Configure a Service
Click
Select a Service (see Services):
Add camera service
Add object service
Click on the service icon in the Services panel.
Configure the service in the Properties panel.
Rig: Type the name of the rig whose data should send to an engine
IP: IP address of the Viz Engine, which is to receive the tracking data
Port: Port number for this connection, (same port as configured in the Viz Engine configuration)
Cam.Number: Same as Viz Engine is expecting
Mode: Not in use (default = 0)
Active: When checked the service is active, unchecked no data is send to the Viz Engine
Click Start in the Configure the Studio.
Click Save in the Configure the Studio.
