Version 2.2 | Published May 02, 2024 ©
Supported Codecs
The Channel Recorder supports the following containers and codecs.
Note: If a combination of CODEC / CONTAINER / RESOLUTION is not supported, Channel Recorder floods the logs with errors. If this happens stop the recording using RECORD STOP. Please make sure that the mentioned combination are supported by consulting the tables below.
Note: Only the containers AVCINTRAMXF, DVCPROMXF, XDCAMMXF, XAVCMXF support capturing of closed captions. The closed captions must be part of SMPTE 334M CDP. The captured close caption is found in the recorded clip in the wrapper according to SMPTE 436M and in the actual MXF essence.
Note: The examples below are not exhaustive. Some parameters such as the number of audio channels have other options.
PAL Codecs
MPEG-IFrame
Container
Codec
Features
Audio
VizSend Example
MVCP Example
.avi
MPEG2-IFrame422
720x576
Alpha: No
Bitrate: 10-50
Bit depth: 8
VBI: N/A
Timecode: N/A
TDIR: Yes
No Audio
PCM:
  • 2 ch: 24 in 32-bit; 48kHz
  • 4 ch: 24 in 32-bit; 48kHz
  • 8 ch: 24 in 32-bit; 48kHz
  • 16 ch: 24 in 32-bit; 48kHz
CONFIG SET CODEC IFrame
CONFIG SET CONTAINER AVI
CONFIG SET AUDIOCHANNELS 8
RECORD CLIP clip
RECORD START
Specifying this codec / container combination is not supported through MVCP.
If this codec / container combination is required then the web interface can be used to configure Channel Recorder. When sending MVCP commands, however, the codec / container must not be specified via vtr.media.video.input.compression.type.
DVCAM
Container
Codec
Features
Audio
VizSend Example
MVCP Example
.avi
DV/DVCAM 4:2:0
720x576
Alpha: No
Bitrate: 25
Bit depth: 8
VBI: N/A
Timecode: N/A
TDIR: Yes
CC: No
No Audio
PCM:
CONFIG SET CODEC DvCam
RECORD CLIP clip
RECORD START
.mov
DVCAM 4:2:0
720x576
Alpha: No
Bitrate: 25
Bit depth: 8
VBI: N/A
Timecode: N/A
TDIR: N/A
CC: No
No Audio
PCM:
CONFIG SET CONTAINER MOV
RECORD CLIP clip
RECORD START
.mxf
Panasonic P2 (OP-Atom)
DVCAM 4:2:0
720x576
Alpha: No
Bitrate: 25
Bit depth: 8
VBI: N/A
Timecode: Yes
TDIR: Yes
CC: No
No Audio
CONFIG SET CONTAINER MXF
RECORD CLIP clip
RECORD START
Information: Video bitrate is 25, but the encoded bitrate is 28.75 (15% more) which includes other data.
DVCPRO
Container
Codec
Features
Audio
VizSend Example
MVCP Example
.avi
DVCPRO 4:1:1
720x576
Alpha: No
Bitrate: 25
Bit depth: 8
VBI: N/A
Timecode: N/A
TDIR: Yes
CC: No
No Audio
PCM:
CONFIG SET CODEC DvCPro
RECORD CLIP clip
RECORD START
.avi
DVCPRO 50 4:2:2
720x576
Alpha: No
Bitrate: 50
Bit depth: 8
VBI: N/A
Timecode: N/A
TDIR: Yes
CC: No
