Viz Plug-ins User Guide
Version 5.2 | Published December 12, 2023 ©
Text FX Color Per Vertex
images/download/thumbnails/95402155/ico_tfx_cpv.png
The Text FX Color Per Vertex plug-in adds a color per vertex effect to the text.
Supported Pipelines
Classic Render Pipeline
images/s/2wwyjx/8804/1yuue1v/_/images/icons/emoticons/check.svg
Viz Engine Render Pipeline
images/s/2wwyjx/8804/1yuue1v/_/images/icons/emoticons/error.svg
Note: Works only if the text is set to texture (does not work with geometry text).
Text FX Color Per Vertex Properties
  • Color Bbox: Defines the reference bounding box, global for the entire text, or local for each character.
  • Color Direction: Defines the color gradient shape. Available options are; top left to bottom left, top right to bottom right, top left to top right, bottom left to bottom right, top right to bottom left and four corners.
  • Color Level: Sets the level of the color (0.1 to 1.9). Default is 1.0.
  • Top and Bottom Left and Right: Sets the color and alpha value for each edge.
  • Color use Alpha: Enables alpha.
