Viz Plug-ins User Guide
Text FX Arrange
images/download/thumbnails/95402148/ico_tfx_arrange.png
The Text FX Arrange plug-in allows you to arrange characters in either a circular or a wave shape. The characters can be animated on the selected shape by animating the offset value.
Supported Pipelines
Classic Render Pipeline
images/s/-wjspee/8703/98yf4s/_/images/icons/emoticons/check.svg
Viz Engine Render Pipeline
Text FX Arrange Properties
  • Offset %: Moves the characters on the shape. 100% means one full rotation of the text on the circle.
  • Scale %: Sets the text on the shape. The parameter does not scale the characters itself, but the kerning of the characters.
  • Shape: Changes the shape of the character layout to Circle or Wave.
    Note: The shape of the text transformation is not visible in the Scene Editor while the Text Editor is active.
Circle Parameters
  • Diameter: Sets the diameter of the circular shape.
  • Positioning: Defines the position of the text on the circular shape:
    • Relative: Maintains the text spacing of the text object.
    • Absolute: Distributes the text evenly onto the circle.
  • Direction: Sets the direction of the text on the circle to either Clockwise or Counterclockwise.
  • Rotation: Rotates the characters on the X-axis.
  • Align: Rotates the characters on the Z-axis to align the X-axis with the tangent of the shape at the characters position.
Wave Parameters
  • Length: Sets the wave length. A high value creates many and small waves, a low value creates fewer and bigger waves.
  • Width: Sets the width of the wave.
  • Height: Sets the height of the waves without altering the number of waves as the Length does.
  • Shift %: The wave usually starts at the height 0. The shift value moves that point, thereby moving the texts position on the wave structure. Setting Shift % to 100% brings you back to the beginning.
  • Damping: Modifies the amplitude of the wave curves.
