Performance Bar
A Performance Bar can be shown at the bottom of the Scene Editor. The Performance Bar gives an indication of the performance (frames per second) the Scene is rendering in.
images/download/attachments/50615438/workbench_performancebarnew.png
Note: A Performance Bar can also be shown in On Air Mode (see Viz Artist Performance).
This section also contains information on the following topics and procedures:
Performance Bar Properties
  • VER (Vertices): Shows the number of vectors in the scene.
  • TET (AllocTexSize): Shows the total allocated size of Texture memory.
  • TEC (TexSize): Shows the size of the current in use Texture memory.
    Note: The actual drawing of Textures has an impact on the performance, more visible textures cause more render time. If texture memory is low it is possible that Textures are not visible in the Scene. The Texture memory usage is an indication for this.
  • ANI (Animation): Shows how many microseconds all active directors and animation channels take. This indicator is linked to the yellow bar.
  • MAT (Matrix): Transforms each container in the scene into world coordinate space. This indicator is linked to the cyan bar.
  • Z&C (Z-Sort): Refers to Z-sort and Culling, and sorts all containers for correct transparency drawing and determines if containers are visible in the current camera view. This indicator is linked to the pink bar.
  • VID (Video): Shows how many microseconds video input (live video Media Asset) and video output take. De-interlaced video inputs take longer time than progressive and interlaced. The only way to improve this value is to use a faster system. This indicator is linked to the red bar.
  • REN (Rendering): Shows how many microseconds it takes to render all objects on the screen. A faster graphics card improves this value. This indicator is linked to the blue bar.
  • PLU (plug-in): Indicates how much time in microseconds all active plug-ins spend in each render cycle. This indicator is linked to the orange bar.
  • SCR (Script): Shows the consumed time in microseconds from all active scripts. This indicator is linked to the dark green bar.
  • CUR (Current): Shows how many frames per second the scene render at in On Air mode. The number should be above 50 (PAL) or 60 (NTSC), according to the rate that has been specified in the Output Format section.
  • MAX (Maximum): Shows how many frames per second the scene can render at without waiting for vertical retrace. The higher the maximum value, the more performance is left. If the maximum value is reduced to below 50 or 60, the scene is not rendering in real-time.
  • Blue bar: Shows the number of frames used.
  • Green bar: Shows the number of frames available. The Performance Bar refresh rate can be modified in User Interface (see the Configuring Viz section of the Viz Engine Administrator Guide).
To View the Performance Bar
  • Click images/download/attachments/50615438/workbench_button_p.png in the Scene Editor.
    Note: This shows the Current (CUR) and Maximum (MAX) parameters.
To View All Performance Bar Indicators
  • Middle-click images/download/attachments/50615438/workbench_button_p.png .
    images/download/attachments/50615438/workbench_middleclickp_performancebar.png
