Component Properties
The following section describes properties of the standard components, exposed in the Object Inspector. For simplicity and ease of use, it is listed in alphabetical order.
Component properties listed in the Object Inspector
Action
Designates the action associated with the control.
Active
Use Active to determine or set whether a data set is populated with data. When Active is false, the data set is closed; the data set cannot read or write data and data-aware controls can not use it to fetch data or post edits. When Active is true, the data set can be populated with data. It can read data from a database or other source (such as a provider).
ActivePage
Specifies the page currently displayed by the page control.
AliasName (Database)
Specifies the Borland Database Engine (BDE) alias used by this database connection
Align
Determines how the control aligns within its container (parent control).
Alignment
Controls the horizontal placement of the text within the label.
AllowEditingOfDefaultName
Determines if the user should be allowed to edit the suggested name in the save dialog.
AllowGrayed
Determines whether check box can be in a “grayed” state.
AllowUp
Specifies whether all speed buttons in the group that contains this speed button can be unselected at the same time.
Anchors
Specifies how the control is anchored to its parent. Use Anchors to ensure that a control maintains its current position relative to an edge of its parent, even if the parent is resized. When its parent is resized, the control holds its position relative to the edges to which it is anchored. If a control is anchored to opposite edges of its parent, the control stretches when its parent is resized.
Attributes
Set Attributes to specify whether a connection object performs retaining commits or retaining aborts. The two behaviors are independent of each other. Attributes can contain one of the two TXactAttribute values (xaCommitRetaining and xaAbortRetaining), both values, or neither value.
AutoCalcFields
Determines when the OnCalcFields event is triggered. Set AutoCalcFields to control when the OnCalcFields event is triggered to update calculated fields during data set processing. A calculated field is one that derives its value from the values of one or more fields in the active record, sometimes with additional processing.
AutoCalcFields (Table)
AutoCloseUp
When AutoCloseUp is true, the drop-down closes up automatically when the user selects an item.
AutoComplete
When AutoComplete is true, the combo box responds to user keystrokes by searching the Items property array for the first item that matches the string entered so far. When AutoComplete is false, this feature is disabled.
AutoDropDown
When AutoDropDown is true, the combo box automatically drops down its list when the user starts typing a string while the combo box has focus. When AutoDropDown is false, the user must explicitly use the drop-down button to drop down the combo box list.
AutoEdit
Determines if a data source component automatically calls a data set’s Edit method when a data-aware control associated with the data source receives focus.
AutoRefresh
Specifies whether server-generated field values are automatically re-fetched.
AutoScroll
Use AutoScroll to specify whether the page scroller scrolls when the mouse hovers over one of its arrows.
AutoSelect
Determines whether all the text in the edit control is automatically selected when the control gets focus.
AutoSize
Determines whether the size of the label automatically resizes to accommodate the text.
BevelEdges
Use BevelEdges to get or set which edges of the control are beveled. The BevelInner and BevelOuter properties determine the appearance of the specified edges.
BevelInner
Determines the style of the inner bevel of a panel.
BevelKind
Use BevelKind to modify the appearance of a bevel. BevelKind influences how sharply the bevel stands out.
BevelOuter
Determines the style of the outer bevel of a panel.
BevelWidth
Determines the width, in pixels, of both the inner and outer bevels of a panel.
BiDiMode
Specifies the bi-directional mode for the control. Use BiDiMode to enable the control to adjust its appearance and behavior automatically when the application runs in a locale that reads from right to left instead of left to right.
BorderStyle
Determines whether the edit control has a single line border around the client area.
BorderWidth
Use BorderWidth to specify how wide the border around the panel should be. A value of 0 (zero) means no border should appear.
CacheSize
Set CacheSize to control how many rows the ADO data set’s provider keeps cached in its buffer and how many to retrieve at one time into local memory. Default value of CacheSize is 1 and the minimum allowed value is 1.
CachedUpdates
Specifies whether cached updates are enabled for a data set.
CalAlignment
Set CalAlignment to dtaLeft or dtaRight to align the drop-down calendar on the left or right side of the component. This property is applicable only if the Kind property is dtkDate and the DateMode property is dmComboBox.
CalColors
Use the CalColors property to get or set the calendar’s background color, month background color, text color, title background color, title text color, and trailing text color.
Cancel
Determines whether the button’s OnClick event handler executes when the Escape key is pressed.
Caption
Specifies a text string that identifies the control to the user.
Center
When the image does not fit perfectly within the image control, use Center to specify how the image is positioned. When Center is true, the image is centered in the control. When Center is false, the upper left corner of the image is positioned at the upper left corner of the control. The default value for Center is false. Note
ChannelID
Specifies the Viz Engine channel that should be used.
CharCase
Determines the case of the text within the edit control.
Checked
Specifies whether the check box appears checked.
Cmd
Deprecated (no longer in use).
Collate
Collate is true whenever the Collate check box is selected in the Print dialog. To make the dialog open with the check box selected, set Collate to true in the Object Inspector or in program code.
Color
Specifies the background color of the control.
Columns
Use Columns to specify the number of columns, in a multi-column list box, that are visible without having to use the horizontal scroll bar.
CommandTimeOut
Use CommandTimeout to specify the amount of time, in seconds, that can expire before an attempt to execute a command is considered unsuccessful. The default value is 30 seconds.
Connected
Set Connected to true to establish a connection to an ADO data store without opening a data set. Set Connected to false to close a connection. The default value for Connected is false.
Connection
Use Connection to specify an ADO connection object to use to connect to an ADO data store.
