Version 5.4 | Published November 24, 2023 ©
tdfi_connection
The table tdfi_connection which contains a list of fields (or newsroomtags) that corresponds to a template description. See also information given in the td_templatedescription table.
This is a relation table defining a many-to-many relationship between the td_templatedescription and fi_field tables.
Name |
Type |
Allow Null |
Description |
tdfi_recno |
integer |
No |
Primary key. |
tdfi_td_recno |
integer |
No |
Foreign key referencing the corresponding template description td_recno in the td_templatedescription table. |
tdfi_fi_recno |
integer |
No |
Foreign key referencing the corresponding field fi_recno in the fi_field table. |
tdfi_default |
varchar(128) |
Yes |
Optional default value for fields not of type ENUMERATION. I.e for STRING and NUMBER types. |
tdfi_em_recno |
integer |
Yes |
Optional foreign key for the default value for ENUMERATION field types. Reference to a enumeration value em_recno in the em_enumerationmember table. |
