Many map designs come with a small locator to indicate where the story happens.
To transfer the geographical information from one Map system to another container in GeoTransformation mode, we will use the GeoCameraLink
  • We need to build a scene with two map containers, both with GeoCanvas and GeoCamera on it. One as Reference, one for the Locator Map.
  • Resize the Locator Map
  • Add a sub container in GeoTransformation mode to the Locator map.
  • Create some graphics indicating this position. e.g. a circle or a Noggi as outline.
  • Now add the CameraLink plugin to it.
  • Drag the Reference map container as the new Source Container inside the CameraLink plugin.
Any change on the GeoCamera will now be applied correctly to the smaller locator container.
As a map can automatically act as a MaskSource, we can easily cut off the indicator to render outside the map by applying the MaskTarget to it. This prevents the two lines in our example to be “off”-map.
The plugin takes care of different projections. You’ll notice that when moving towards the poles.
This is because of the fact, that you cannot project a globe correctly on a flat surface.
