Viz Multiplay User Guide
Version 3.2 | Published March 07, 2024 ©
Toolbar and Channels Layout
Toolbar
Configure how Viz Multiplay looks in your display from the toolbar using Settings, Show and Hide Sources Pane, and 1-Tap Mode.
Click on the Viz Multiplay logo for version information, as well as links to documentation and third party licenses.
Show/Hide: Toggle both the Show Pane and Finding Media and Content in Sources Pane on/off.
New and Open: Create a new Show or open an existing one.
Settings: Open the Viz Multiplay settings window from the tool bar.
From the General Tab, you can change the thumbnail size, show/hide the status bar, and set whether to display a preview in the Program column when clips are taken to air.
Use the Profiles Tab to individually configure Profiles, Channels, Viz Engine handlers and Viz Video handlers, as well as easily configure video walls.
Use the Workspaces Tab to create Workspaces, which define which sets of channels are hidden from view for each type of user.
The Inboxes Tab allows setup of one or more global shows in which multiple users can ingest new elements (images, clips, graphics) simultaneously. These elements are available to the Viz Multiplay operator instantly.
Use the Servers Tab to configure preview servers and MAM systems that help to search media quickly.
1-Tap Mode: When enabled, the Armed column is hidden and tapping an element or shortcut in the Media column will take it directly to Program. In this mode, elements can still be dragged between channels, or dragged to the program channel. When 1-Tap is disabled, tap arms an element. Tap in the Arm column to take it to Program. Drag elements to the preview pane to preview them.
Cleanup: Unloads resources from Viz Engine in the current profile.
Initialize: Loads the scene resources of the Show onto the Viz Engines in the profile. See Preparing and Playing Out Content.
Shortcuts: Display the keyboard shortcuts in Viz Multiplay. See Keyboard Shortcuts.
On Air Mode: Click this button to toggle between on and off air mode. In On Air Mode, the button turns red and is labelled ON AIR. In Off Air Mode, the button is grey and labeled OFF AIR. Some functions in the user interface that are used for sending items to air in On Air Mode are not available in Off Air Mode. This is in order to hinder elements from accidentally being sent to air while editing a show or channel.
The following panels and columns are hidden in Off Air Mode:
The Arm and Take Multiple Elements Action Bar.
The Armed column.
The Program column.
Tablet Set-up
As space is limited on a tablet, a compact layout is provided automatically. You can also consider using the following display settings:
Hide the Status bar (see Settings).
Enable 1-Tap Mode.
Adjust the icon size (see Settings).
Resizing and Collapsing Channels
Channels can be custom-sized, expanded by row or collapsed entirely.
Set Custom Channel Size
Hold down ALT.
Hover the cursor over the top edge of a channel header until the cursor turns into a row separator (row resize cursor).
Drag the separator up or down as desired.
When holding ALT the channels can be resized freely. Without ALT the channels are resized to a factor of the thumbnail height.
Resizing Channels from the Context Menu
Right-click the channel header and select the Set Height menu item:
Select the desired row height.
Select Auto to enable automatic creation of new channel rows when new items are added to a full row.
Collapsing Channels
Click the channel header to collapse individual channels.
Click Collapse All (or Expand All depending on the objective).
Tip: Use the keyboard shortcuts SHIFT + C and SHIFT + E to collapse and expand all channels, respectively.
Tip: If a profile contains several video walls, the interface can quickly become crowded with channels. Create different workspaces to hide channels. The workspace is a personal setting that is specific to each Viz Multiplay client.