ConnectionString
Set ConnectionString to specify the information needed to connect the ADO connection component to the data store. The value used for ConnectionString consists of one or more arguments ADO uses to establish the connection. Specify multiple arguments as a list with individual arguments separated by semicolons.
ConnectionTimeOut
Use ConnectionTimeout to specify the amount of time, in seconds, that can expire before an attempt to make a connection is considered unsuccessful. The default value is 15 seconds.
ConnectOptions
Set ConnectOptions to specify whether the connection established by the TADOConnection is synchronous or asynchronous. The default value for ConnectOptions is coConnectUnspecified.
Constrained
Indicates whether updates and inserts, that don not conform to the result set generated by a SELECT statement, are permitted for Paradox and dBASE tables.
Constraints
Specifies the size constraints for the control.
Constraints (DataSet)
Specifies record-level constraints that must be met when editing the data.
ControlObjectName
Used to map the Field Identifier ID set for the scene. See also ControlObjectName and Control plugins.
ControlValue
The value that the control object in Viz Engine should receive.
Copies
If Copies is 0 or 1, the dialog will have 1 in the Number of Copies field. To make the dialog open with 2 or more copies selected, set the value of Copies in the Object Inspector or in program code.
Ctl3D
Determines whether a control has a three-dimensional (3-D) or two-dimensional look.
Cursor
Specifies the image used to represent the mouse pointer when it passes into the region covered by the control
CursorLocation
Use CursorLocation to indicate whether the cursors that use the connection object to connect to the ADO datastore use a client-side or server-side cursor library. CursorLocation only affects connections opened after the property is set. The default value for CursorLocation is clUseClient.
CursorType
Set CursorType to indicate the type of cursor the ADO data set uses for the record set when it is opened. CursorType must be set prior to activating the data set component. Among other cursor aspects, CursorType affects directional scrolling through a record set and the visibility of changes made by other users. The default value of CursorType is ctKeyset.
CustomColors
Each custom color is represented as a string of the form ColorX=HexValue. For example, the following string sets the first custom color
DatabaseName
Specifies the name of the database associated with this data set.
DataField
Specifies the field from which the edit control displays data.
DataSet
Specifies the data set for which the data source component serves as a conduit to data-aware controls. Set DataSet to the name of an existing data set component either at design time, or at runtime. By changing the value of DataSet at runtime an application can effectively use the same data-aware controls to display and edit data in different data sets.
DataSetField
Use DataSetField when the data set is the nested detail set of another data set, such as an Oracle8 nested data set. Read DataSetField to access the data set field component in the master data set that includes this data set as a detail. Set DataSetField to a field component in the master data set to assign this data set as the value of that field.
DataSource
Links the edit control to the data set that contains the field it represents.
DataSource
Specifies the data source component from which to extract current field values to use with same-name parameters in the query’s SQL statement.
Date
Use Date to get or set the date that is marked on the calendar. The value of Date must lie within the range specified by the MaxDate and MinDate properties. If MultiSelect is true, the selected range of dates goes from Date to EndDate.
DateFormat
If DateFormat is set to dfShort, the date is formatted using the short date format specified in the Windows control panel. By default, it appears like this
DateMode
If DateMode is dmComboBox, the component has a drop-down calendar illustration from which the user can select a date. If DateMode is dmUpDown, the component has Up/Down arrows with which the user can adjust the date. (Applies only when Kind is dtkDate.)
Default
Determines whether the component’s OnClick event handler executes when the Enter key is pressed.
DefaultDatabase
Set DefaultDatabase to indicate the database the ADO connection objects uses if the connection to the database specified in ConnectionString is unavailable, the connection cannot be made, or the database is not specified in the connection string.
DefaultExt
DefaultExt specifies a file extension that is appended automatically to the selected file name, unless the selected file name already includes a registered extension. If the user selects a file name with an extension that is unregistered, DefaultExt is appended to the unregistered extension.
DefaultIndex (Table)
Specifies if the data in the table should be ordered on a default index when opened.
DestHeight
The destination height of the image in Viz Engine. If set to <> 0 a crop tool will appear if the selected image does not adhere to the aspect given by DestHeight and DestWidth.
DestWidth
The destination width of the image in Viz Engine. If set to <> 0 a crop tool will appear if the selected image does not adhere to the aspect given by DestHeight and DestWidth.
Device
Use Device to specify whether the dialog should list screen fonts (fdScreen), printer fonts (fdPrinter), or both screen and printer fonts (fdBoth).
DisallowedKeyWords
Defines the disallowed keywords used when searching for media content. When a user searches and finds an image, they are not allowed to select the image if it contains a keyword that is present in the DisallowedKeywords property. Note
DockSite
Specifies whether the control can be the target of drag-and-dock operations.
Down
Specifies whether the button is selected (down) or unselected (up).
Director
Specifies the Viz Engine director.
DragCursor
Indicates the image used to represent the mouse pointer when the control is being dragged.
DragKind
Specifies whether the control is being dragged normally or for docking.
DragMode
Determines how the control initiates drag-and-drop or drag-and-dock operations. Enable automatic dragging by setting DragMode to dmAutomatic.
DropDownCount
By default, the drop-down list is long enough to contain eight items without requiring the user to scroll to see them all. To make the drop-down list smaller or larger, specify a number larger or smaller than eight as the DropDownCount value. If the DropDownCount value is larger than the number of items in the Items property, the drop-down list will be just large enough to hold all the possible choices and no more. If the DropDownCount value is smaller then the number of item in the Items property, the drop down list will display a scroll bar.
DriverName (Database)
Specifies the name of the BDE driver for the database.
