Graphic Hub Startup
This section details the procedures to start and shutdown the Graphic Hub and the startup of a configured Graphic Hub database. All Graphic Hub configurations are started through the Graphic Hub Terminal.
To log in and use a Graphic Hub, see Graphic Hub Login and Log Out.
To Start a Graphic Hub
  1. Open the Graphic Hub Terminal:
    • Click Start > All Programs > Vizrt > Graphic Hub > GH Terminal, or
    • Double-click the Graphic Hub Terminal desktop icon. The Graphic Hub Terminal opens in the default web browser.
      Note: Each time the Viz GH Terminal desktop icon is double-clicked a new Graphic Hub Terminal instance is opened.
  2. Start a Graphic Hub Server:
    1. The last used server configuration is available.
    2. Click Start Server.
      or
    3. Click Mode.
    4. Select the required Graphic Hub mode (see Graphic Hub Modes and Selecting a Graphic Hub Mode).
    5. Click Load and run configuration > Select configuration.
      images/download/attachments/50608324/start_shutdown_mode_load_start.png
      Note: From the same menu, select Load Configuration to load and modify a configuration. Then start that configuration.
Localhost, 5/4 Free and Multiuser Startup Screen
images/download/attachments/50608324/start_shutdown_mode_load_screen.png
Cluster Startup Screen
images/download/attachments/50608324/start_shutdown_mode_cluster_load_screen.png
