Viz Arc User Guide
Version 1.7 | Published November 15, 2022 ©
Import and Export
By right-clicking on an empty space in the main area is also possible to import and export.
images/download/attachments/54031774/arc_ie_cm.jpg
Import Actions
images/download/thumbnails/54031774/arc_imp.jpg
In Viz Arc, you can import action boxes directly into your active project. There are two ways to import boxes: internally (From Clipboard) or from an external file (creates a text file containing a .json structure). The boxes are imported directly into the same tab as they were located if such a tab exists, or imported into your active tab area.
Export Actions
images/download/attachments/54031774/arc_exp.jpg
You can export selected action boxes or all boxes in the opened project. You can choose to export boxes internally (To Clipboard) or to an external file (creates a text file containing a .json structure).