EditMask
Use EditMask to restrict the characters a user can enter into the masked edit control to valid characters and formats. If the user attempts to enter an invalid character, the edit control does not accept the character. Validation is performed on a character-by-character basis by the ValidateEdit method. Setting EditMask to an empty string removes the mask.
EnableBCD
Use the EnableBCD property to specify how fields are mapped to field classes. If EnableBCD is true, (the default value) adDecimal and adNumeric fields are mapped to the TBCDField class when field objects are created. If EnableBCD is false, the fields are mapped to the TFloatField class.
Enabled
Controls whether the control responds to mouse, keyboard, and timer events.
EnableSpellCheck
Enables the user to spell check the text content of a template.
EvObjects
A list of paths to other objects in Viz Engine that should be controlled like the current control.
ExecuteOptions
Set ExecuteOptions to control the characteristics of a command (a data retrieval operation) executed from the ADO data set component.
ExecuteOptions.eoAsyncExecute
The command or data fetch operation is executed asynchronously.
ExecuteOptions.eoAsyncFetch
The data set first fetches the number of records specified by the CacheSize property synchronously, then fetches any remaining rows asynchronously.
ExecuteOptions.eoAsyncFetchNonBlocking
Asynchronous data fetches or command execution do not block the current thread of execution.
ExecuteOptions.eoExecuteNoRecords
A command or stored procedure that does not return data. If any rows are retrieved, they are discarded and not returned.
Exclusive (Database)
Enables an application to gain sole access to a database.
Exclusive (Table)
Enables an application to gain sole access to a Paradox or dBASE table.
ExtendedSelect
Determines if the user can select a sequential range of items in the list box.
FieldDefs (DataSet/Table)
Points to the list of field definitions for the data set.
FileDenyBrowseUp
If set when FileStartDir is set, this says that selecting from anywhere else (limiting instead of suggesting) is not permitted.
FileName
The FileName property contains the name and complete directory path of the most recently selected file. The value of FileName is the same as the first item in the Files property.
FileStartDir
If set, this contains the path to the folder (or its subfolders) from which images are selected. For example c:\Users\Public\Pictures\ (final backslash optional).
Filter
The file-selection dialog includes a drop-down list of file types under the edit box. When the user picks a file type from the list, only files of the selected type are displayed in the dialog.
Filter (DataSet/Query)
Specifies the text of the current filter for a data set.
Filtered (DataSet/Query)
Specifies whether filtering is active for a data set.
FilterOptions (DataSet/Query)
Specifies whether filtering is case insensitive, and whether or not partial comparisons are permitted when filtering records.
FilterIndex
FilterIndex determines which of the file types in Filter is selected by default when the dialog opens. Set FilterIndex to 1 to choose the first file type in the list as the default, or set FilterIndex to 2 to choose the second file type as the default, and so forth.
FindText
FindText contains the text string that the user wants to search for. When the user clicks the Find Next button, the text in the dialog’s edit box is automatically assigned to FindText. To make a default text string appear in the edit box when the dialog opens, assign a value to FindText in the Object Inspector or in program code.
Flat
Determines whether the button has a 3D border that provides a raised or lowered look.
FocusControl
Designates a windowed control associated with the label. Set FocusControl to the windowed control that should receive focus when the user presses the accelerator key specified by the label. Specify an accelerator key by preceding a character in the label text with an ampersand (&) and setting the ShowAccelChar property to True.
Font
Controls the attributes of text written on or in the control.
Font.Charset
Specifies the character set of the font.
Font.Color
Specifies the color of the text.
Font.Heigth
Specifies the height of the font.
Font.Name
Identifies the typeface of the font.
Font.Pitch
Specifies whether the characters in the font all have the same width.
Font.Size
Specifies the height of the font in points.
Font.Style
Determines whether the font is normal, italic, underlined, bold, and so on.
ForceDotAsDecimalSeperator
Determines if local specific decimal separator should be ignored and . used as separator.Deprecated - The decimal separator will now always be a dot.
Format
Format specifies custom format string for the date-time display, overriding the control panel strings. A custom format can include both date and time fields, but time fields are not editable unless the Kind property is dtkTime.Examples
Frequency
Use Frequency to specify the spacing of the tick marks, using the logical units used by the Position property. For example, a Frequency of 5 sets a tick mark at every fifth possible increment.
FromPage
The FromPage property corresponds to the From field in the Print dialog.
FullRepaint
Determines how the panel repaints itself when it is resized. When FullRepaint is true, the entire panel, including the beveled border repaints when the size changes. When FullRepaint is false, only the area inside the beveled border repaints.
Global
Determines if the targa clip should be controlled on a global lever or on Viz Engine director level.
Glyph
Specifies the bitmap that appears on the bitmap button.
GroupIndex
Buttons with the same property value (other than 0), work together as a group and can present mutually exclusive choices to the user.
HandleShared (Database)
Specifies whether or not to share a database handle.
Height
Specifies the vertical size of the control in pixels.
HelpContext
HelpContext supports help systems that use numeric topic IDs. For help systems that use topic keywords, see HelpKeyword. To enable context-sensitive help for a control, set HelpType to htContext and set HelpContext to a numeric topic ID. A topic ID of 0 (default) means that no help topic is provided for the control.
HelpKeyword
HelpKeyword supports help systems that use topic keywords. For help systems that use numeric topic IDs, see HelpContext. To enable context-sensitive help for a control, set HelpType to htKeyword and set HelpKeyword to a keyword string. No keyword (zero-length string; default) means that no help topic is provided for the control.
