![](assets/images/logos/GraphicsPlugin.png)
Version 2.5 | Published March 06, 2024 ©
Optimizing System Processing
Despite an optimally configured Graphics Plugin, users may still experience performance issues. One important factor is the size of the project. Working on a fully interlaced HD (1080i) project uses more resources than PAL or NTSC.
When there is a mismatch between video size and the timeline/project settings, the NLE system might need to re-scale graphics and video, which is a costly process. Rendering on a video that resides on a shared drive on the network also utilizes valuable network capacity.
For example, an interlaced HD project with a well-configured Graphics Plugin has an effect added to a layer above the video, and rendering is started. The following happens:
The NLE system requests a frame,
Receives it from Graphics Plugin,
Processes the graphics and possibly caches the data on disk.
These steps are then repeated for each frame. Steps 1 to 2 might only take 20 milliseconds (ms); however, the time from 2 to 3 can be as much as 600-1000 ms. Ensuring that the video size, format, project, and timeline settings correspond with each other, and that rendering is done locally on a fast disk is therefore very beneficial. Although the performance analysis reports that everything is fine, the system as a whole might be slow due to slow hardware on the NLE system.
