Viz Arc User Guide
Version 2.0 | Published July 03, 2024 ©
Installing Viz Arc
  1. Uninstall any previously installed Viz Arc versions.
  2. Run the installer. Depending on the target system, you might need to install the required prerequisites which are the MS Visual C++ 2015-2022 Redist (X64), Windows Desktop runtime, Asp.Net Core runtime and the Codemeter Runtime Kit.
    images/download/attachments/158778144/install.png
    Select the parts you want to install on the target machine:
    1. Viz Arc, the main application.
    2. Viz Arc REST Service, required when Viz Arc actions shall be called from Viz Pilot, Pilot Edge or the MOS integration.
    3. Viz Unreal Loader, required on machines running an Unreal Engine which are controlled by Viz Arc. This installer contains the Viz Arc communication plugins for the Unreal Engine which can be found in C:\ProgramData\vizrt\VizArc\Resources\unreal after installation. When the installer detects an existing Unreal installation it offers the automatic deployment of the plug-in when the respective checkbox is selected.
  3. Press Finish to complete installation.
    images/download/attachments/158778144/installfinished.png
Note: After installation, you must first configure your system, and request and apply the license to use all of the software features.