HelpType
Set HelpType to specify whether the control identifies its context-sensitive help topic by ID or keyword. When HelpType is htContext, the HelpContext property identifies the control’s help topic. When HelpType is htKeyword, the HelpKeyword property identifies the control’s help topic.
HideFileSelector
Determines if the File Selector icon should be hidden.
HideObjects
A list of paths to other objects in Viz Engine that should be hidden if this control is hidden. See HideOnEmpty.
HideOnEmpty
If the current control is empty, meaning there is no text, no image selected etc then the control will hidden in Viz Engine.
HideSelection
Determines whether the visual indication of the selected text remains when focus shifts to another control.
Hint
Contains the text string that can appear when the user moves the mouse over the control.
HorzScrollBar
HorzScrollBar properties.
HorzScrollBar.ButtonSize
Size of the horizontal scroll bar button.
HorzScrollBar.Color
Color of the horizontal scroll bar.
HorzScrollBar.Increment
Scroll increment.
HorzScrollBar.ParentColor
To have a control use the same color as its parent control, set ParentColor to true. If ParentColor is false, the control uses its own Color property.
HorzScrollBar.Position
Indicates the current position of the scroll bar.
HorzScrollBar.Range
Determines how far the scrolling region of the associated control can move.
HorzScrollBar.Visible
Determines if the horizontal scroll bar should be visible or not.
HotTrack
Determines whether labels on the tab under the mouse are automatically highlighted.
ImageInfo
Information about the image selected from Object Store
ImageInfoKey
ImageKeywords
Keywords for the image selected from Object Store
ImageSources
Use the ImageSources property to set the sources the user should be able to pick images from.
ImageSources.isAdvancedCuriousMap
The user can search and select a map from the Viz World Client.
ImageSources.isArdome
The user is allowed to search for clips in Ardome.
ImageSources.isBackground
Deprecated.
ImageSources.isCuriousMap
The user can search and select a map from the Viz World Client (simplified version).
ImageSources.isImageMediaSearch (previously named isDatabase)
The user can select an image from Object Store.
ImageSources.isFileOpen
The user can select a file from the file system.
The user can drag and drop images from the image pool found under the Viz tab in Director.
ImageSources.isMaterial
The user can drag and drop materials from the material pool found under the Viz tab in Director.
ImageSources.isObject
The user can drag and drop objects from the “geom” pool found under the Viz tab in Director.
ImageSources.isPaste
The user is allowed to paste images from the clipboard.
ImageSources.isProximity
The user is allowed to select images or video clips from Proximity’s Artbox. Requires the Proximity Artbox asset management system.
ImageSources.isRGB
The user can drag and drop files from the RGB-files tab in Director.
ImageSources.isScene
The user can drag and drop scenes from the scene pool found under the Viz Engine tab/button in Director.
ImageSources.isVideoMediaSearch (previously named isVideoHub)
The user can select a video from one of the configured providers in the Media Search.
ImeMode
Determines the behavior of the input method editor (IME). Set ImeMode to configure the way an IME processes user keystrokes. An IME is a front-end input processor for Asian language characters.
ImeName
Specifies the input method editor (IME) to use for converting keyboard input to Asian language characters.
Imported
Boolean telling us if the current was opened and filled externally.
Increment
Determines the increment.
IncrementalDisplay
Specifies whether successive approximations of the image should be drawn during slow operations. Set IncrementalDisplay to True on large compressed images that take a long time to load or on images that may be altered by a computationally slow process. When IncrementalDisplay is True, partial renderings of the image are drawn periodically during slow operations such as loading.
IndexDefs (Table)
Contains information about the indexes for a table.
IndexFieldNames (Table)
Lists the columns to use as an index for a table.
IndexFiles (Table)
Specifies one or more dBASE index file(s) to use for a dBASE table that uses non-production indexes.
IndexName (Table)
Identifies a secondary index for the table.
IntegerMode
Determines if the control will only use integer values.
InitialDir
InitialDir determines the default directory displayed in the file-selection dialog when it opens. For example, to point the dialog at the /home/company/docs directory, set the value if InitialDir to /home/company/docs. If no value is assigned to InitialDir, or if the specified directory does not exist, the initial directory is the current working directory.
IntegralHeight
Determines whether the list box displays the partial items.
InternalSpacing
Determines the spacing, in pixels, between each field.
Interval
Interval determines how frequently the OnTimer event occurs. Each time the specified interval passes, the OnTimer event occurs. Use Interval to specify any cardinal value as the interval between OnTimer events. The default value is 1000 (one second).
IsolationLevel
Use IsolationLevel to specify the transaction isolation level for a connection. The transaction isolation level determines how a transaction interacts with other simultaneous transactions when they work with the same tables, and how much a transaction sees of the work performed by other transactions. The default value for IsolationLevel is ilCursorStability.
ItemHeight
Specifies the height in pixels of an item in an owner-draw list box.
ItemsIndex
Indicates which item in the list is selected.
Items
Contains the strings that appear in the list box.
KeepConnection (Database)
Specifies whether an application remains connected to a database even if no data sets are open.
Keyframe
Specifies the Viz Engine keyframe to control.
Kind
Use Kind to specify the appearance of the component’s control and its response when the user clicks the button.
Layout
Specifies the vertical placement of the text within the label.
Left
Specifies the horizontal coordinate of the left edge of a component relative to its parent.
Lines
Contains the individual lines of text in the memo control.
LinkName
When selecting an image connected to a person in Object Store, the name of the person can be automatically put into an edit box. Use LinkName to set the edit box that should receive the name of the person
LinkTitle
When selecting an image connected to a person in Object Store, the title of the person can be automatically put into an edit box. Use LinkTitle to set the edit box that should receive the title of the person.
