The panel lists the controllable fields of the objects currently loaded into the master - what a control application would show to the operator. Values changed here are applied to the rendered master immediately, the same way a control application sends them.
The funnel switch in the panel header decides how much is listed:
Title
Shows
Control Objects - live (NewsMaster)
The fields of everything loaded into the master. This is what you see while the switch is off.
Control Objects - 1000
Only the fields of the scene you selected or took last in the Scenes pane. This needs the switch to be on.
With the switch on, the panel follows your selection in the Scenes pane and moves to the scene you take; selecting the master row returns it to the whole master.
