Database Configuration
Most features of the Viz Pilot system require a database connection, usually an Oracle database. However, Viz Pilot 7.0 and later support using Graphic Hub as a database.
Comparison of Oracle Database vs Graphic Hub Database
  • Oracle is designed for performance when handling large amounts of data. Graphic Hub is designed for ease of use and low maintenance costs.
  • There are more options for tuning and customization with Oracle. Graphic Hub just works out of the box.
  • The main reason for using Graphic Hub as the database is ease of setup and maintenance. Viz Pilot systems typically have a Graphic Hub. Moving the database into it a Graphic Hub rather than an Oracle database means there is one less component to install and maintain.
  • Graphic Hub comes with its own tools for maintenance tasks, such as importing and exporting data, backup and replication. With Graphic Hub there’s no need to keep a dedicated database administrator.
  • Object Store is not supported by Graphic Hub.