LineSize
Use LineSize to specify the distance along the slider that represents a single unit. The current Position is marked by a slider.
Locked
Determines whether a panel that is used as a toolbar is replaced by a toolbar supplied by an OLE server.
LockType
Use LockType to specify the lock type to use when opening a data set. LockType determines whether the row locking scheme for a record set will be pessimistic, optimistic, or read-only. To be effective, LockType must be set prior to activating the ADO data set component.
LoginPrompt
Specifies whether a login dialog appears immediately before opening a new connection.
Margin
The margin is the space between the image edge and the button edge.
MarshalOptions
Use MarshalOptions when the data set component uses a client-side cursor and data changes are to be sent back to the server. MarshalOptions specifies which records in the local record set are sent to the middle tier or server. A value of moMarshalAll results in all records in the local record set being packaged and sent back. A value of moMarshalModifiedOnly sends back only those records that have actually been changed in the local record set The default value for MarshalOptions is moMarshalAll.
MasterFields (Table)
Specifies one or more fields in a master table to link with corresponding fields in this table in order to establish a master-detail relationship between the tables.
MasterSource (Table)
Specifies the name of the data source for a data set to use as a master table when establishing a detail-master relationship between this table and another one.
Max
Specifies the maximum size of an interval, see Min.
MaxDate
Use MaxDate to get or set the maximum date to which users can scroll the calendar. The values of the Date and EndDate properties cannot exceed MaxDate.
MaxFontSize
Assign a value to MaxFontSize to limit the font sizes available in the dialog. MaxFontSize is inoperative unless the fdLimitSize flag is set in Options.
MaxLength
Specifies the maximum number of characters the user can enter into the edit control.
MaxRecords
Use MaxRecords to control the number of rows the provider for the ADO data set component returns from the data source. Set MaxRecords to indicate the maximum number of rows. The default value for MaxRecords is 0 (zero), which places no limits on the result set.
MaxValue
Specifies the maximum value allowed, see MinValue.
Min
Specifies the minimum size of an interval, see Max.
MinDate
Use MinDate to get or set the minimum date that can be selected.
MinFontSize
Assign a value to MinFontSize to limit the font sizes available in the dialog. MinFontSize is inoperative unless the fdLimitSize flag is set in Options.
MinValue
Specifies the minimum value allowed, see MinValue.
ModalResult
Determines whether and how the button closes its (modal) parent form.
Mode
Read Mode to determine the permissions available to the connection after the connection has been activated. The permissions expressed in Mode govern the types of operations (such as reading and writing) can be performed through the connection. They also control how these operations are affected by and affect other concurrent users.
MultiLine
Determines whether the tabs can appear on more than one row.
MultiSelect
Determines whether the user can select more than one element at a time.
MultiSelection
Indicates if the user is allowed to multi select or not.
Name
Specifies the name of the control as referenced in code.
NumGlyphs
ObjectPath
Reference to the object to control in the Viz Engine scene. Enter the path to the object in the scene. Use full Viz Engine-path or the name of the container with a dollar-sign ($) in front (the container must then have a unique name in the scene tree).
ObjectView (DataSet/Query)
Specifies whether fields are to be stored hierarchically or flattened out in the Fields property.
OEMConvert
Determines whether characters typed in the edit control are converted from ANSI to OEM and then back to ANSI.
Options
Use the Options property to customize the appearance and functionality of the dialog. By default, all options are off.
Options.cdAnyColor
Allow the user to select non-solid colors (which may have to be approximated by dithering).
Options.cdFullOpen
Display custom color options when the dialog opens.
Options.cdPreventFullOpen
Disable the Define Custom Colors button in the dialog, so that the user cannot define new colors.
Options.cdShowHelp
Add a Help button to the color dialog.
Options.cdSolidColor
Direct Windows to use the nearest solid color to the color chosen.
Options.fdAnsiOnly
Displays only fonts that use the Windows character set. Symbol fonts are not listed in the dialog.
Options.fdApplyButton
Displays an Apply button in the dialog, whether or not there is an OnApply event handler.
Options.fdEffects
Displays the Effects check boxes (Strikeout and Underline) and the Color list box in the dialog.
Options.fdFixedPitchOnly
Displays only monospaced fonts in the dialog. Proportionally spaced fonts are not listed, nor are TrueType fonts that do not have the fixed-pitch flag set in the style header.
Options.fdForceFontExist
Allows the user to enter only fonts that are displayed in the dialog (that is, listed in the Font combo box). If the user tries to enter another font name, an error message appears.
Options.fdLimitSize
Enables the MaxFontSize and MinFontSize properties, limiting the range of font sizes that appear in the dialog if these properties have values.
Options.fdNoFaceSel
Causes the dialog to open without a preselected font name in the Font combo box.
Options.fdNoOEMFonts
Removes OEM fonts from the dialog’s combo box. Lists only non-OEM fonts.
Options.fdNoSimulations
Displays only fonts and font styles that are directly supported by the font definition file. GDI-synthesized bold and italic styles (for bitmap fonts) are not listed.
Options.fdNoSizeSel
Causes the dialog to open without a preselected size in the Size combo box.
Options.fdNoStyleSel
Causes the dialog to open without a preselected style in the Font Style combo box.
Options.fdNoVectorFonts
Removes vector fonts from the dialog’s combo box; lists only non-vector fonts. (Vector fonts are Windows 1.0 fonts, such as Roman or Script, which resemble pen-plotter output.)
