![](assets/images/logos/VizWorldLogo.png)
Viz World Release Notes
Version 21.0 | Published December 14, 2021 ©
Viz World 21.0.0
Release Date: 2021/12/13
These are the release notes for Viz World 21.0.0. This document describes the user-visible changes that have been made to the software since release 20.1.0.
Functionality Removed or Changed
Known Issues
World Server Launcher must run with elevated privileges to launch World Server as a service (MAPS-5530).
World Server must be restarted after manually scanning street data (MAPS-6275).
World Server leaks memory when targeted by a port scan (MAPS-5597).
When editing multi-hop scenes, it is possible to select Favorites. This is not intended functionality, and it causes errors if you do (MAPS-6319).
Styles with names including non-English letters can exhibit bugs (MAPS-5714). Workaround: Use English letters only.
Favorites with names including the plus symbol + can exhibit bugs (MAPS-5731). Workaround: Avoid the use of the plus symbol.
If the MapService.Service process is running, it must be manually stopped before uninstalling Viz World Client (MAPS-5902)
Other notes
This is the last release of 32-bit versions of Viz World Server and Viz World Classic standalone. This does not affect the release of 32-bit World Client applications (Viz World Instant Maps / Viz World Map Editor / Viz World Design Client / ActiveX Maps Client), nor the 32-bit Viz Engine Map Plugins . (MAPS-6602)
Compatibility Notes
Viz World 21.0.0 was tested with:
Viz Engine 4.3.1 and 3.14.5
Viz Pilot 8.6.0
Viz Pilot Edge 2.1.0
Viz Pilot Data Server 8.7.0
Viz Trio 3.2.6
Documentation
Documentation for both Viz World and Viz World Classic are available at the Vizrt Documentation Center:
Support
