Datacenter User Guide
Version 2.1 | Published April 03, 2024 ©
Custom Mapping of Dataset Keys
To facilitate matching input data with existing control channels/objects on a configured Viz Engine setup, Datacenter offers a way to intuitively map input entries keys to known Viz Engine channels/objects.
images/inline/39e1ec83e9950dd86beb967daba63c42b13f6b14576cbcb2c861f7b1811e97c9.png
To do so, select a dataset from the Datasets panel and click on the custom mapping icon on the engine output to edit:
images/download/attachments/149915807/image-2024-1-25_9-57-18.png images/download/thumbnails/149915807/image-2024-1-24_18-41-10.png
All current keys are listed in the dialog shown. Next to each, there's a search-box to search for all the advertised control channels and control objects on the selected viz Engine output.
images/download/attachments/149915807/image-2024-1-25_12-4-10.png
In the example above, the input dataset "file-test" has four keys ("booker12", "grey07", "johnson81" and "jenkins46"), while the selected Viz Engine "My Engine" exposes two control channels/objects ("frame_nr" and "name").
You can now choose a custom mapping for any input key, by simply selecting a value from the right-side search-box:
images/download/attachments/149915807/image-2024-1-25_12-7-30.png
For example, the picture above shows the current custom mapping:
  • booker12 → frame_nr
  • grey07 → name
  • johnson81 → johnson81
  • jenkins46 → jenkins46
By clicking Save, the current mapping is applied. Clear All resets the mapping to its default value (input keys not remapped).
When a custom mapping is applied to a dataset, selecting that dataset reveals a green dot next to the output name:
images/download/thumbnails/149915807/image-2024-1-25_12-11-22.png
For example, the picture below shows the case where the Dataset "file-test" has a custom mapping specified for the output "My Engine" but not for the output "My output".
images/download/attachments/149915807/image-2024-1-25_12-11-58.png