Options.fdScalableOnly
Displays only scalable fonts in the dialog. Non-scalable (bitmap) fonts are removed from the list.
Options.fdShowHelp
Displays a Help button in the dialog.
Options.fdTrueTypeOnly
Displays only TrueType fonts in the dialog. Other fonts are not listed.
Options.fdWysiwyg
Displays only fonts that are available to both the printer and the screen. Device-specific fonts are not listed in the dialog.
Options.frDisableMatchCase
Disables (grays) the Match Case check box in a find dialog.
Options.frDisableUpDown
Disables (grays) the Up and Down buttons, which determine the direction of the search.
Options.frDisableWholeWord
Disables (grays) the Match Whole Word check box of find dialog.
Options.frDown
Selects the Down button by default when the dialog opens. If the frDown flags is off, Up is selected when the dialog opens. (By default, frDown is on.)
Options.frFindNext
This flag is turned on when the user clicks the Find Next button and turned off when the dialog closes.
Options.frHideMatchCase
Removes the Match Case check box from the dialog.
Options.frHideUpDown
Removes the Up and Down buttons from the dialog.
Options.frHideWholeWord
Removes the Match Whole Word check box from the dialog.
Options.frMatchCase
This flag is turned on (off) when the user selects (deselects) the Match Case check box. To select the check box by default when the dialog opens, set frMatchCase at design time.
Options.frReplace
Applies to TReplaceDialog only. This flag is set by the system to indicate that the application should replace the current occurrence (and only the current occurrence) of the FindText string with the ReplaceText string. Not used in search routines.
Options.frReplaceAll
Applies to TReplaceDialog only. This flag is set by the system to indicate that the application should replace all occurrences of the FindText string with the ReplaceText string.
Options.frShowHelp
Options.frWholeWord
This flag is turned on (off) when the user selects (deselects) the Match Whole Word check box. To select the check box by default when the dialog opens, set frWholeWord at design time.
Options.ofAllowMultiSelect
Allows users to select more than one file in the dialog.
Options.ofCreatePrompt
Generates a warning message if the user tries to select a nonexistent file, asking whether to create a new file with the specified name.
Options.ofDontAddToRecent
Prevents the file from being added to the list of recently opened files.
Options.ofEnableIncludeNotify
(Windows 2000 and later.) Sends CDN_INCLUDEITEM notification messages to the dialog when the user opens a folder. A notification is sent for each item in the newly opened folder. It is also possible to use these messages to control which items appear in the folder’s item list.
Options.ofEnableSizing
(Windows 98 and later) Lets the Explorer-style dialog be resized with the mouse or keyboard. By default, the dialog allows this resizing regardless of the value of this option. It is only required when a hook procedure or custom template is provided (old style dialogs never permit resizing).
Options.ofExtensionDifferent
This flag is turned on at runtime whenever the selected filename has an extension that differs from DefaultExt. Remember to reset it if this flag is used in an application.
Options.ofFileMustExist
Generates an error message if the user tries to select a nonexistent file. (only applies to Open dialogs).
Options.ofForceShowHidden
Ensures that hidden files are visible in the dialog.
Options.ofHideReadOnly
Removes the Open As Read Only check box from the dialog.
Options.ofNoChangeDir
After the user clicks OK, resets the current directory to whatever it was before the file-selection dialog opened.
Options.ofNoDereferenceLinks
Disables dereferencing of Windows shortcuts. If the user selects a shortcut, assigns to FileName the path and file name of the shortcut itself (the .LNK file), rather than the file linked to the shortcut.
Options.ofNoLongNames
Displays 8.3-character file names only. This option is only valid if Options also includes ofOldStyleDialog.
Options.ofNoNetworkButton
Removes the Network button (which opens a Map Network Drive dialog) from the file-selection dialog. Applies only if the ofOldStyleDialog flag is on.
Options.ofNoReadOnlyReturn
Generates an error message if the user tries to select a read-only file.
Options.ofNoTestFileCreate
Disables checking for network file protection and inaccessibility of disk drives. Applies only when the user tries to save a file in a create-no-modify shared network directory.
Options.ofNoValidate
Disables checking for invalid characters in file names. Allows selection of file names with invalid characters.
Options.ofOldStyleDialog
Creates the older style of file-selection dialog.
Options.ofOverwritePrompt
Generates a warning message if the user tries to select a file name that is already in use, asking whether to overwrite the existing file. (Use with save dialogs.)
Options.ofPathMustExist
Generates an error message if the user tries to select a file name with a nonexistent directory path.
Options.ofReadOnly
Selects the Open As Read Only check box by default when the dialog opens.
Options.ofShareWare
Ignores sharing errors and allows files to be selected even when sharing violations occur.
Options.ofShowHelp
Options.poDisablePrintToFile
Disables (grays) the Print To File Check box. (Applicable only if the poPrintToFile flag is set.)
Options.poHelp
Displays a Help button in the dialog. May not work in some versions of Windows 95.
Options.poPageNums
Enables the Pages radio button, allowing the user to specify a page range.
Options.poPrintToFile
Displays a Print To File check box in the dialog.
Options.poSelection
Enables the Selection radio button, allowing the user to print selected (highlighted) text.
Options.poWarning
Generates a warning message if the user tries to send a job to an uninstalled printer.
OptionsEx
Use the OptionsEx property to further customize the file open dialog beyond the options covered by the Options property.
OptionsEx.ofExNoPlacesBar
Setting ofExNoPlacesBar to True hides the “Places Bar”. The “Places Bar” provides shortcuts to places on the computer or the network from which a file can be opened, such as the History folder, the desktop, or My Network Places.
