Deploy Agent Modes
The Deploy Agent supports two modes:
  • Standard Mode: Creates only folders on the destination server which contain files that have to be copied by the task. This mode ensures that the folders on the source and destination servers have the same UUID if possible. I.e. folders outside of the original structure which contain references and/or folder links of files inside the structure have new UUIDs assigned if their original UUIDs are present on the destination server.
  • Direct Deploy Copy Mode: Also creates only folders on the destination server which contain files that have to be copied by the task. This mode ignores the UUID of folders and makes sure that all folders have the correct name in the structure
Standard Mode Supported Options
The standard mode supports these options:
Options
Supported Item
Schedule Options
Real-time
Time steered
User triggered
Data Mode Options
Folder based (Only a single folder can be selected per task)
File based: in ‘Copy to target folder only’ mode (Multiple files can be selected per task, folders are not allowed)
Search criteria based: in ‘Copy to target folder only’ mode (Copies all files that result from executing the search criteria, folders are ignored)
Real-time Options
Rebuild original structure
Rebuild structure under target folder
Support for: Removal of deleted objects on target server(s), Synchronization users, groups, keywords, add-on templates, etc.
Time Steered Options
User Triggered Options
Direct Deploy Copy Mode Supported Options
The Direct Deploy Copy Mode (DDC) mode supported these options:
Note: Real-time is not supported in this mode.
Options
Supported Item
Schedule Options
Time steered
User triggered
Data Mode Options
File based (Multiple files can be selected per task, folders are not allowed)
Search criteria based (Copies all files that result from executing the search criteria, folders are ignored)
Additional Information on Data Modes
  • File based: The task is not able to execute if the objects to deploy contain folders
  • Search criteria based: The task ignores all folders that are contained in the result of the search.
Standard and DDC Supported Options
Data Mode
Options
Standard Mode
DDC Mode
X = Supported Options
Real-time
Time steered
User triggered
Real-time
Time steered
User triggered
Folder based
X
X
X
X
X
X
X
X
X
X
X
X
X
X
File based
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
