Version 3.7 | Published August 05, 2022 ©
List of Ports Used for Graphic Hub Network Connectivity
Since Graphic Hub 3, the server requires a limited number of open network ports. The following table lists the ports used for Graphic Hub server connectivity:
Port Number
Protocol
Used for
427
TCP, UDP
OpenSLP
19390
TCP
ImEx Agent (HTTP)
19391
TCP, UDP
Deploy Agent High Availability
19392
UDP
Deploy Agent
19393
TCP
Deploy Agent
19394
UDP
Manager for Terminal 2
19395
TCP
Terminal 2
19396
TCP, UDP
Naming service
19397
TCP, UDP
Graphic Hub
19398
TCP
REST (HTTP)
19399
TCP
Terminal 3 (HTTP)
Since GH Deploy Agent 2, Graphic Hub Manager 5, GH REST 2, and Viz Artist 3.8.2, these clients do not require any port exemption rules on the client side firewall configuration. However, for earlier versions, all ports must be open on the client side.
