Service Host
Version 1.1 | Published November 21, 2018 ©
Control Mode
The Control Mode plugin is registered as a Windows Service when the Service Host is installed. This service is the administration point for this Service Host. The shortcut to the Control Mode of the current Service Host can be found at %ProgramData%/vizrt/ServiceHost/ServiceHost.control. It provides the following functionalities via REST and Command interface.
On the welcome page, the first thing to do is to log in. The login name is used to log all interactions with the Control Mode. The login name can be viewed on the upper right of the GUI, next to the Login/Logout button.
images/download/attachments/41791733/control_mode_login_001.png
Control Mode Login
images/download/attachments/41791733/image2018-6-26_11-19-2.png
Control Mode Login Confirm
images/download/attachments/41791733/control_mode_login_003.png
Control Mode Logged In
Viz Engine
The Control Mode is aware of Viz Engine instances on the local machine. They can be controlled from here.
Follow the menu Monitor > Viz Engine
images/download/attachments/41791733/monitor_engine.png
to go to this screen.
images/download/attachments/41791733/monitor_engine_002.png
Viz Engine Monitor
Start a Viz Engine instance
From the Viz Engine Instances Monitor page, the context menu on an individual Viz Engine instance or use the action bar on the bottom of the screen can be used to start Viz Engine instances.
images/download/attachments/41791733/monitor_engine_context_menu_start.png
Viz Engine Context Menu
images/download/attachments/41791733/monitor_engine_action_bar_start.png
Viz Engine Action Bar
The page is not automatically refreshed by default. This is due to performance reasons to keep the impact on the Viz Engines as minimal as possible. To check for a proper launch or termination, use the Refresh button or set a refresh rate.
Preconditions
  • The Viz Engine needs to be installed at the default location.
Postconditions
  • Start: a Viz Engine was launched without GUI and without console
  • Start: the launch may have failed. Please check the reason in the logs. Context menu Logs or Menu Report > Logs > Viz Engine.
Stop a Viz Engine instance
From the Viz Engine Instances Monitor page, the context menu on an individual Viz Engine instance or use the action bar on the bottom of the screen can be used to stop Viz Engine instances.
images/download/attachments/41791733/monitor_engine_context_menu_stop.png
images/download/attachments/41791733/monitor_engine_action_bar_stop.png
The page is not automatically refreshed by default. This is due to performance reasons to keep the impact on the Viz Engines as minimal as possible. To check for a proper launch or terminate use the Refresh button or set a refresh rate.
Preconditions
  • The General Comm. Port of each Viz Engine instances need to be configured properly. Otherwise, the control instance will not be able to stop the specified Viz Engine instance correctly.
Postconditions
  • Stop: the Viz Engine instance was sent the EXIT command.
The shutdown of a Viz Engine may take some time. To kill the process, with all consequences, use Terminate from the context menu.
View Viz Engine Configuration
The config file of a Viz Engine instance can be viewed either from the Context menu on the Monitor page or via menu Configuration > Viz Engine.
images/download/attachments/41791733/conf_engine_001.png
From there, select the Viz Engine instance.
images/download/attachments/41791733/conf_engine_002.png
Viz Engine Configuration Instance Selection
The page is view only.
View Viz Engine Logs
The log file of a Viz Engine instance can be viewed either from the Context menu on the Monitor page or via menu Report > Logs > Viz Engine.
images/download/attachments/41791733/report_engine_menu.png
From there, select the Viz Engine instance to filter the available log files and how many lines to display.
images/download/attachments/41791733/report_engine_logs.png
Viz Engine Logs
Plugins
Register a Plugin Instance
To register a new instance of a plugin as a Windows Service, use the menu Configuration > Plugin-in > Register New Instance.
images/download/attachments/41791733/plugin_register_001.png
Register a New Plugin Instance
On the following screen, select the plugin type and give the instance a service and display name. E.g. register a Channel Recorder:
images/download/attachments/41791733/plugin_register_002.png
New Plugin Instance Type and Name
images/download/attachments/41791733/register_plugin_003.png
New Plugin Instance Success Dialog
Confirm with Apply. The dialog allows to go directly to the configuration of this plugin instance.
Configure a Plugin Instance
The configuration of a plugin instance can be reached from the Monitor plugin page via the context menu of a plugin instance or via the menu Configuration > Plug-in > Configure Instance.
images/download/attachments/41791733/plugin_configuration.png
Plugin Monitor
The plugin monitor page can be reached via the menu Monitor > Plugin or from the welcome page by clicking on the Plugin-in Instances icon.
images/download/attachments/41791733/plugin_monitor_001.png
Plugin Monitor
On this page, there is a filter on the left-hand side to select the available plugin instances. Each concrete entry on the right-hand side has a context menu that allows the plugin instance to be unregistered.
Start/Stop a Plugin instance
The context menu provides the capability to start/stop a plugin instance.
images/download/attachments/41791733/image2018-6-26_12-51-57.png
Start/Stop a Plugin Instance
Unregister a Plugin Instance
The context menu provides the capability to unregister a plugin instance. Once selected and the following dialog has been answered with Yes, then the plugin instance is stopped if it was running and unregistered from Windows services.
Any log and configuration files remain in ProgramData in order for later use by a subsequent new registration.
images/download/attachments/41791733/plugin_unregister_001.png
images/download/attachments/41791733/plugin_unregister_002.png
Report/Logs
The logs can be reached either via the context menu on the plugin monitor page or from the menu Report > Logs > Plug-in.
images/download/attachments/41791733/plugin_logs_001.png
Plugin Logs
On the left-hand side, there is the instance filter and the content of the selected log file is displayed on the right-hand side of the screen. The number of lines displayed can be selected. It operates like the tail command.