No Audio
PCM:
CONFIG SET CODEC Dv50
RECORD CLIP clip
RECORD START
.mov
DVCPRO 4:1:1
720x576
Alpha: No
Bitrate: 25
Bit depth: 8
VBI: N/A
Timecode: N/A
TDIR: N/A
CC: No
No Audio
PCM:
RECORD CLIP clip
RECORD START
.mov
DVCPRO 50 4:2:2
720x576
Alpha: No
Bitrate: 50
Bit depth: 8
VBI: N/A
Timecode: N/A
TDIR: N/A
CC: No
No Audio
PCM:
RECORD CLIP clip
RECORD START
.mxf (OP1a)
DVCPRO 4:1:1
720x576
Alpha: No
Bitrate: 25
Bit depth: 8
VBI: N/A
Timecode: Yes
TDIR: Yes
CC: Yes
PCM:
CONFIG SET CONTAINER DVCPROMXF
RECORD CLIP clip
RECORD START
UADD CS_ENCODER1 * SHAR dart
SET U1 MED vtr.media.video.input.compression.type "dvcpro"
SET U1 MED vtr.media.mpeg.bit_rate "25000000"
SET U1 MED vtr.media.audio.input.channels "8"
CUER U1
REC U1
.mxf (OP1a)
DVCPRO 50 4:2:2
720x576
Alpha: No
Bitrate: 50
Bit depth: 8
VBI: N/A
Timecode: Yes
TDIR: Yes
CC: Yes
PCM:
RECORD CLIP clip
RECORD START
SET U1 MED vtr.media.mpeg.bit_rate "50000000"
CUER U1
REC U1
.mxf Panasonic P2 (OP-Atom)
DVCPRO 4:1:1
720x576
Alpha: No
Bitrate: 25
Bit depth: 8
VBI: N/A
Timecode: N/A
TDIR: Yes
CC: No
No Audio
RECORD CLIP clip
RECORD START
DVCPRO 50 4:2:2
720x576
Alpha: No
Bitrate: 50
Bit depth: 8
VBI: N/A
Timecode: N/A
TDIR: Yes
CC: No
No Audio
RECORD CLIP clip
RECORD START
Information: Video bitrate is 25, but the encoded bitrate is 28.75 (15% more) which includes other data. The same applies for 50 bitrate. The encoded bitrate is 57.6 (15% more).
XDCAM
Container
Codec
Features
Audio
VizSend Example
MVCP Example
.mxf XDCAM (OP1a)
D10 (IMX50) 4:2:2
720x608
Alpha: No
Bitrate: 50
Bit depth: 10
VBI: required
Timecode: required
TDIR: Yes
CC: Yes
AES3:
  • 4ch: 24 in 32-bit; 48kHz
  • 8ch: 24 in 32-bit; 48kHz
CONFIG SET CODEC XDCam
CONFIG SET CONTAINER XDCAMMXF
CONFIG SET BITRATE 50
CONFIG SET AUDIOCHANNELS 4
RECORD CLIP clip
RECORD START
SET U1 MED vtr.media.video.input.compression.type "mpeg2"
SET U1 MED vtr.media.audio.input.channels "4"
CUER U1
REC U1
Container
Codec
Features
Audio
VizSend Example
MVCP Example
.mxf XDCAM (OP1a)
D10 (IMX40) 4:2:2
720x608
Alpha: No
Bitrate: 40
Bit depth: 10
VBI: required
Timecode: required
TDIR: Yes
CC: Yes
AES3:
CONFIG SET BITRATE 40
RECORD CLIP clip
RECORD START
SET U1 MED vtr.media.mpeg.bit_rate "40000000"
CUER U1
REC U1
Container
Codec
Features
Audio
VizSend Example
MVCP Example
.mxf XDCAM (OP1a)
D10 (IMX30) 4:2:2
720x608
Alpha: No
Bitrate: 40
Bit depth: 10
VBI: required
Timecode: required
TDIR: Yes
CC: Yes
AES3:
RECORD CLIP clip
RECORD START
SET U1 MED vtr.media.mpeg.bit_rate "30000000"
CUER U1
REC U1
NTSC Codecs
MPEG IFrame
Container
Codec
