![](assets/images/logos/Gateway.png)
Gateway Administrator Guide
Version 5.5 | Published July 06, 2023 ©
Pre-Configuration
From the NCS, obtain the following information:
NCS ID, NCS server IP, MOS version, and MOS ID.
To use the Oracle database as a backend, obtain the following information:
Oracle System Identifier (SID), username, password, and UTF-8 character encoding.
To use the Pilot Data Server as a backend, obtain the following information:
Base URL and the port number for the Pilot Data Server: http://hostname:8177
If the Gateway is installed on another host than the Oracle database, the hostname of the database must be used in addition to the SID (<hostname>/<SID>). To test the database connection, try typing tnsping hostname/SID on the command-line.
Port numbers used in screen-shots in this document are standard port numbers used in the MOS Protocol. Other port numbers may be used.
