Reality Connect User Guide
Version 1.0 | Published March 14, 2024 ©
Delay Configuration
Camera tracking and video data needs to be synchronized both for Viz Engine and Reality Connect. The delays are affected by multiple factors such as hardware performance and parameters. Read through this chapter to learn how to correct these delays.
Overview
images/download/attachments/130556513/image-2023-7-11_9-51-26.png
Reality Connect adds an additional delay to the virtual studio system. The image and camera data need to be delayed correspondingly for Viz Engine to render the scene. Details are explained in the following section.
Synchronization Guidelines
Configure the following parameters to synchronize the system.
Note: It is important to specify the following delays in a top-down order, as some parameters affect others.
Smoothing Strength
images/download/thumbnails/130556513/Delay_Smoothing.png
A stronger Smoothing Strength increases the overall delay of the system.
Performance Mode
images/download/thumbnails/130556513/Delay_PerformanceMode.png
The overall delay of the system is increased when not every field is processed.
Info: This assumes that no performance problems are encountered. If a corresponding warning is displayed choose a different performance mode.
Tracking Hub Delay for Viz Engine
images/download/attachments/130556513/Delay_TrackingHub.png
Synchronize the camera data with the Viz Engine using the Overall Delay (Fields) parameter within the camera rig connected to the Viz Engine. This Camera Delay has to be determined experimentally.
For the camera data which is sent to the Viz Engine, add to this Camera Delay the Processing Delay from the Delay Value Table below.
Tracking Hub Delay for Reality Connect
Synchronize the camera data with Reality Connect using the Overall Delay (Fields) parameter within the camera rig connected to Reality Connect.
As Overall Delay (Fields) set the previously determined Camera Delay (without the Processing Delay).
Viz Engine Delay after Inputgraph
This delay synchronizes the talent tracking data received from Reality Connect with the Viz Engine rendering.
Change this delay by executing the following Viz Engine command:
MAIN_SCENE*VIDEO*VIDEOIN*1*DELAY_AFTER_INPUTGRAPH SET {X}
Choose the Processing Delay value {X} according to the Delay Value Table at the end of this chapter.
Note: VIDEOIN*1 refers to LIVE1 being the camera input source. Change correspondingly if you are using a different input.
Delay Value Table
Performance Mode
Smoothing Strength
Processing Delay
Every sync
Off
3
Light
4
Medium
5
Strong
7
Every second
Off
4
Light
5
Medium
6
Strong
8
Every fourth
Off
8
Light
8
Medium
8
Strong
10
