Version 2.2 | Published May 02, 2024 ©
Clock Behavior and Resolution
The clock is a very important component of Channel Recorder. If no clock is present Channel Recorder might fail in performing scheduled, loop or frame accurate recordings. There are four sources of resolution: input, genlock, configuration and internal.
For clock type GENLOCK, the priority is given in the following order:
  • Input
  • Genlock
  • Configuration
  • Internal
For clock type INPUT, the priority is given in the following order:
  • Input
  • Configuration
Important points to remember are:
  • The resolution from the configuration is only used when there is no input or genlock signal detected.
  • Internal resolution is only relevant when the following is true:
    • There is another application using Matrox board.
    • The application in question is using a different frame rate family.
  • Clock type INPUT is the simplest and should be used unless there is a compelling reason not to use it.
Note: For IP boards, 2059 is used by default.