Notes
The Configuration File of a Plugin instance is missing
The configuration file of a Plugin instance, located at %ProgramData%\vizrt\ServiceHost, contains the Plugin name, which is a most important information. Service Host uses the Plugin name to load the correct DLL at run time to serve functionalities and get some information from the DLL, such as the configuration model. Thus, if the configuration file missing, a plugin instance cannot be started.
At the Plugin monitor page, for the plugin instances which their configuration files missing, the Plug-in field will be empty. To fix the problem, users need to unregister them first, and register them back.
images/download/attachments/41791733/image2018-6-26_13-4-24.png
Service Host (Control Mode)
The Control Mode itself can be configured too. For security reasons, the configuration of the Control Mode needs to be configured by administrators.
Configuration
The configuration page for the Control Mode may be reached via the menu Configuration > Service Host.
images/download/attachments/41791733/control_mode_conf_001.png
Control Mode Configuration
On this page, the REST listening address can be configured. By default, Service Host is listening to all interfaces. This is specified by [All interfaces] in the Listen to field. As port number, any valid and unused port number may be used. Later versions may support automatically finding of an available port number.
The Access Treat Type controls who is able to interact with the Service Host.
  • Only local access (LOCAL_ONLY): To allow only users accessing the GUI via the local machine to change the system (such register/unregister new plugin instance or start/stop Viz Engine instances). Users accessing the GUI from external machine, regardless of whether authenticated, are not allowed to make any changes.
  • Authentication required (AUTHENTICATION_REQUIRED): Same as above, only local access; except that users accessing externally are allowed as well as long as they are authenticated. In future versions, this may change to all users are required to authenticate before they can make changes to the system.
  • No authentication (NO_AUTHENTICATION): No restrictions apply. All users may change the system, both locally and externally. We do no recommend this setting since there is no way of gathering user information in the operating logs.
images/download/attachments/41791733/control_mode_conf_002.png
The Arguments edit lets one pass arbitrary startup arguments to the control mode plugin. In this case, we set the log level to debug mode.
Allowed values for Arguments are
  • -l debug
  • -l info
  • -l warning
  • -l error
  • -l off
Report/Logs
The logs produced by the control mode may be accessed via the menu Report > Logs > Service Host.
images/download/attachments/41791733/control_mode_logs_001.png
Control Mode Logs Navigation
On the left-hand side, select the log file to be displayed. There are two types of logs available.
The Control Mode log
This log file is named ServiceHost.control.log, it does log rotation and may also be reached via the log panel on the bottom of the screen.
images/download/attachments/41791733/control_mode_logs_004.png and images/download/attachments/41791733/control_mode_logs_003.png
Service Host Startup Logs
Logs are produced during startup and kept as long as this Service Host is running, so possible startup issues can be captured before a plugin is loaded and initialized. These log files are removed after a successful shutdown. They are named ServiceHost.dateandtime.pid.log, where dateandtime is the date and time the selected timezone, pid is the process id.
images/download/attachments/41791733/control_mode_logs_002.png
Startup Logs
Debugging of Service Host
Manual Register/Unregister and Stop/Start
The Service Host itself is capable of registering and unregistering itself as Control Mode service. This might be useful in cases not covered by the installer.
Register Control Mode from Command Line
 Z:\> ServiceHost.exe -c -i
Unregister Control Mode from Command Line
Z:\> ServiceHost.exe -c -r
The Service Host in Control Mode can also be started and stopped from the command line.
Start Control Mode from Command Line
 Z:\> ServiceHost.exe -c -s
Stop Control Mode from Command Line
Z:\> ServiceHost.exe -c -k
Launch Service Host in Foreground With a Console Window
For debugging, the Service Host can be launched in foreground and with a console window attached. To list all the possibilities use the command line switch -h
Command line Options for Service Host
Z:\>ServiceHost.exe -h
Usage:
$0 [-v] ... start from within windows services, optional verbose mode
$0 [-v] -N service_name -i
... install $service_name as service
-v ... optional verbose mode
$0 [-v] -N service_name -r
... remove $service_name as service
$0 [-v] -N service_name -s
... start service $service_name
$0 [-v] -N service_name -k
... kill service $service_name
$0 [-v] -N service_name -d
... run $service_name in debug mode with a console window
$0 [-v] -c -i
... install control as service, the service name is '{ProductName}.control'
$0 [-v] -c -r
... remove control as service, the service name is '{ProductName}.control'
$0 [-v] -c -s
... start control service, the service name is '{ProductName}.control'
$0 [-v] -c -k
... kill control service, the service name is '{ProductName}.control'
$0 [-v] -c -d
... run control in debug mode with a console window
-p "[argument...]"
... arguments that gets forwarded to the plugin
e.g. -p "-l debug -v"
What we are interested in here are the lines with the -d option.
To start the Service Host in the Control Mode with a console window, make sure it is not running as windows service then launch it with -c -d options.
Z:\>ServiceHost.exe -c -k
Z:\>ServiceHost.exe -c -d
Optionally, you can add verbose and log parameters to the Service Host and the Control Mode plugin.
Z:\>ServiceHost.exe -c -d -v -l debug -p "-v -l debug"
the first -v -l debug are for the Service Host executable and the one inside the -p option are forwarded to the Control Mode plugin. In the console mode, the logs are also forwarded to the console window.