Features
Audio
VizSend Example
MVCP Example
.avi
MPEG2-IFrame422
720x480
Alpha: No
Bitrate: 10-50
Bit depth: 8
VBI: N/A
Timecode: N/A
TDIR: Yes
CC: No
No Audio
PCM:
RECORD CLIP clip
RECORD START
DVCAM
Container
Codec
Features
Audio
VizSend Example
MVCP Example
.avi
DV/DVCAM 4:1:1
720x480
Alpha: No
Bitrate: 25
Bit depth: 8
VBI: N/A
Timecode: N/A
TDIR: Yes
CC: No
No Audio
PCM:
RECORD CLIP clip
RECORD START
.mov
DVCAM 4:1:1
720x480
Alpha: No
Bitrate: 25
Bit depth: 8
VBI: N/A
Timecode: N/A
TDIR: N/A
CC: No
No Audio
PCM:
RECORD CLIP clip
RECORD START
.mxf
Panasonic P2
(OP-Atom)
DVCAM 4:1:1
720x480
Alpha: No
Bitrate: 25
Bit depth: 8
VBI: N/A
Timecode: Yes
TDIR: N/A
CC: No
No Audio
RECORD CLIP clip
RECORD START
DVCPRO
Container
Codec
Features
Audio
VizSend Example
MVCP Example
.avi
DVCPRO 4:1:1
720x480
Alpha: No
Bitrate: 25
Bit depth: 8
VBI: N/A
Timecode: N/A
TDIR: Yes
CC: No
No Audio
PCM:
RECORD CLIP clip
RECORD START
.avi
DVCPRO 50 4:2:2
720x480
Alpha: No
Bitrate: 50
Bit depth: 8
VBI: N/A
Timecode: N/A
TDIR: Yes
CC: No
No Audio
PCM:
RECORD CLIP clip
RECORD START
.mov
DVCPRO 4:1:1
720x480
Alpha: No
Bitrate: 25
Bit depth: 8
VBI: N/A
Timecode: N/A
TDIR: N/A
CC: No
No Audio
PCM:
RECORD CLIP clip
RECORD START
.mov
DVCPRO 50 4:2:2
720x480
Alpha: No
Bitrate: 50
Bit depth: 8
VBI: N/A
Timecode: N/A
TDIR: N/A
CC: No
No Audio
PCM:
RECORD CLIP clip
RECORD START
.mxf (OP1a)
DVCPRO 4:1:1
720x480
Alpha: No
Bitrate: 25
Bit depth: 8
VBI: N/A
Timecode: N/A
TDIR: Yes
CC: Yes
PCM:
RECORD CLIP clip
RECORD START
CUER U1
REC U1
.mxf (OP1a)
DVCPRO 50 4:2:2
720x480
Alpha: No
Bitrate: 50
Bit depth: 8
VBI: N/A
Timecode: N/A
TDIR: Yes
CC: Yes
PCM:
RECORD CLIP clip
RECORD START
CUER U1
REC U1
DVCPRO 4:1:1
720x480
Alpha: No
Bitrate: 25
Bit depth: 8
VBI: N/A
Timecode: N/A
TDIR: Yes
CC: No
No Audio
RECORD CLIP clip
RECORD START
DVCPRO 50 4:2:2
720x480
Alpha: No
Bitrate: 50
Bit depth: 8
VBI: N/A
Timecode: N/A
TDIR: Yes
CC: No
No Audio
RECORD CLIP clip
RECORD START
XDCAM
Container
Codec
Features
Audio
VizSend Example
MVCP Example
.mxf XDCAM (OP1a)
D10 (IMX50) 4:2:2
720x512
Alpha: No
Bitrate: 50
Bit depth: 10
VBI: Required
Timecode: Required
TDIR: Yes
CC: Yes
AES3:
RECORD CLIP clip
RECORD START
CUER U1
REC U1
Container
Codec
Features
Audio
VizSend Example
MVCP Example
.mxf XDCAM (OP1a)
D10 (IMX40) 4:2:2
720x512
Alpha: No
Bitrate: 40
Bit depth: 10
VBI: Required
Timecode: Required
TDIR: Yes
CC: Yes
AES3:
RECORD CLIP clip
RECORD START
CUER U1
REC U1
Container
Codec
Features
Audio
VizSend Example
MVCP Example
.mxf XDCAM (OP1a)
D10 (IMX30) 4:2:2
720x512
Alpha: No
Bitrate: 30