Orientation
Specifies whether the track bar is horizontal or vertical.
OwnerDraw
Set OwnerDraw to true to enable events that allow the control to draw itself by overriding any default painting behavior.
PageSize
Specifies the amount Position is changed when the PageUp or PageDown key is pressed, or when the bar is clicked.
ParamCheck (Query)
Specifies whether the parameter list for a query is regenerated if the SQL property changes at runtime.
Parameters
At design-time, use Parameters to access the parameters for the SQL statement used by the ADO component. Use the properties and methods of Parameters to set and get individual parameter values or to set or inspect parameter attributes. At runtime, use the Parameters property editor to access the collection of parameters.
Params (Database)
Contains database connection parameters for the Borland Database Engine (BDE) alias associated with the database component.
Params (Query)
Contains the parameters for a query’s SQL statement.
ParentBackground
Determines whether control uses parent’s theme background. If ParentBackground is true, the control uses the parent’s theme background to draw its own background. ParentBackground has no effect unless XP themes are enabled.
ParentBiDiMode
Specifies whether the control uses its parent’s BiDiMode.
ParentColor
Determines where a control looks for its color information. To have a control use the same color as its parent control, set ParentColor to True. If ParentColor is False, the control uses its own Color property.
ParentCtl3D
Determines where a component looks to determine if it should appear three dimensional.
ParentFont
Determines where a control looks for its font information. To have a control use the same font as its parent control, set ParentFont to True. If ParentFont is False, the control uses its own Font property.
ParentShowHint
Determines where a control looks to find out if its Help Hint should be shown.
ParseInput
Enables the OnUserInput event. If ParseInput is true, the OnUserInput event occurs whenever the user types into the component’s edit box.
PasswordChar
Indicates the character, if any, to display in place of the actual characters typed in the control.
PersonInfo
List with information about the person selected from Object Store.
picFilename
Contains the path to the image/map/video that the control contains.
Specifies the image that appears on the image control.
Pool
The Viz Engine pool that the item selector should display (like SCENE, GEOM, FONT etc).
PopupMenu
Identifies the pop-up menu associated with the control.
Position
Contains the current position of the slider of a TTrackBar.
Prefix
Specifies the prefix for a save name.
Prepared
Set Prepared before calling the Open method to specify whether ADO prepares the command used to create the data set’s record set. If Prepared is set to true and the data set component is connected to a data store, ADO prepares the command before executing it. If Prepared is set to false, ADO does not prepare the command. The default value of Prepared is false.
PrintRange
The value of PrintRange corresponds the All, Selection, and Pages (From/To) radio buttons in the Print dialog.
PrintToFile
PrintToFile is true whenever the Print To File check box is selected in the dialog.
Proportional
Indicates whether the image should be changed, without distortion, so that it fits the bounds of the image control.
Provider
Set Provider to indicate the provider the ADO connection object uses. The provider a connection is to use can also be specified in the string entered in ConnectionString. If Provider is left blank and the provider specified through ConnectionString, when the connection is activated the Provider property is automatically set indicating the provider used.
RaggedRight
Specifies whether rows of tabs stretch to fill the width of the control.
RDSConnection
Use RDSConnection to specify the RDS connection component to use to obtain the record set when the TADODataSet is opened. This property is mutually exclusive of the Connection property.
ReadOnly
Determines whether the user can change the text of the edit control.
ReadOnly (Database)
Specifies that the database connection provides read-only access.
ReplaceText
ReplaceText, taken from the Replace With edit box, contains the text string that will replace FindText.
RequestLive (Query)
Specifies whether an application expects to receive a live result set from the Borland Database Engine (BDE) when the query executes.
RequiredKeyWords
Defines the required keywords used when searching for media content. This is currently relevant for Object Store searches only.
RequiredKeyWordsMode
Sets the options RequireOne or RequireAll. Searches can be performed with information from the RequiredKeyWords field.
RTL
Right to left reading.
RTL.rtlReading
Specifies that the text is displayed with right to left reading order.
RTL.rtlReading
The text is right-aligned.
ReverseSorting
Indicates if reverse sorting is active.
SaveNameTextFields
Click the ellipsis button to bring up and editor where you can select the edit boxes that should be used for generating a save name.
ScrollBars
Determines whether the memo control has any scroll bars.
ScrollOpposite
Determines how the rows of tabs are scrolled in a multiline tab control.
ScrollWidth
Specifies the width, in pixels, by which the list box can scroll horizontally.
SelEnd
Specifies the position of the end point of the selection range.
SelectedPath
The Viz Engine path of the selected item.
SelStart
Specifies the position of the starting point of the selection range.
SendSJIS
Sends the text in the text box as SJIS (character encoding for the Japanese language).
SendUTF8
Sends the text in the text box as UTF-8 (universal character encoding).
Seperator
Specifies the size of the tabs in e.g. a list box or page control.
SessionName (Query/Database)
Identifies the name of the session with which this data set is associated.
ShowAccelChar
Determines how an ampersand (&) in the label text is displayed. Set ShowAccelChar to True to allow the label to display an underlined accelerator key value. When ShowAccelChar is True, any character preceded by an ampersand appears underlined. If the FocusControl property is set, the windowed control specified by the FocusControl property receives input focus when the user types that underlined character. To display an ampersand when ShowAccelChar is True, use two ampersands (&&) to stand for the single ampersand that is displayed. Set ShowAccelChar to False to display the label text with all ampersands appearing as ampersands. When ShowAccelChar is False, the value of the FocusControl property is not used.
