Database Connection Parameters
Pilot DBA (Pilot Database Administrator tool) is used by database administrators to maintain and upgrade the Viz Pilot database system. It also enables the database administrator to check the current status of the database.
Parameter
Value
Oracle system identifier (SID/Service name)
VIZRTDB
All system users (default)
system/oraclesys/oracle
All users (default)
PILOT/PILOT
Database schema (default)
PILOT
Important! Vizrt does not support installations on express edition (XE) databases.
Getting Started - Pilot DBA
  1. Browse to the location where you extracted the Pilot DBA files. See Pilot DBA Installation.
  2. Double-click the Pilot DBA executable file to start the application.
    Note: Make sure Viz Engine is configured and running.
  • For information on installing an Oracle database server, see the documentation supplied by Oracle.