Bit depth: 10
VBI: Required
Timecode: Required
TDIR: Yes
CC: Yes
AES3:
CONFIG SET BITRATE 30
RECORD CLIP clip
RECORD START
CUER U1
REC U1
720p50 and 720p59.94 (60M) Codecs
MPEG-IFrame
Container
Codec
Features
Audio
VizSend Example
MVCP Example
.avi
MPEG2-IFrame422
1280x720
Alpha: No
Bitrate: 50-300
Bit depth: 8
VBI: N/A
Timecode: N/A
TDIR: Yes
CC: No
No Audio
PCM:
RECORD CLIP clip
RECORD START
DVCPRO HD
Container
Codec
Features
Audio
VizSend Example
MVCP Example
.avi
DVCPRO HD
1280x720
Alpha: No
Bitrate: 100-115
Bit depth: 8
VBI: N/A
Timecode: N/A
TDIR: Yes
CC: No
No Audio
PCM:
RECORD CLIP clip
RECORD START
.mov
DVCPRO HD
960x720
Alpha: No
Bitrate: 100-115
Bit depth: 8
VBI: N/A
Timecode: N/A
TDIR: N/A
CC: No
No Audio
PCM:
RECORD CLIP clip
RECORD START
.mxf (OP1a)
DVCPRO HD
960x720
Alpha: No
Bitrate: 100-115
Bit depth: 8
VBI: N/A
Timecode: Yes
TDIR: Yes
CC: Yes
PCM:
RECORD CLIP clip
RECORD START
CUER U1
REC U1
.mxf
DVCPRO HD
960x720
Alpha: No
Bitrate: 100-115
Bit depth: 8
VBI: N/A
Timecode: N/A
TDIR: Yes
CC: No
No Audio
RECORD CLIP clip
RECORD START
XDCAM HD 422
Container
Codec
Features
Audio
VizSend Example
MVCP Example
.mxf (OP1a)
XDCAM HD 422
1280x720
Alpha: No
Bitrate: 50
Bit depth: 8
VBI: N/A
Timecode: Yes
TDIR: Yes
CC: Yes
No Audio
PCM:
RECORD CLIP clip
RECORD START
SET U1 MED vtr.media.video.input.compression.type "mpeg2-ibp-422p@hl"
CUER U1
REC U1
XDCAM EX HQ
Container
Codec
Features
Audio
VizSend Example
MVCP Example
.mxf (OP1a)
XDCAM EX HQ
1280x720
Alpha: No
Bitrate: 35
Bit depth: 8
VBI: N/A
Timecode: Yes
TDIR: Yes
CC: Yes
No Audio
PCM:
  • 2 ch: 16 in 16-bit; 48kHz
  • 4 ch: 16 in 16-bit; 48kHz
  • 8 ch: 16 in 16-bit; 48kHz
  • 16 ch: 16 in 16-bit; 48kHz
CONFIG SET CODEC XDCamEX
RECORD CLIP clip
RECORD START
AVC-Intra
Container
Codec
Features
Audio
VizSend Example
MVCP Example
.mxf (OP1a)
AVCIntra Class 50
960x720
Alpha: No
Bitrate: 50
Bit depth: 8
VBI: N/A
Timecode: Yes
TDIR: Yes
CC: Yes
PCM:
CONFIG SET CODEC AVCIntra50
CONFIG SET CONTAINER AVCINTRAMXF
RECORD CLIP clip
RECORD START
SET U1 MED vtr.media.video.input.compression.type "avc-intra"
CUER U1
REC U1
.mxf (OP1a)
AVCIntra Class 100
1280x720
Alpha: No
Bitrate: 100
Bit depth: 8
VBI: N/A
Timecode: Yes
TDIR: Yes
CC: Yes
PCM:
CONFIG SET CODEC AVCIntra100
CONFIG SET BITRATE 100
RECORD CLIP clip
RECORD START
SET U1 MED vtr.media.mpeg.bit_rate "100000000"
CUER U1
REC U1
AVCIntra Class 50
960x720
Alpha: No
Bitrate: 50
Bit depth: 8
VBI: N/A
Timecode: N/A
TDIR: Yes
CC: No
No Audio
RECORD CLIP clip
RECORD START
AVCIntra Class 100
1280x720
Alpha: No
Bitrate: 100
