Service Host
Version 1.1 | Published November 21, 2018 ©
Recording Viz Engine
From version 1.2, Channel Recorder supports the recording of the input and output signal from VizEngine. This feature is controlled by the parameter AliasNodeSource in the configuration.
The order in which the applications are execute is very important. In order to capture from Viz Engine, this must be executed before Channel Recorder.
