![](assets/images/logos/Gateway.png)
Gateway Administrator Guide
Version 5.5 | Published July 06, 2023 ©
Introduction
Gateway is Vizrt’s implementation of the Media Object Server (MOS) Protocol. It enables users of a Newsroom Computer System (NCS) to perform instant updates on running orders (rundown/playlist) in Vizrt content control applications such as Viz Trio and Viz Pilot.
As Gateway supports multiple NCS connections, it allows content control applications to request and monitor multiple running orders from multiple newsroom systems. By supporting the MOS protocol, Vizrt is able to integrate a wide range of its products with Newsroom Computer Systems that supports the MOS Protocol.
The Gateway Controller Client’s graphical interface is browser-based.
Important! A 64-bit version of Windows is required to run Gateway.
Related Documents
Gateway has previously been known as Vizrt Viz Gateway, Viz Gateway or Viz MOS Gateway. As of version 2.0, the preferred name is simply Gateway.
All related documents contain information on how to configure a content control application to request running orders from the newsroom system through the Gateway connection. For complementing information see the following documents:
Viz Pilot User Guide: Contains information on how to create content based on templates, how to playout elements in playlists based on these templates, and how to install and configure Viz Pilot as a stand-alone product, and with integrated third-party systems such as newsroom systems and other Vizrt products.
Viz Trio User Guide: Contains information on how to use the Vizrt character generator for real-time update of scenes from the operator desk.
Tip: You can find updated documentation for Viz software on the Documentation portal.
Feedback and Suggestions
Legal
Copyright © $action.dateFormatter.formatGivenString($paramFormat, $content.currentDate) Vizrt. All rights reserved.
Disclaimer
Antivirus
Vizrt does not recommend or test antivirus systems in combination with Vizrt products, as the use of such systems can potentially lead to performance losses. The decision for the use of antivirus software and thus the risk of impairments of the system is solely at the customer's own risk.
There are general best-practice solutions, these include setting the antivirus software to not scan the systems during operating hours and that the Vizrt components, as well as drives on which clips and data are stored, are excluded from their scans (as previously stated, these measures cannot be guaranteed).
Technical Support
For technical support and the latest news of upgrades, documentation, and related products, visit the Vizrt web site at www.vizrt.com.
