Datacenter User Guide
Version 2.1 | Published April 03, 2024 ©
Viz Arc Output
To create an output of type Viz Arc, add a new output and click on the new entry.
On the dialog shown, select Viz Arc in the Type field, and fill all other fields as required:
images/download/attachments/149925134/image-2024-1-25_16-17-7.png
  • Name: Name of the output that is displayed in the output list.
  • Host: Host address where Viz Arc runs.
  • Port: The port to connect to.
  • Check connection every (ms): Specifies how often the communication between Viz Arc and Datacenter is health-checked.
To learn more about configuring Viz Arc to accept incoming data from Datacenter, please refer to the Configuring Output section of this manual.
