Viz Engine logs.
Crash Log Files
Eureka Log Files (.elf)
Eureka Log files for Viz Pilot News, Director and Template Wizard are found here:
%ProgramData%\Vizrt\Logs\Viz Pilot x.y
Crash Dumps
When using Windows 7 or later, it's possible to generate crash dumps automatically by setting certain registry keys, as described in Collecting User-Mode Dumps.
All of the Viz Pilot system’s client applications are 32-bit. When collecting a crash dump of a 32-bit application on 64-bit Windows, you must use the 32-bit version of the Windows Task Manager in order for the dumps to be readable.
The Windows task manager will normally be installed in:
32-bit version; C:\Windows\SysWOW64\taskmgr.exe
64-bit version; C:\Windows\System32\taskmgr.exe
Viz Config Files
Viz Pilot System Config Files
Most of the Viz Pilot system’s components use the ContentPilot.ini file. Object Store may use its own objectstore.ini file.
The INI files are stored here:
%ProgramData%\Vizrt\Viz Pilot x.y\Config
For more details, see Initialization and Configuration Files.
Viz Engine Config Files
The Viz Engine files are stored here:
Windows 64-bit: %ProgramFiles(x86)%\Vizrt\Viz3
Media Sequencer Config Files
The default.xml files are stored here:
Windows Vista and 7: %ProgramData%\Vizrt\Media Sequencer Engine
Windows XP: C:\Documents and Settings\All Users\Application Data\Vizrt\Media Sequencer Engine
For more details, see Media Sequencer Data.
Modifying Log File Settings
The default location can be overridden using the LOGDIR and LOGFILE settings in the ContentPilot.ini file.
The maximum size and number of rolling log files can also be configured in the ini file (LOGSIZE, LOGCOUNT).
The log level can be changed by using the following command line parameters:
noverbose sets log level to low.
extra_verbose sets log level to high
