Reality Connect User Guide
Version 1.0 | Published March 14, 2024 ©
AI Terminal Configuration
Create Instance
After installation, Reality Connect is automatically discovered by the AI Terminal. Click the + button next to the tool to create an instance.
images/download/attachments/130548464/RealityConnect_Launch.png
Input/Output Configuration
Create and configure the following input/output modules.
images/download/attachments/130548464/image-2023-6-30_11-47-41.png
Shared Memory Sync
  • Choose a Performance mode. If performance problems appear later when starting the tool, this mode can be changed to improve performance.
  • Specify the same value for Key as configured earlier in Viz Engine Configuration.
  • Select this input as Sync in the Reality Connect box.
Shared Memory Input
  • Set Key to viz_{instance}_{input}_aux.
    • {instance}: The Viz Engine instance (which is 1 by default).
    • {input}: The Viz Engine input (which is live1 by default).
  • Set Graphics device to the device the Viz Engine is running on.
  • Select this input as Video Input in the Reality Connect box.
Tracking Hub Input
  • Specify the same value for Port as the Tracking Port configured earlier in Tracking Hub Configuration for the camera service sending to Reality Connect.
  • Select this input as Camera Data in the Reality Connect box.
Pose Data Sender
  • Select Joint Positions as the 3D Positions.
  • Set the Hostname to 127.0.0.1. The Viz Engine must run on the same computer as Reality Connect.
  • Set the Number of joints to 34.
  • Specify the same value for Port as the General Communication Port configured earlier in Viz Engine Configuration.
Tool Configuration
images/download/thumbnails/130548464/RealityConnect_AiTerminal.png
Configuration
  • Select the Graphics device that is used by Reality Connect.
  • Specify the maximum number of talents to be tracked. This should match the number of models imported earlier in Viz Engine Scene Design.
Note: Despite multiple talents being tracked, this version of Reality Connect does not contain a control mechanism to assign talent models to the actual talents. This implies that the same talent model should be chosen for each talent.
Control
  • Choose the desired Smoothing Strength mode. This affects the quality of the tracked data and the overall system delay (check Delay Configuration for more information).
  • Specify the Z-Position of the virtual ground plane as Ground Plane Offset. This controls on which height the tracked talents are projected to.
Info: The control parameters can be changed dynamically during runtime.
Verify Configuration
Start the tool and verify that no errors are shown. Check the AI Terminal User Guide for proposed actions in case of errors.
If all applications are setup as instructed, the models imported as described in Viz Engine Scene Design, should be animated by the tracked talent motion.