Bit depth: 8
VBI: N/A
Timecode: N/A
TDIR: Yes
CC:No
No Audio
RECORD CLIP clip
RECORD START
ProRes
Container
Codec
Features
Audio
VizSend Example
MVCP Example
.mov
I-Frame 4:2:2
1280x720
Alpha: No
Bitrate: 100 (LT), 147, 220 (HQ)
Bit depth: 10
VBI: N/A
Timecode: N/A
TDIR: Yes, with .ref file
CC: No
No Audio
PCM:
CONFIG SET CODEC ProRes
RECORD CLIP clip
RECORD START
DNxHD
Container
Codec
Features
Audio
VizSend Example
MVCP Example
.mxf (OP1a)
DNxHD (50) 120, 175
DNxHD (59.94) 145, 220
1280x720
Alpha: No
Bitrate (50): 120,175
Bitrate (59.94): 145,220
Bit depth: 8
VBI: N/A
Timecode: N/A
CC: No
No Audio
PCM:
CONFIG SET CODEC DNxHD
CONFIG SET CONTAINER DNXHDMXF
CONFIG SET BITRATE 120
RECORD CLIP clip
RECORD START
.mxf (OP1a)
DNxHD (50) 175x
DNxHD (59.94) 220x
1280x720
Alpha: No
Bitrate (50): 175x
Bitrate (59.94): 220x
Bit depth: 10
VBI: N/A
Timecode: N/A
CC: No
No Audio
PCM:
CONFIG SET BITRATE 175
RECORD CLIP clip
RECORD START
DNxHD (50) 120, 175
1280x720
Alpha: No
Bit depth: 8
VBI: N/A
Timecode: N/A
CC: No
No Audio
RECORD CLIP clip
RECORD START
DNxHD (50) 175x
DNxHD (59.94) 220x
1280x720
Alpha: No
Bitrate (50): 175x
Bit depth: 10
VBI: N/A
Timecode: N/A
CC: No
No Audio
RECORD CLIP clip
RECORD START
XAVC
Container
Codec
Features
Audio
VizSend Example
MVCP Example
.mxf (OP1a)
XAVC
Alpha: No
Bitrate: 100
Bit depth: 10
VBI: N/A
Timecode: Yes
TDIR: Yes
CC: Yes
PCM:
CONFIG SET CODEC XAVC
CONFIG SET CONTAINER XAVCMXF
RECORD CLIP clip
RECORD START
Note: The configuration v210 must be enabled in the configuration section for recording XAVC.
1080i25 and 1080i29.97 (30M) Codecs
MPEG-IFrame
Container
Codec
Features
Audio
VizSend Example
MVCP Example
.avi
MPEG2-IFrame422
1920x1080
Alpha: No
Bitrate: 50-300
Bit depth: 8
VBI: N/A
Timecode: N/A
TDIR: Yes
CC: No
No Audio
PCM:
RECORD CLIP clip
RECORD START
DVCPRO HD
Container
Codec
Features
Audio
VizSend Example
MVCP Example
.avi
DVCPRO HD (25) 1920x1080
DVCPRO HD (29.97) 1260x1080
Alpha: No
Bitrate: 100
Bit depth: 8
VBI: N/A
Timecode: N/A
TDIR: Yes
CC: No
No Audio
PCM:
RECORD CLIP clip
RECORD START
.mov
Alpha: No
Bitrate: 100
Bit depth: 10
VBI: N/A
Timecode: N/A
TDIR: Yes
CC: No
No Audio
PCM:
RECORD CLIP clip
RECORD START
.mxf
Panasonic P2
(OP-Atom)
Alpha: No
Bitrate: 100
Bit depth: 10
VBI: N/A
Timecode: N/A
TDIR: Yes
CC: No
No Audio
RECORD CLIP clip
RECORD START
.mxf (OP1a)
Alpha: No
Bitrate: 100
Bit depth: 10
VBI: N/A
Timecode: Yes
TDIR: Yes
CC: Yes
PCM:
RECORD CLIP clip
RECORD START
CUER U1
REC U1
Information: Video bitrate is 100, but the encoded bitrate is 115 (15% more) which includes other data.
