This document describes the public scripting API available to Template Builder and Viz Pilot Edge templates. Scripts are written in TypeScript and compiled to JavaScript for execution in the browser. This API exposes the following:
  • Global TypeScript types
  • The global vizrt object (template-level events & data access)
  • The global app object (application-level utilities)
  • Global helper functions
Pilot Data Types
PilotData
Contains Pilot- and MOS-related information available to scripts.
Property
Type
Description
mosartConfig?
MosartConfig
Read-only Viz Mosart configuration
mosartTimingPanel?
MosartTimingPanel
State and options for the Viz Mosart Timing Panel
mos
MOS
MOS data and related settings
element?
PilotElementInfo
Information about the current data element
PilotElementInfo
Property
Type
Description
elementId?
string
ID of the currently open element
Mosart & Timing Panel
MosartTimingPanel
Represents the state and customization options for the Viz Mosart Timing Panel.
Property
Type
Description
destinations
readonly string[]
Available playout destinations
showIsLocator
boolean
Whether to expose the IsLocator option
showContinueCount
boolean
Whether to expose the ContinueCount option
expanded
boolean
Whether the panel is expanded by default (default: true)
MosartConfig
Read-only Viz Mosart configuration.
Property
Type
Description
showTimingPanel
boolean
Whether the timing panel should be shown
destinations
readonly string[]
Default Viz Mosart destinations
showIsLocator
boolean
Whether IsLocator is shown by default
MOS Types
MEMBlock
A MOS External Metadata (MEM) block.
Property
Type
Description
schema
string
Schema URL for the block
payload
string
XML payload content
scope
"PLAYLIST" | "STORY" | "OBJECT"
The scope of the MEM block
MEMAccess
Provides access to MEM blocks in MOS items.
Methods
Method
Description
get(schema)
Returns a MEM block by schema URL, or undefined
set(block)
Creates or updates a MEM block
delete(schema)
Removes a MEM block
MOS
Represents MOS state for the current template.
Property
Type
Description
mosart?
MosartTimingValues
Viz Mosart timing values MEM
continueCount?
number
Continue count MEM
description?
string
MOS description
abstract?
string
MOS abstract
slug?
string
MOS slug
mem
MEMAccess
Access to MEM blocks
MosartTimingValues
Timing values for Viz Mosart playout.
Property
Type
Description
channel
string
Playout channel
start
string
Start time
duration
string
Duration
inMode
InMode
In mode
outMode
OutMode
Out mode
isLocator
boolean
Whether locator is enabled
InMode
"auto" | "manual"
OutMode
"auto" | "story-end" | "background-end" | "open-end"
Playout & Media Sequencer Types
VizLayer
"MAIN" | "FRONT" | "BACK"
PlayoutTarget<Layer>
Property
Type
Description
profile
string
Media Sequencer profile
channel
string
Media Sequencer channel
layer?
Layer
Viz Engine layer (default: "MAIN")
MseConnection
Provides commands executed on Media Sequencer.
Methods
Method
Description
sendVizCommand(target, ...commands)
Sends Viz Engine commands
take(target)
Executes a take command
update(target)
Executes an update command
continue(target)
Executes a continue command
out(target)
Executes an out command
checkConnection()
Returns Promise<boolean> indicating connection validity
Global app Object
The app object exposes Viz Pilot Edge application utilities.
Methods
  • app.notify(severity, message): Displays a UI toast notification.
Parameter
Type
severity
"warning" | "info" | "error" | "success"
message
string
  • app.createMseConnection(url): Creates an MseConnection.
  • app.jumpToFieldPreview(path): Jumps to a specific field's preview based on the given path.
  • app.jumpToPreviewPoint(name): Jumps to a named preview point.
Global vizrt Object
The vizrt object provides access to template fields, environment data, and lifecycle hooks.
Properties
Property
Type
Description
$env
Partial<Readonly<Record<string, string>>>
Environment variables
$pilot
PilotData
Pilot-related variables
$data
Partial<Record<string, string>>
Temporary data for dynamic editors
fields
Payload
Template field values
Events or Hooks
  • vizrt.onCreate: Called when a new data element is created in Viz Pilot Edge. Not triggered in Template Builder.
  • vizrt.onLoad: Called when an existing data element is opened in Viz Pilot Edge. Not triggered in Template Builder.
  • vizrt.onClick(name): Called when a click event is triggered from a UI element with vizrt-click-name.
  • vizrt.onUpdate(fields, action): Called from Script Runner when Update Service is configured. Not triggered in Template Builder or Viz Pilot Edge.
  • vizrt.onAfterSave: Called after the data element is saved successfully.
Global Helper Functions
  • createRichText(plainText, escape?): Creates a RichText object that can be assigned to the Formatted field type.
  • createImageAsset(image, title?): Creates an ImageAsset from a URL, path or GH ID.
  • createVideoAsset(video, title?): Creates a VideoAsset from a local file path.
  • reportErrors(f, stage): Captures errors from a callback or async chain and reports to the UI.
Deprecated
  • vizrt.jumpToPreviewPoint(name) is deprecated. Use app.jumpToPreviewPoint() instead.
