Viz Ticker User Guide
Version 4.0 | Published June 29, 2021 ©
Scrolling Carousel Conventions
The following design conventions apply only for scrolling carousel scenes.
Scrolling carousel scenes are characterized by containing one or more Scroller plug-ins with belonging directors and stop points.
A scrolling carousel scene must be designed according to the following conventions:
The Layer setting in the Scroller plug-in editor must be identical to the director holding the in and out stop points.
The Element Source in the Scroller plug-in editor must be identical to the in state stop point of the layer director.
The out state stop point of the layer director must be named the letter O. All other states are in state stop points.
All template containers must be organized under a root container called ticker_templates. It is important to position the ticker_templates container at the top of the root level of the scene tree, as Viz Engine performs a depth-first search when identifying containers. This means that the system starts with the first root container, and searches through all of its sub-containers, before moving on to the second root container, and so on. Keeping template containers high up in the tree structure improves performance.
Do not add any containers under the container holding the Scroller plug-in. The scroller generates its own tree structure with copies of the template containers.
Geometry plug-ins/Ticker section in Viz Artist User Guide