ShowHint
Determines whether the control displays a Help Hint when the mouse pointer rests momentarily on the control.
ShowProximitySelector
Specifies if the control should show a Proximity selection button.
ShowSaveDialog
Determines whether Director should show the save dialog when saving the template.
ShowTimeStamp
Indicates if the control will show timestamp.
SliderVisible
Specifies whether the slider should be visible or not.
SortByDate
Sort entries by date.
SortByName
Sort entries by name.
Sorted
Specifies whether the items in a list box or combo box are arranged alphabetically.
Source
Spacing
Spacing determines the number of pixels between the image (specified in the Glyph property) and the text (specified in the Caption property). The default value is 4 pixels.
SQL (query)
Contains the text of the SQL statement to execute for the query.
State
Indicates whether the check box is selected, deselected, or grayed.
StoreDefs (Table)
Indicates whether the table’s field and index definitions persist with the data module or form.
StoryActions
Click the ellipsis button to bring up and editor where you can select and order the edit boxes that should get the data we receive externally.
Stretch
Indicates whether the image should be changed so that it exactly fits the bounds of the image control.
Strings
List of strings.
Style
Determines the style of a list box or combo box.
TableDirect
Use TADOTable to access data in a single database table using ADO. TADOTable provides direct access to every record and field in an underlying database table. An ADO table component can also work with a subset of records within a database table using ranges and filters.
TableName
Use TableName to specify the base table in a database on which the ADO table component operates. Data is retrieved from and changes written to this base table. Before setting or changing the value of TableName, deactivate the ADO table component by calling its Close method or setting its Active property to false. At design-time, if a valid connection to a database can be established, the Object Inspector provides a drop-down list of names of available tables.
TableType (Table)
Indicates the database table structure for the table that this component represents.
TabHeight
TabIndex
Specifies the order of the tabs in e.g. a list box or page control.
TabOrder
Indicates the position of the control in its parent’s tab order. TabOrder is the order in which child windows are visited when the user presses the Tab key. In most applications, the control with the TabOrder value of 0 is the control that has the focus when the form first appears. In Pilot News however, it is the text box with the smallest TabOrder that has the initial focus.
TabPosition
Specifies the position of the tabs in e.g. a list box or page control.
TabStop
Determines if the user can tab to a control.
TabWidth
Tag
Stores an integer value as part of a component. Tag has no predefined meaning. The Tag property is provided for the convenience of developers. It can be used for storing an additional integer value or it can be typecast to any 32-bit value such as a component reference or a pointer.
Text
Contains a text string associated with the control.
ThumbLength
Specifies the size of the slider.
TickMarks
Specifies where the slider ticks are shown.
TickStyle
Specifies how tick marks are placed on the track bar.
Title
Use Title to return or set the title caption for the dialog box.
Top
Specifies the Y coordinate of the top left corner of a control, relative to its parent or containing control in pixels.
ToPage
The ToPage property corresponds to the To field in the Print dialog.
TransIsolation (Database)
Specifies the transaction isolation level for transactions managed by the Borland Database Engine (BDE).
Transparent (Label)
Specifies whether controls that sit below the label on a form can be seen through the label.
Transparent
Specifies whether the background of the image obscures objects below the image object.
TWImageInfComponent
UHPathIsRelative
If true, then the path in UpdateHubPath is considered relative to the current position in the UpdateHub tree. Otherwise, it is treated as an absolute path.
UpdateHubPath
The path in the UpdateHub that control edits or displays.
UTF8Items
The items in the control represented as a list of UTF-8 strings.
UTF8Text
Defines the character encoding. UTF-8 is a variable-length character encoding for Unicode, representing any universal character in the Unicode standard, and contains virtually all characters in common use.
UniDirectional (Query)
Determines whether or not Borland Database Engine (BDE) bidirectional cursors are enabled for a query’s result set.
UnixShare
UpdateMode (DataSet/Query/Table)
Determines how the Borland Database Engine (BDE) finds records when updating to an SQL database.
UpdateObject (DataSet/Query)
Specifies the update object component used to update a read-only result set when cached updates are enabled.
UseDockManager
Use UseDockManager to get or set whether a docking manager is used in drag-and-dock operations.
UseUTF8UnicodeProperty
When the DirectStoryImporter receives data and sets text into the various text boxes, this property determines if it will use the .text or the .utf8text property of the edit fields.
Value
Specifies the value.
VertScrollBar
Vertical scrollbar properties.
VertScrollBar. ParentColor
VertScrollBar.Position
VertScrollBar.Range
Visible
Determines whether the component appears on screen.
VizDenyBrowseUp
Indicates if the user should be allowed to navigate up in the Viz Engine tree when selecting a Viz resource in an image control. Note that VizDenyBrowseUp is ignored in Director. This means that while users of Viz Pilot News inside a Newsroom System are limited by the VizDenyBrowseUp property, users of Director are considered graphics/video/maps super users and can use any image in the Director template.
VizStartDir
Starting location in the Viz Engine tree when selecting a Viz resource in an image control. Only considered if there is no pre-selected value in the control and, in Pilot News, also when VizDenyBrowseUp is set and the pre-selected value is not within the folder specified here.
VizText
WantReturns
Determines whether the user can insert return characters into the text.
WantTabs
Determines whether the user can insert tab characters into the text.
Width
Specifies the horizontal size of the control or form in pixels.
WordWrap
Determines whether the edit control inserts soft carriage returns so text wraps at the right margin.
XValue
Value for X.
YValue
Value for Y.
ZValue
Value for Z.
