Bounding Actions
images/download/attachments/50614684/viz_icons_boundingactions.png
The Bounding Actions plug-in enables you to run Viz Artist/Engine actions depending on the size of the bounding box.
Bounding Actions Properties
images/download/attachments/50614684/plugins_container_boundingactions_editor.png
  • Text box: Executes the command every time the bounding box changes.
  • Scale X, Y and Z: Applies a scaling to the values %dx %dy %dz.
  • Offset X, Y and Z: Adds an offset to the values %dx %dy %dz.
Syntax:
  • %dx: Substitutes the width of the bounding box.
  • %dy: Substitutes the height of the bounding box.
  • %dz: Substitutes the depth of the bounding box.
  • %xbool: 0 if dx <= 0 else 1.
  • %ybool: 0 if dy <= 0 else 1.
  • %zbool: 0 if dz <= 0 else 1.
  • %container: Path of the container the bounding action is applied to.
  • %container[path]: Relative path of the container the bounding action is applied to.
Example:
THIS_SCENE*TREE*#297*TRANSFORMATION*POSITION SET %dx %dy %dz
Example:
%container[$textnode1$textnode2]*GEOM*TEXT SET %xbool
To Use Bounding Actions
  1. Drag the plug-in onto a container.
  2. Insert a command in the Text box (see examples above). Now every time the bounding box changes (a Sub-Container is moved outside the current bounding box or the bounding box plug-in is used to modify it), this command is executed.
