Text FX Slide
images/download/attachments/41798416/viz_icons_tfxslide.png
The Text FX Slide plug-in allows you to create a sliding animation of the characters on the X, Y and Z-axis.
Text FX Slide Properties
images/download/attachments/41798416/plugins_container_textfx_slide_editor.png
  • X, Y and Z Distance: Defines direction and distance of moved text.
  • Show Direction: Enables and disables view of movement vector.
    Note: The direction is not shown in On Air mode.