XDCAM HD 422
Container
Codec
Features
Audio
VizSend Example
MVCP Example
.mxf (OP1a)
XDCAM HD 422
1920x1080
Alpha: No
Bitrate: 50
Bit depth: 8
VBI: N/A
Timecode: Yes
TDIR: Yes
CC: Yes
No Audio
PCM:
RECORD CLIP clip
RECORD START
CUER U1
REC U1
XDCAM HD LP
Container
Codec
Features
Audio
VizSend Example
MVCP Example
.mxf (OP1a)
XDCAM HD LP
1440x1080
Alpha: No
Bitrate: 17.5
Bit depth: 8
VBI: N/A
Timecode: Yes
TDIR: Yes
CC: Yes
No Audio
PCM:
CONFIG SET CODEC XDCamHD
CONFIG SET BITRATE 18
RECORD CLIP clip
RECORD START
XDCAM HD SP
Container
Codec
Features
Audio
VizSend Example
MVCP Example
.mxf (OP1a)
XDCAM HD SP
1440x1080
Alpha: No
Bitrate: 25
Bit depth: 8
VBI: N/A
Timecode: Yes
TDIR: Yes
CC: Yes
No Audio
PCM:
CONFIG SET BITRATE 25
RECORD CLIP clip
RECORD START
XDCAM HD HQ
Container
Codec
Features
Audio
VizSend Example
MVCP Example
.mxf (OP1a)
XDCAM HD HQ
1440x1080
Alpha: No
Bitrate: 35
Bit depth: 8
VBI: N/A
Timecode: Yes
TDIR: Yes
CC: Yes
No Audio
PCM:
CONFIG SET BITRATE 35
RECORD CLIP clip
RECORD START
XDCAM EX HQ
Container
Codec
Features
Audio
VizSend Example
MVCP Example
.mxf (OP1a)
XDCAM EX HQ
1920x1080
Alpha: No
Bitrate: 35
Bit depth: 8
VBI: N/A
Timecode: Yes
TDIR: Yes
CC: Yes
No Audio
PCM:
RECORD CLIP clip
RECORD START
AVC-Intra
Container
Codec
Features
Audio
VizSend Example
MVCP Example
.mxf (OP1a)
AVCIntra Class 50
1440x1080
Alpha: No
Bitrate: 50
Bit depth: 8
VBI: N/A
Timecode: Yes
TDIR: Yes
CC: Yes
PCM:
RECORD CLIP clip
RECORD START
CUER U1
REC U1
.mxf (OP1a)
AVCIntra Class 100
1920x1080
Alpha: No
Bitrate: 100
Bit depth: 8
VBI: N/A
Timecode: Yes
TDIR: Yes
CC: Yes
PCM:
RECORD CLIP clip
RECORD START
CUER U1
REC U1
.mxf
Panasonic P2
(OP-Atom)
AVCIntra Class 50
1440x1080
Alpha: No
Bitrate: 50
Bit depth: 10
VBI: N/A
Timecode: N/A
TDIR: Yes
CC: No
No Audio
RECORD CLIP clip
RECORD START
.mxf
Panasonic P2
(OP-Atom)
AVCIntra Class 100
1920x1080
Alpha: No
Bitrate: 100
Bit depth: 10
VBI: N/A
Timecode: N/A
TDIR: Yes
CC: No
No Audio
RECORD CLIP clip
RECORD START
ProRes
Container
Codec
Features
Audio
VizSend Example
MVCP Example
.mov
I-Frame 4:2:2
1920x1080
Alpha: No
Bit depth: 10
VBI: N/A
Timecode: N/A
CC: No
No Audio
PCM:
RECORD CLIP clip
RECORD START
DNxHD
Container
Codec
Features
Audio
VizSend Example
MVCP Example
.mxf (OP1a)
DNxHD (30) 120, 185
DNxHD (29.97) 145, 220
1920x1080
Alpha: No
Bitrate (50): 120,185
Bit depth: 8
VBI: N/A
Timecode: N/A
CC: No
No Audio
PCM:
RECORD CLIP clip
RECORD START
.mxf (OP1a)
DNxHD (30) 185x
DNxHD (29.97) 220x
1920x1080
Alpha: No
Bitrate (50): 185x
Bit depth: 10
VBI: N/A
Timecode: N/A
CC: No
No Audio
PCM:
CONFIG SET BITRATE 185
RECORD CLIP clip
RECORD START
DNxHD (30) 120, 185
1920x1080
Alpha: No
Bit depth: 8
VBI: N/A
Timecode: N/A
CC: No
No Audio
RECORD CLIP clip
RECORD START
DNxHD (30) 185x
DNxHD (29.97) 220x
1920x1080
Alpha: No
Bitrate (50): 185x
Bit depth: 10
VBI: N/A
Timecode: N/A
CC: No
No Audio
RECORD CLIP clip
RECORD START
XAVC
Container
Codec
Features
Audio
VizSend Example
MVCP Example
.mxf (OP1a)
XAVC
Alpha: No
Bitrate: 100
Bit depth: 10
VBI: N/A
Timecode: Yes
TDIR: Yes
CC: Yes
PCM:
RECORD CLIP clip
RECORD START
1080p50 and 1080p59.94 (60M) Codecs
AVC-Intra
Container
Codec
Features
Audio
VizSend Example
MVCP Example
.mxf (OP1a)
AVCIntra Class 50
1440x1080
Alpha: No
Bitrate: 50
Bit depth: 10
VBI: N/A
Timecode: Yes
TDIR: Yes
CC: Yes
PCM:
RECORD CLIP clip
RECORD START
CUER U1
REC U1
.mxf (OP1a)
AVCIntra Class 100
1920x1080
Alpha: No
Bitrate: 100
Bit depth: 10
VBI: N/A
Timecode: Yes
TDIR: Yes
CC: Yes
PCM:
RECORD CLIP clip
RECORD START
CUER U1
REC U1
.mxf
Panasonic P2
(OP-Atom)
AVCIntra Class 50
1440x1080
Alpha: No
Bitrate: 100
Bit depth: 10
VBI: N/A
Timecode: N/A
TDIR: Yes
CC: No
No Audio
RECORD CLIP clip
RECORD START
.mxf
Panasonic P2
(OP-Atom)
AVCIntra Class 100
1920x1080
Alpha: No
Bitrate: 100
Bit depth: 10
VBI: N/A
Timecode: N/A
TDIR: Yes
CC: No
No Audio
RECORD CLIP clip
RECORD START
MPEG-IFrame
Container
Codec
Features
Audio
VizSend Example
MVCP Example
.avi
MPEG2-IFrame422
1920x1080
Alpha: No
Bitrate: 50-300
Bit depth: 8
VBI: N/A
Timecode: N/A
TDIR: Yes
CC: No
No Audio
PCM:
RECORD CLIP clip
RECORD START
ProRes
Container
Codec
Features
Audio
VizSend Example
MVCP Example
.mov
I-Frame 4:2:2
1920x1080
Alpha: No
Bit depth: 8, 10
VBI: N/A
Timecode: N/A
CC: No
No Audio
PCM:
RECORD CLIP clip
RECORD START
DNxHD
Container
Codec
Features
Audio
VizSend Example
MVCP Example
.mxf (OP1a)
DNxHD (50) 240, 365
DNxHD (59.94) 290, 440
1920x1080
Alpha: No
Bitrate (50): 240, 365
Bitrate (59.94): 290, 440
Bit depth: 8
VBI: N/A
Timecode: N/A
CC: No
No Audio
PCM:
CONFIG SET BITRATE 240
RECORD CLIP clip
RECORD START
.mxf (OP1a)
DNxHD (50) 365x
DNxHD (59.94) 440x
1920x1080
Alpha: No
Bitrate (50): 365 x
Bitrate (59.94): 440x
Bit depth: 10
VBI: N/A
Timecode: N/A
CC: No
No Audio
PCM:
CONFIG SET BITRATE 365
RECORD CLIP clip
RECORD START
DNxHD (50) 240, 365
1920x1080
Alpha: No
Bitrate (50): 240 , 365
Bitrate (59.94): 290 , 440
Bit depth: 8
VBI: N/A
Timecode: N/A
CC: No
No Audio
RECORD CLIP clip
RECORD START
DNxHD (50) 365x
DNxHD (59.94) 440x
1920x1080
Alpha: No
Bitrate (50): 365 x
Bit depth: 10
VBI: N/A
Timecode: N/A
CC: No
No Audio
RECORD CLIP clip
RECORD START
XAVC
Container
Codec
Features
Audio
VizSend Example
MVCP Example
.mxf (OP1a)
XAVC
Alpha: No
Bitrate: 100
Bit depth: 10
VBI: N/A
Timecode: Yes
TDIR: Yes
CC: Yes
PCM:
RECORD CLIP clip
RECORD START
2160p50 and 2160p59.94 (60M) Codecs
XAVC
Container
Codec
Features
Audio
VizSend Example
MVCP Example
.mxf (OP1a)
XAVC
Alpha: No
Bitrate: 300, 480, (VBR/CBR)
Bit depth: 10
VBI: N/A
Timecode: Yes
TDIR: Yes
CC: Yes
PCM:
CONFIG SET BITRATE 300
RECORD CLIP clip
RECORD START
Note: A M264 board is recommended for recording UHD.
Note: The configuration uhd and v210 must be enabled in the configuration section for recording UHD.
